#1 2025-04-17 10:01:24
AhmadRaniri
[SOLVED] How does polkit work on devuan / sysvinit ?
Hello, I was devuan user in the past and now daily driving a distro with sysvinit (LFS). I'm curious about how polkit works on devuan sysvinit. Does it have a service file so it can run in the background ? My distro is a bit weird, it needs seatd in order polkit to show up afer launching wayland compositor. Where I can look to know how the polkit get built on devuan ? Thanks.
#2 2025-04-17 12:12:01
Re: [SOLVED] How does polkit work on devuan / sysvinit ?
Code for forked packages is here:
https://git.devuan.org/devuan/policykit-1
You can also get devuan package information from here:
https://pkginfo.devuan.org/cgi-bin/policy-query.html
If you can't find an associated package on our git, check salsa.debian.org.
#3 2025-04-17 12:55:36
AhmadRaniri
Thanks Admin.
