#1 2025-02-25 11:47:50
digifuzzy
[SOLVED] menu-config utility reference
Got an arm64 image installed on an RPi4 successfully.
On first boot, system message indicated to user to execute menu-config.
I am unable to find a reference to this utility. A web search is unhelpful as search engines, with their overzealous AI, wants to split the words despite explicit search parameters. Searches want to return results related to menu configuration not a specific executable.
Can someone point to documentation or repository where source is hosted?
#2 2025-02-25 14:06:42
Re: [SOLVED] menu-config utility reference
Can't find docs, but when you run it, it allows you to set up your keyboard & country, etc.
#3 2025-02-25 15:39:56
c0rnelius
There are no docs for it. It was quickly put together so people with limited knowledge could set some basic defaults.
https://github.com/pyavitz/rpi-img-buil … menuconfig
