#1 2025-01-11 18:39:50
cade
XBell (beep) muted or disabled on Xorg (daedalus)
hello!
today I upgraded my chimaera machine to the latest daedalus.
for my surprise, audible beep in Xorg via the pc speaker was muted or disabled somehow,
so bash will not alert in my rxvt, neither xterm nor gnome-terminal. even Firefox does
not beep on failed Ctrl+F search, f.e.
I tried everything:
xset b
xinput set bell-style audible
checked /dev/input links (seem correct)
pcspkr kernel module is loaded
xkbbell
xkbevd to check if XkbBellNotify fires (it fires but nothing audible)
apt purged pulseaudio and pipewire to avoid notification capture
strangely, beep works in text mode consoles (i.e. before running Xorg...)
has anyone noticed this? it is pretty annoying if you got used to beeps smile
I'd appreciate any ideas what to check next or how to fix this?
UPDATE: looks like using DM enables the beep (slim,xdm,lightdm...) but when not using one, just startx, it disappears...
thank you and have a great new year!
Vladi.
#2 2025-01-11 19:28:33
Re: XBell (beep) muted or disabled on Xorg (daedalus)
Well I guess every DE is different and I don't know what you're using, but currently in my Mate install of daedalus, it's in the menu.
system>>preferences>>hardware>>sound, and the GUI that pops up has a little checkbox at the bottom for enabling system sounds.
#3 2025-01-11 20:13:55
RedGreen925
hello!
Distributions have taken to black listing the pcspkr module as it some kind of inconvenience to be alerted to potential problems, the noise offends their sensibilites.
To get your beep in the console back.
https://askubuntu.com/questions/19906/beep-in-shell-script-not-working
edit the /etc/modprobe.d/blacklist.conf and comment out the black listing of
the pcspkr module.
# ugly and loud noise, getting on everyone's nerves; this should be done by a
# nice pulseaudio bing (Ubuntu: #77010)
blacklist pcspkr
Put a # in front of the blacklist pcspkr and on next boot the module should load. A modprobe pcspkr as root or using sudo in front should load it and have it available without the reboot.
#4 2025-01-11 20:28:31
"system sounds" are not the same as the dedicated PC speaker bell.
@cade: We are talking about the old-school hardware PC speaker, not some soundcard emulation, right?
Is the pcspkr module loaded, and does 'beep' work? Do you have an appropriate evdev link (i.e. /dev/input/by-path/platform-pcspkr-event-spkr)?
You're not the first to ask after this here, see this thread.
#5 2025-01-11 20:44:27
cade
@steve_v: yes, good plain pc speaker. nothing to do with soundcard, which I keep muted on the amp usually.
* yes, I have proper link in /dev
* also set bell-style audible in xinput
* pcspkr is loaded, tried to unload/load even without effect
but! console (text mode) beep works!
also 'beep' command in rxvt terminal beeps but I think this has nothing to do with X bell notify event (i.e. gui apps and terms)
I will check the thread you linked, thanks! I also suspect the bell handling is routed through the sound subsystem somewhere or muted, but still have no much progress of alsa/pulse/etc. digging...
I even had brief look at X sources... but this will be last resort smile)
thanks!
#6 2025-01-11 21:39:06
cade
@RedGreen925: sorry, forgot to mention that I already checked that and console (text mode) beep works fine. just X ignores the bell events, well, at least audible...
@greenjeans: I don't use any DE, just X with window manager (icewm), so the problem is somewhere in the Xorg, not in apps (DEs). I even did try to run clean X without my xinitrc configuration (which is a lot) and still no beeps...
pretty strange, it worked fine for the last 25 years smile
#7 2025-01-11 21:48:43
Each terminal emulator has its own code to handle keyboard input and character output/display. Some of them have configurable properties to "re-enable" audible bell and some don't.
#8 2025-01-11 21:59:56
cade
@ralph.ronnquist: it is not terminal problem, they properly send XBell notifications, I can see them in xkbevd. I did check rxvt, xterm and gnome-terminal. The problem still exists and with X gui apps like Firefox, it beeps when you search for something which is not found on the current page... i.e. not beeping in my case smile
#9 2025-01-11 22:32:58
Yes, you're right. The XkbBellNotify event is generated but nothing handles it to make the noise.
#10 2025-01-12 04:42:35
I looked into this a bit and found a fair few ducks to line up before it worked both in console and Xorg.
For bell sound by the "xkbbell" command I needed to
  • add a special "InputClass" configuration snippet that tells Xorg to use the "kbd" module (from xserver-xorg-input-kbd) for the "PC Speaker" device;
  • configure Xorg to bell with 50% volume rather than 0%, and
  • enable loopback for the sound card.
