#1 2025-03-10 18:20:00
semil
X11 recently failing to start the first time after boot
This is happening on my occasionally-used 32-bit x86 computer. It seems to have started with the X11 updates that came maybe a week ago.
I startx, and get xf86OpenConsole: Switching VT failed
and the Xorg log has xf86OpenConsole: VT_ACTIVATE failed: Bad file descriptor
Not a lot of detail.
The second startx has been succeeding.
#2 2025-03-11 10:40:54
Re: X11 recently failing to start the first time after boot
I can only offer a data point - it's not happening here running daedalus on asus EEE with 686-pae kernel, minimal lxqt with no display manager. Tested before and after latest upgrade which gave me xserver-xorg-core and xserver-common.
#3 2025-03-11 11:33:08
"before latest upgrade", "after latest upgrade" as well as "updates that came maybe a week ago" are all pretty lousy version identifiers.
#4 2025-03-11 15:45:01
Before:
2:21.1.7-3+deb12u8devuan1
After:
2:21.1.7-3+deb12u9devuan1
apt policy xserver-common  # same output for xserver-xorg-core
 *** 2:21.1.7-3+deb12u9devuan1 500
        500 http://deb.devuan.org/merged daedalus-security/main i386 Packages
        100 /var/lib/dpkg/status
     2:21.1.7-3+deb12u8devuan1 100
        100 http://deb.devuan.org/merged daedalus-proposed-updates/main i386 Packages
     2:21.1.7-3+deb12u7devuan1 500
        500 http://deb.devuan.org/merged daedalus/main i386 Packages
#5 2025-03-11 20:40:55
fsmithred wrote:
... daedalus on asus EEE with 686-pae kernel ...
An OT question, if I may: what Asus EEE model would that be?
I have been running my 1000HE (Intel N280 Atom / 2.0Gb) on Chimaera (5.10.0-0.deb10.16-686-pae) for a long while now and was wondering if it would make sense to move on to Daedalus.
#6 2025-03-12 00:14:44
1101HAB  Atom Z520 @1.33GHz  2G RAM and 128GB SSD
Daedalus and Excalibur work on it.
Every new release gets bigger.
#7 2025-03-12 01:21:12
I see.
Seashell (?), larger screen (?) than mine.
I've noticed that.
Like I wrote in another non-related thread:
altoid wrote:
Devuan Chimaera netinstall *.iso: 372.00 MB - UEFI installer: 00.754 MB
Devuan Daedalus netinstall *.iso: 477.80 MB - UEFI installer:  23.00  MB
30X more code has been added to the UEFI partition on the road between Chimaera and Daedalus.
Does anyone really know exactly what all that added code does?
I'll stay with Chimaera then, maybe go for a backported kernel if I can find a justification for doing so.
The hardware will certainly not change so at some point in the future it may well be a good idea to roll a custom kernel for it and leave it at that.
The 1000HE is the best piece of portable hardware I ever purchased (used in 2011).
Thanks for the data.
