#1 2025-01-02 04:28:31
mtbvfr
[SOLVED] Graphical User Manager app?
Hi Folks,
MX Linux has a User Manager app as part of its MX Tools suite.
Is there something similar I can install for Simpleton Users that aren't au fait with computers like we are?
Thanks!!
#2 2025-01-02 06:24:40
brocashelm
Re: [SOLVED] Graphical User Manager app?
If you're using GTK, then GNOME's Users and Groups (gnome-system-tools) or MATE User Admin (mate-user-admin) can certainly work with that. KDE Plasma and LXQt also have their own graphical user manager tools, if I'm not mistaken.
#3 2025-01-02 09:09:08
mtbvfr
brocashelm wrote:
If you're using GTK
Thanks! I installed gnome-system-tools as mate-user-admin would have wanted to install the mate desktop too.
Now I need an applet for Screen Brightness that uses xrandr.
