#1 2025-03-23 13:41:43
fahro
libguava-java (gradle)
Hello,
I am trying to resolve issue with libguava-java. The context is: I want to prepare build environment for calimero java libraries in NetBeans. Gradle installation failed with errors related to libguava-java. Also gradle --version fails.
--fix-missing fails with:
fahron@ibnrusd:~$ sudo apt --fix-broken install
Correcting dependencies... Done
  libguava-java
  libguava-java
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
7 not fully installed or removed.
Need to get 2,613 kB of archives.
After this operation, 2,959 kB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged daedalus/main amd64 libguava-java all 31.1-1 [2,613 kB]
Ign:1 http://deb.devuan.org/merged daedalus/main amd64 libguava-java all 31.1-1
Err:1 http://deb.devuan.org/merged daedalus/main amd64 libguava-java all 31.1-1
  Connection timed out [IP: 199.232.18.132 80]
E: Failed to fetch http://deb.debian.org/debian/pool/main/g/guava-libraries/libguava-java_31.1-1_all.deb  Connection timed out [IP: 199.232.18.132 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Environment is
fahron@ibnrusd:~$ lsb_release -a
No LSB modules are available.
Distributor ID:	Devuan
Description:	Devuan GNU/Linux 5 (daedalus)
Release:	5
Codename:	daedalus
fahron@ibnrusd:~$
fahron@ibnrusd:~$ uname -a
Linux ibnrusd 6.1.0-31-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.128-1 (2025-02-07) x86_64 GNU/Linux
fahron@ibnrusd:~$
Any help is highly appreciated.
Thank You,
#2 2025-03-23 23:01:42
Re: libguava-java (gradle)
It sometimes helps to run
apt-get update
to update your local meta files.
TL;DR; apt asks for particular versions of packages and it does not ask for "whatever is current right now" (as one might think it would do). The meta files tell "slices" of versions across packages that have been tested and shown to work together. Sometimes one would want apt to run "update" automatically upon install of packages, but I guess that would add code "unnecessarily"; anyone who wants update to be part of installing would simply do that themselves.
Sometimes though it's a neworking problem, or that the target server has a transient problem.
#3 2025-04-01 20:33:31
fahro
It seems as permanent problem. Still getting the same errors, but now I cannot upgrade in general; whilst apt-get update passed.
  libguava-java
  libguava-java
0 upgraded, 1 newly installed, 0 to remove and 39 not upgraded.
fahron@ibnrusd:~$ sudo apt-get upgrade
You might want to run 'apt --fix-broken install' to correct these.
 liberror-prone-java : Depends: libguava-java but it is not installed
 libgradle-core-java : Depends: libguava-java (>= 23.0) but it is not installed
 libguice-java : Depends: libguava-java but it is not installed
 libplexus-container-default-java : Depends: libguava-java but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I will have to look for something else. Anyway, thank you.
#4 2025-04-02 16:24:47
What is in your /etc/apt/sources.list ? Your first quote contains:
Which suggests you have a mixture of devuan and debian resources. That is a recipe for disaster. You should only have devuan in there. Also check /etc/apt/sources.list.d/ as well.
And I'm not sure where the IP address 199.232.18.132 is supposed to be. Reverse DNS lookup fails but it responds to ping.
#5 2025-04-03 20:32:18
fahro
Well, I already did some basic troubleshooting and sources.list is fine.
#deb cdrom:[Devuan GNU/Linux 5.0.1 daedalus amd64 - netinstall 20230914]/ daedalus contrib main non-free non-free-firmware
deb http://deb.devuan.org/merged daedalus main non-free-firmware
deb-src http://deb.devuan.org/merged daedalus main non-free-firmware
deb http://deb.devuan.org/merged daedalus-security main non-free-firmware
deb-src http://deb.devuan.org/merged daedalus-security main non-free-firmware
# daedalus-updates, to get updates before a point release is made;
# see https://www.debian.org/doc/manuals/debian-reference/ch02.en.html#_updates_and_backports
deb http://deb.devuan.org/merged daedalus-updates main non-free-firmware
deb-src http://deb.devuan.org/merged daedalus-updates main non-free-firmware
# This system was installed using small removable media
# (e.g. netinst, live or single CD). The matching "deb cdrom"
# entries were disabled at the end of the installation process.
# For information about how to configure apt package sources,
# see the sources.list(5) manual.
So far, after timeout apt-get switches to deb.debian.org and I wonder how.
Somewhere down the road of installation of NetBeans, Java, calimero, gradle, ... something went wrong.  I will try on Debian vanila box and see how it goes on.
Still, I would like to know mechanics of failback after timeout. Where it is configured? Or, I have malfunctioned package somewhere (or malicious?)
I have the same response when trying to reach 199.232.18.132 80. Traceroute does not report anything as well.