My special configuration snippet /etc/X11/xorg.conf.d/pcspkeaker.conf is
Section "InputClass"
	Identifier  "PC Speaker"
	MatchProduct "PC Speaker"
	Driver      "kbd"
EndSection
You can use the "lsinput" command (from input-utils) to verify the name (i.e. the MatchProduct string) of the device. You also need to restart Xorg for loading the snippet.
The Xorg bell volume would be raised with an "xset" xommand:
# xset b 50
Loopback enabling might also be a command:
$ amixer sset 'Loopback Mixing' Enabled
though the actuals of that does depend on the soundcard; use a plain "amixer" command and guess from that.
I also needed that loopback enabling to hear a console bell.
#11 2025-01-12 09:26:05
cade
hi ralph and thanks for looking into this!
I tried your suggestion but it didn't work hmm
also I think pc speaker should not be handled by kbd driver (which also strangely was not installed here "xserver-xorg-input-kbd", not sure if was upgrade glitch) because it ruined my keyboard mapping, all arrows/pgup/dn keys appear entirely different (not the keymap).
removed the driver line from xorg.conf and restarted, now I have this:
[  1385.287] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[  1385.287] (**) PC Speaker: Applying InputClass "PC Speaker"
[  1385.287] (II) No input driver specified, ignoring this device.
I also have 3 sound cards, one on the mb, which has loopback mixing, one usb audigy, which has only master vol and a strange hdmi interface.
I managed to set amixer -c2 sset 'Loopback Mixing' Enabled and xset b 50 but still no success sad
installed back pulseaudio and pipewire if they handle somewhere something but nothing happens.
a whole lot of ducks and few monsters around smile
I believe it should be evdev problem, beep command says
$ beep --verbose
beep: Verbose: evdev driver_detect 0x55e45ecdb700 (nil)
beep: Verbose: b-lib: opened /dev/input/by-path/platform-pcspkr-event-spkr as 3
beep: Verbose: beep: using driver 0x55e45ecdb700 (name=evdev, fd=3, dev=/dev/input/by-path/platform-pcspkr-event-spkr)
beep: Verbose: 1 times 200 ms beeps (100 ms delay between, 0 ms delay after) @ 440 Hz
beep: Verbose: evdev driver_begin_tone 0x55e45ecdb700 440
beep: Verbose: evdev driver_end_tone 0x55e45ecdb700
beep: Verbose: evdev driver_fini 0x55e45ecdb700
and it works. but maybe X does not use the same interface? I don't know how to debug evdev/eudev channels...
I wasted nearly day and a half already so I'm thinking to get fresh install on separate machine (I have lenovo tiny around) so I can see if it is install or upgrade glitch (or both).
thanks again!
#12 2025-01-12 11:07:01
However wrong it is, the PC Speaker appears as an input device and is handled by the kbd module, or more specifically, Xorg looks for a keyboard device that handles bell. I think the idea is that the XBell event is actually like a KeyPress event and should be handled along the keyboard event handling path.
In any case, the kbd module is the only device handler for "bell" I've been able to find. You could also try the "evdev" module as driver. Xorg doesn't really care, but "libinput" doesn't recognise the "PC Speaker" device, so no driver gets installed.
I'm not sure how that could affect the "real" keyboard handling. The short of it is that Xorg has to install a driver for that device in order to use it.
The device, /dev/inputevent7 for you, is linked up by udev as /dev/input/by-path/platform-pcspkr-event-spkr (which you will find is a symbolic link to ../event7), and that's thus the same destination character device. But the missing link is for Xorg to install a (keyboard) driver that would have interest in the bell event(s).
EDIT: actually if you could share your Xorg.0.log with me, e.g. upload it to https://transfer.rrq.au so I could havea glance and maybe get some inspiration.... Xorg.0.log is found in either /var/log/ (if Xorg is run as root) or in ~/.local/share/xorg/ if Xorg is run by non-root user). Or email it to me.
#13 2025-01-12 11:49:46
cade
yes, kbd driver seems to be proper way since, afaik, the bell/buzzer was initially attached to the physical keyboards back then. I will try again with kbd but keys mapping goes crazy.
platform-pcspkr-event-spkr symlink is correct, I checked permissions, groups, etc. all looks fine...
I'll send you the log, thanks!
#14 2025-01-12 17:17:55
cade
aaah &*#%... fresh install works fine. it is upgrade glitch sad
#15 2025-01-13 08:24:01
thanks for letting thread visitors know that this was another "upgrade versus fresh-install" conundrum.
while i humbly and respectfully acknowledge that not _everyone_ is able to do a fresh-install(whether from lacking hardware and/or skills and/or willingness), nevertheless a fresh install is by far best.
should this be a poem or haiku?
#16 2025-01-13 12:35:04
cade
@stargate-sg1-cheyenne-mtn: you are right, you should stick to haiku. smile
#17 2025-01-13 12:38:06
cade
and I was wrong, fresh install doesn't help.
however DM enables the beep for some reason, but I'm not using one.
still chimaera works fine so there must be some kind of difference in firing the X session...
