#1 2025-02-08 22:22:51
recklessswing
Devuan won't recognize Windows 10 UEFI install
Debian 12 had no problem doing that. Only Devuan. How to fix this? I mount that EFI partition too, see if it helps. No, os-prober is on.
#2 2025-04-14 09:12:07
Re: Devuan won't recognize Windows 10 UEFI install
probably need some kind of raid functionality.
#3 2025-04-14 09:51:52
i don't think there is any difference in the involved packages and procedures.
is the linux installation also an uefi install? if not, it won't work.
anyhow, i only use the boot override key to select the system to be booted on my uefi pcs. my linux systems are encrypted, and osprober does not find encryted systems.