Is it possible to run apt-get with detailed debug logs to check what is going on?
#6 2025-04-03 21:36:36
well, is there any package that is not in main and non-free-firmware you want to install?
the sources.list is missing contrib non-free.
#7 2025-04-03 21:47:27
Looks to me like your system is all good and that you have run into a flaw in debian's package provisioning; namely that they happen to include a host that is currently unresponsive.
Debian packages are accessed (by your host) via the domain deb.debian.org which afaik is resolved by "fastly" into one (or possibly a few) actual host IP, and it happens that it transiently offers "bad" IP.
If you want your resolution of deb.debian.org go to a specific host of your choice, then you may set up that resolution in your /etc/hosts file.
Sometimes this kind of thing happens if your local meta files are outdated, in which case you will have to run apt-get update to freshen them.
#8 2025-04-04 21:36:15
fahro
I tried apt-get update sequence several times and it does not work. Now, I do not want debian packages from Debian (or anywhere else) unless absolutely necessary.
This is sequence
fahron@ibnrusd:~$ sudo apt-get update
[sudo] password for fahron:
Get:1 http://deb.devuan.org/merged daedalus InRelease [43.0 kB]
Get:2 http://deb.devuan.org/merged daedalus-security InRelease [33.2 kB]
Get:3 http://deb.devuan.org/merged daedalus-updates InRelease [33.4 kB]
Get:4 http://deb.devuan.org/merged daedalus-security/main Sources [117 kB]
Get:5 http://deb.devuan.org/merged daedalus-security/main amd64 Packages [254 kB]
Fetched 481 kB in 1s (508 kB/s)
  libguava-java
  libguava-java
0 upgraded, 1 newly installed, 0 to remove and 40 not upgraded.
I prepared transcript of all actions since I started. Need to cleanup some trash from console trace and will bring in next post.
#9 2025-04-04 21:40:49
fahro
So, this is list of actions I did until I started this thread. All straightforward administration after Devuan netinstall.
sudo apt-get update
apt search openjdk | more
sudo apt search jdk | more
sudo apt search jdk | grep ^openjdk
sudo apt search jdk | grep openjdk
sudo apt-get install openjdk-17*
java -version
cd Downloads/
ls -al
dpkg -i apache-netbeans_24-1_all.deb
sudo dpkg -i apache-netbeans_24-1_all.deb
sudo apt-get update
cd ../Downloads/
ls -al
mv calimero-server-2.6.zip ../sw/.
cd -
ls -al
unzip calimero-server-2.6.zip
clear
ls -al
rm -r calimero-core-release-2.6/
clear
ls- al
ls -al
cd calimerocpp/
ls -la
find . type f
clear
find . -type f
find . -type f -exec rm {} \;
clear
ls -al
cd test
ls -al
cd ..
clear
cd ..
ls -al
unzip calimero-core-release-2.5.1.zip
ls -al
unzip calimero-gui-release-2.5.1.zip
clear
ls -al
rm calimero-core-release-2.5.1.zip
ls -al
rm calimero-gui-release-2.5.1.zip
ls -al
unzip calimero-server-release-2.5.1.zip
ls -al
rm calimero-server-release-2.5.1.zip
ls -al
unzip calimero-tools-release-2.5.1.zip
rm calimero-tools-release-2.5.1.zip
clear
ls -al
gradle -version
sudo apt search gradle
sudo apt search gradle | grep ^gradle
sudo apt-get install gradle
sudo apt-get --fix-missing
sudo apt --fix-missing
sudo apt-get update
sudo apt-get
man apt-get
man apt
man apt-get
sudo apt-get install gradle --fix-missing
sudo apt-get install libgradle-core-java
sudo apt-get install libgradle-plugins-java
sudo apt-get update
gradle --version
sudo apt-get install build-essential debhelper devscripts
nslookup 195.85.215.80
lsb_release -a
uname -a
sudo apt-get updfate
sudo apt-get update
sudo apt-get update
y
sudo cat /etc/apt/sources
sudo cat /etc/apt/sources.list
sudo apt-get
man apt-get
exit
#10 2025-04-05 19:00:28
fahro
OK, I give up.
The same problem is on vanilla Debian.
