#1 2025-04-13 12:09:44
mirrortokyo
mesa and VA-API hardware acceleration
I'm not sure if it has been my hardware "AMD Ryzen 5 5500GT with Radeon Graphics" being less tested than discrete AMD GPU's, but I had quite a lot of video lock-ups after Firefox enabled VA-API hardware decoding by default.
Just to be sure, I also tested using:
mpv --vo=gpu --hwdec=vaapi
I searched: https://gitlab.freedesktop.org/mesa/mesa/-/issues
and filed my findings under the report:
https://gitlab.freedesktop.org/mesa/mesa/-/issues/12528 "HW accelerated video playback causes VCN timeout"
After several days of building mesa-git and the Linus git head kernel, I appear to have working VA-API acceleration under mpv and Firefox.
The anti-climax was that no obvious commit appeared to fix the issue, just ongoing code clean-ups.
#2 2025-04-13 17:52:26
Re: mesa and VA-API hardware acceleration
VA-API is - as far as I know- hardware acceleration using Intel-Graphics.
There is a warper for nvidia GPUs for VA-API calls (nvidia-vaapi-driver).
No idea how or whether this is possible with Radeon graphics.
#3 2025-04-14 01:04:35
mirrortokyo
VAAPI hardware decoding is available on R600 and above Radeon gpu's according to https://www.x.org/wiki/RadeonFeature/
VAAPI hardware encoding is available on a more limited set of Radeon gpu's according to the same web page.
#4 2025-11-25 17:30:05
NicePics13
hmm Something did happen with VAAPI, in Daedalus I could play back 10 bit HEVC 4k@60fps videos with no problem but in Excalibur I get nothing but dropped frames with the same config
#5 2025-11-25 23:37:29
Devarch
For some unknown for me reason I can't use vulkan in mpv.conf with AMD Radeon Integrated Graphics. Vulkan is ok but not with mpv.
so I've to use
vo=gpu-next
hwdec=vaapi
gpu-api=opengl
#6 2025-11-26 16:31:54
NicePics13
vo=gpu-next
hwdec=vaapi
gpu-api=opengl
big_smile That was it!
I don't get it why vulkan video decoding wouldn't work on my rig (RX 460 Vulkan 1.3)
