So, I'm trying to find Atheros wlan mini pci-e card for my dell precision m4500 and some have
also newer bluetooth included.
The laptop has deticated bluetooth module at not so nice place to remove..
What do you think what kind of problems would double bluetooth cause? Or do I just have to try find a card
without bluetooth or remove the deticated bluetooth module first?
I have not yet tried if the old bluetooth module works or not, but maybe try it inside few days.
It would be nice to update the bluetooth with the card also to try to get ldac/aptx support..
Any toughts? Does anyone have same situation with their laptops?
I would assume it is not very easy to get the oem bluetooth module to work with linux, but will try to install the needed
software in few days and see if it is recoqnized.
