Note that this is only intended for experienced users. Do not attempt otherwise.
Unhappy with the direction Xfce has been going since the 4.16 release (CSD and all), I've considered just going back to 4.12 (while staying on Daedalus), which I successfully pulled off by preferring Beowulf's repository for all my Xfce-related packages. The problem, however, is that some of them depend on GTK3 (as 4.12 has partial GTK3 support). What I then did was enable the archived repositories for Ascii and even Jessie, and I ensured that my Xfce would be completely unaffected if I decided to run sudo apt autoremove libgtk-3-0.
Another issue is that I had to use the Jessie versions of xfce4-terminal and xfce4-notifyd, as those were already depending on GTK3 as of Ascii. After successfully "downgrading" my packages accordingly, and seeing that Xfce has been purely GTK2-ized once more, I set a negative pinning on the packages to prevent them from being "upgraded". I only had to redo my Thunar configs (although I'm much happier just using SpaceFM as my file manager, even as a transparent overlay on my icon-less Xfce desktop) and set a script for my panel's CPU temperatures (with xfce4-genmon-plugin).
Going even further, I was able to get the GTK2 versions of GParted, GSmartControl, Meld, Gnumeric, Atril, Engrampa, FileZilla, Audacity, EasyTAG, Geany (although I mainly just use Leafpad), and AbiWord back, but some of those had to be done rather "dirtily" to get the results I sought (i.e. by enabling the archived repositories for Debian's Lenny, Squeeze, and Wheezy releases). It wasn't something I wanted to do, but I was able to resolve all dependencies rather carefully.
Maybe it's "Frankensteined" in a way, but I find the system just as functional as before (if not more so now), and I seldomly tinker with software nowadays. I simply wanted to get rid of GTK3 and its problems. Now, some programs I couldn't actually do that, namely with Firefox ESR, LibreWolf, Thunderbird (although I guess Sylpheed remains an option), Alacarte (because I like customizing my menus, and KDE's menu editor flat-out sucks), and Synaptic (which I keep around in case I don't feel like typing up command lines). I couldn't get the GTK2 version of NetworkManager's applet to install, so I'm using the Qt5 alternative in nm-tray.
Has anyone else tried this? I'd be curious as to a different solution from mine.
For me, I still have fully functional ISO's of pure Jessie that are all GTK2, archive repo is still available but I have everything I want already, the only program that needed a modern version to work properly was the browser, so I use an appimage of FF. No frankensteining needed. ![]()
Devuan 5 mate-mini iso, pure Devuan, 100% no-vuu-do.
Devuan 6 version also available for testing.
That's pretty cool.
For a worthy RSS feed reader, I recommend using the last GTK2 version of Liferea, which is 1.8.7, but the last one Debian packaged is 1.8.6. The dependencies should be resolvable if using the standalone DEB from sometime in 2012 (the current Debian stable release at that time was Squeeze, but Wheezy was a year away from the testing freeze).
Anyway, Liferea is great, and it has some cool features, like managing different categories for your feeds, opening an item within the program (in a new tab, as if it were a browser), minimizing to a tray icon with notifications and total new feeds, and setting up proxy connections and what to use to download file enclosures (e.g. Mpv for videos, Leafpad for text files). It's a great tool that's still useful to this day.
Thanks to Liferea's exceeding pros, I no longer have a use for Newsboat, which was already freezing up at random and has Rust stains in its code...
referencing RSS Feed Readers, please go to https://rachelbythebay.com/w/ and do a page search for "feed reader" since she has done a fairly exhaustive review over the course of 22 commentaries.
Do the happy dance! I finally got rid of Thunderbird as my e-mail client, thanks to the versatility of Claws Mail (last GTK2 version being 3.17.8). Much like SpaceFM, it's very customizable, and you get a lot of handy plugins for security and encryption. I recommend this guide to hardening your Claws Mail profile(s). Claws Mail's official wiki can also be a good resource on setting things up. Surprisingly, the ArchWiki does not have a page on Claws Mail (they usually do).
Interestingly, Ardour (a DAW similar to Audacity, but far more advanced with customization features) will remain GTK2-only software (thus no Wayland support) for the foreseeable future. See this post in a Phoronix thread where the original poster cries about it "still" being on GTK2. This one is the most important, which I shall quote below:
From a project-level perspective, perhaps the most important change is that we have moved the source code of our GUI toolkit (GTK v2) into the Ardour source tree. This has no impact whatsoever on people using the builds provided at ardour.org 2.