Get:44 http://deb.debian.org/debian bookworm/main amd64 libguava-java all 31.1-1 [2,613 kB]
Ign:44 http://deb.debian.org/debian bookworm/main amd64 libguava-java all 31.1-1
Err:44 http://deb.debian.org/debian bookworm/main amd64 libguava-java all 31.1-1
Fetched 81.2 MB in 3min 9s (429 kB/s)
root@curie:~#
After update/upgrade the same.
root@curie:~# apt-get update
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
root@curie:~# apt-get upgrade
Calculating upgrade... Done
root@curie:~# apt-get install gradle
  ant ant-optional antlr bnd groovy ivy java-wrappers junit4 libantlr-java libaopalliance-java libapache-pom-java libasm-java libatinject-jsr330-api-java libbcel-java libbcpg-java
  libbcprov-java libbindex-java libbsf-java libbsh-java libcdi-api-java libcommons-cli-java libcommons-codec-java libcommons-collections3-java libcommons-compress-java libcommons-io-java
  libcommons-lang-java libcommons-lang3-java libcommons-logging-java libcommons-parent-java libdd-plist-java libdom4j-java libeclipse-jdt-annotation-java libel-api-java liberror-prone-java
  libfelix-framework-java libfelix-gogo-runtime-java libfelix-osgi-obr-java libfelix-resolver-java libfindbugs-java libgeronimo-annotation-1.3-spec-java
  libgeronimo-interceptor-3.0-spec-java libgoogle-gson-java libgpars-groovy-java libgradle-core-java libgradle-plugins-java libguava-java libguice-java libhamcrest-java
  libhawtjni-runtime-java libhttpclient-java libhttpcore-java libjansi-java libjansi-native-java libjansi1-java libjarjar-java libjatl-java libjavaewah-java libjaxen-java libjcifs-java
  libjcip-annotations-java libjcommander-java libjcsp-java libjetty9-java libjformatstring-java libjgit-java libjline2-java libjna-java libjna-jni libjsch-java libjsoup-java
  libjsp-api-java libjsr166y-java libjsr305-java libjzlib-java libkryo-java libkxml2-java liblogback-java libmaven-parent-java libmaven-resolver-java libmaven-shared-utils-java
  libmaven3-core-java libminlog-java libmultiverse-core-java libnative-platform-java libnative-platform-jni libnekohtml-java libobjenesis-java libosgi-annotation-java
  libosgi-compendium-java libosgi-core-java libplexus-cipher-java libplexus-classworlds-java libplexus-component-annotations-java libplexus-container-default-java
  libplexus-interpolation-java libplexus-sec-dispatcher-java libplexus-utils2-java libpolyglot-maven-java libqdox-java libreflectasm-java libreflectasm-java-doc librhino-java
  libservlet-api-java libsimple-http-java libsisu-inject-java libsisu-plexus-java libslf4j-java libwagon-file-java libwagon-http-java libwagon-provider-api-java libwebsocket-api-java
  libxbean-reflect-java libxerces2-java libxml-commons-external-java libxml-commons-resolver1.1-java libxpp3-java libxstream-java libxz-java libyaml-snake-java testng
Suggested packages:
  ant-doc javacc junit jython libactivation-java libcommons-net-java libmail-java libjaxp1.3-java libjdepend-java liblog4j1.2-java liboro-java libregexp-java libxalan2-java gradle-doc
  groovy-doc ivy-doc libjsch-agent-proxy-java libatinject-jsr330-api-java-doc libbcel-java-doc bsh rhino libcommons-collections3-java-doc libcommons-io-java-doc libcommons-lang-java-doc
  libcommons-lang3-java-doc libavalon-framework-java libcommons-logging-java-doc libexcalibur-logkit-java libmsv-java libxpp2-java libfelix-framework-java-doc
  libfelix-gogo-runtime-java-doc libfelix-osgi-obr-java-doc libgoogle-gson-java-doc libcglib-java libjdom1-java libxom-java libjcifs-java-doc libjcommander-java-doc libjcsp-java-doc jetty9
  libjsoup-java-doc libjsr305-java-doc libjanino-java libtomcat9-java libmaven-shared-utils-java-doc libnative-platform-java-doc libnekohtml-java-doc libosgi-annotation-java-doc
  libosgi-compendium-java-doc libosgi-core-java-doc libplexus-utils2-java-doc libpolyglot-maven-java-doc libqdox-java-doc libsimple-http-java-doc libxerces2-java-doc
  libxml-commons-resolver1.1-java-doc libcglib-nodep-java libjdom2-java libjettison-java libjoda-time-java
  ant ant-optional antlr bnd gradle groovy ivy java-wrappers junit4 libantlr-java libaopalliance-java libapache-pom-java libasm-java libatinject-jsr330-api-java libbcel-java libbcpg-java
0 upgraded, 121 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,613 kB/83.8 MB of archives.
After this operation, 123 MB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bookworm/main amd64 libguava-java all 31.1-1 [2,613 kB]
Ign:1 http://deb.debian.org/debian bookworm/main amd64 libguava-java all 31.1-1
Err:1 http://deb.debian.org/debian bookworm/main amd64 libguava-java all 31.1-1
If there is a way to run apt-get (apt) with detailed debug information, I can run it on Devuan box. For curiosity solely.
Other than that, thank you.