However, this version of GTK is about to be deprecated by a number of Linux distributions, and without this change it will become more difficult for both individual users and Linux package maintainers to continue building Ardour. This also leaves us free to (slowly) strip down aspects of the toolkit that we do not use, and potentially modify it as needed in the future. It also means that even the distribution builds of Ardour for Linux will contain our patches to GTK, which has historically not been the case.
Q: "Does this mean native Wayland support will come in the future?"
A: No plans for Wayland support. Doing the work will get our users nothing, more or less.Q: "No plans to update to a newer GTK version?"
A: "No plans to ever move to a newer version of GTK. That work will get our users very little, and so the cost/benefit analysis says “nope”."
Nice work. I don't know if it's worth all the effort, but it is pretty cool.
Thanks for the info about Ardour. Ardour is a must for a FOSS studio environment. Migrating to another solution is not a simple chore, and would most likely require non-free software to achieve the same feature set. Aurdour, KiCad, and I'm sure there are others are great examples of why X11 (or Xlibre) are still necessarily. Not to mention all the apps that work under Wayland but are crippled. I'm not bashing Wayland here. I'm just pointing out the obvious truth that so many wish to intentionally ignore.
I guess studio focused distros will have to ship with X11 (Xlibre) if they are serious.
Harrison MixBus a fork of Aurdour. So I assume it also does not support Wayland
Has anyone managed to build spacefm or debianize spacefm for Excalibur yet? Upstream Debian did something shady and replaced the spacefm package with gtk3 whereas previously spacefm was gtk2 (congruent with upstream spacefm's recommendations) and there was a seperate packge spacefm-gtk3 if you wanted that. This was done by the "debian gnome team".
Unfortunately building spacefm yourself on Excalibur isn't so easy. There's some things that needs to be patched in the source code. Also using the gtk3 version isn't usable because of constant segfaults, clipboard not working, gtk3 breakage and mess.
Secondly claws-mail maintains a separate gtk2 branch. I've managed to compile that and use it with upstream Debian made claws-mail gtk3 even though it's a separate branch. This is working and continues to work after the upgrade but compiling and installing from source leaves it out from apt's package management. There's now been some minor updates to the gtk2 branch of claws-mail I'd like to install but it's not so easy tracking claws-mail releases anymore.
Surely someone has done this work before? I don't want to rebuild and repackage these things if somebody else has already done that.
Maybe I'm missing something here but IMHO the Devuan devs have done a great job in configuring Excalibur to by default remove CSD and the autohiding scrollbars from GTK3, therefore I don't see any need for myself to avoid GTK3.
All the GTK3 apps look normal (no CSD, no other Gnome style weirdness) to me in XFCE on Excalibur.
Or are there other issues related to GTK3 that I'm not aware of?
You may test GTK3 with WhiteSur GTK Dark Theme:
_https://dev1galaxy.org/viewtopic.php?id=7224
You could simply pin or hold the version of SpaceFM that you installed from Daedalus, which is still GTK2. As it hasn't had any upstream changes since early 2018, it's safe to say the package hasn't implemented any new features or critical bug fixes over time. The last significant thing I remember being that the thumbnail issue was fixed. You could just wait a short while when launching it or disable thumbnails altogether. It's still way faster than Thunar.
Also, the last version of Claws Mail that you can build with GTK2 is the 3.x.x series. The last Debian build of it in that is 3.18.0-1. As of 4.x.x, you must use GTK3 or newer. It will complain if your version of GTK is "outdated".
Spacefm Bookworm/Daedalus just works.
Spacefm Trixie/Excalibur has a segfault where if I press the left alt button a few times it segfaults with glib errors.
So say if i use alt tab to change windows a few time with spacefm, boom segfault.
https://codeberg.org/Matlib/SpaceFM/src/branch/next
branch next
Download links are under the ellipsis button on the right side.
./configure --with-gtk2 --prefix=/usr/local/spacefm --disable-video-thumbnails --sysconfdir=/usr/local/spacefm/etc
make
make installVideo thumbnails need some extra libs. I disabled because I don't need that.
Also GIMP 2.10:
https://codeberg.org/Matlib/gimp2
Launch autogen.sh and follow instructions. I built it agains latest GEGL, but the one from packages should be fine too.
