#1 2024-12-21 21:19:02
francesco
[SOLVED] Which runlevel for umountfs and umountroot (via sysv-rc-conf)?
Hello everybody, i'll get straigth to the point: i need umountfs and umountroot unmounting the filesystem at shutdown and reboot, so i've setted them both on 0 and 6, but it doesn't work, since at every boot the system recovers the journal. Please can someone help me? Many thanks!
#2 2024-12-21 21:50:16
Re: [SOLVED] Which runlevel for umountfs and umountroot (via sysv-rc-conf)?
Hi, Not sure if this will help, but on my open-rc system both of those files have no start and stop is 0 and 6
/etc/init.d/umountroot
#! /bin/sh
### BEGIN INIT INFO
# Provides:          umountroot
# Required-Start:
# Required-Stop:
# Should-Stop:       halt reboot kexec
# Default-Start:
# Default-Stop:      0 6
# Short-Description: Mount the root and /usr filesystems read-only.
### END INIT INFO
---snip---
added /etc/init.d/umountnfs.sh
#! /bin/sh
### BEGIN INIT INFO
# Provides:          umountnfs
# Required-Start:
# Required-Stop:     umountfs
# Should-Stop:       $network $portmap nfs-common
# Default-Start:
# Default-Stop:      0 6
# Short-Description: Unmount all network filesystems except the root fs.
# Description:       Also unmounts all virtual filesystems (proc,
#                    devpts, usbfs, sysfs) that are not mounted at the
#                    top level.
### END INIT INFO
I added the header for the files because they have different deps... (should stop)
#3 2024-12-22 11:39:56
francesco
Hello again, i've setted 0 and 6 on "Default-Stop" but i still doesn't unmount the filesystems:
#! /bin/sh
### BEGIN INIT INFO
# Provides:          umountfs
# Required-Start:
# Required-Stop:     umountroot
# Default-Start:        0 6
# Default-Stop:
# Short-Description: Turn off swap and unmount all local file systems.
# Description:
### END INIT INFO
#! /bin/sh
### BEGIN INIT INFO
# Required-Start:
# Required-Stop:
# Default-Stop:
### END INIT INFO
#! /bin/sh
### BEGIN INIT INFO
# Required-Start:
# Default-Stop:
#                    top level.
### END INIT INFO
#4 2024-12-22 11:40:30
francesco
Sorry, i meant "Default-Start".
#5 2024-12-23 21:51:22
francesco
Sorry again, i've just messed up the whole matter. To put it simply: umountfs and umountroot don't unmount filesystems at shutdown/reboot (therefore resulting in a filesystem recovering at each boot - so if i want to avoid recovering i have to switch to runlevel 1 and unmount filesystems read-only before shutdown/reboot every time [all done via sysrq] -): i've setted these services in runlevels 2,3,4,5 without success (no unmounting at all); then i've tried runlevels 0,6 and still nothing. I've also tries runlevel S and again all runlevels (both services setted on 1,2,3,4,5,0,6 and S). Still nothing.
#6 2024-12-23 22:20:41
For reference, here's what mine look like (using sysvinit). I think they look the same as what GlennW posted, except I put the files in alphabetical order.
Note that it uses Default-Stop, not Default-Start.
#! /bin/sh
### BEGIN INIT INFO
# Required-Start:
# Default-Start:
# Default-Stop:      0 6
# Description:
### END INIT INFO
#! /bin/sh
### BEGIN INIT INFO
# Required-Start:
# Required-Stop:
# Default-Start:
# Default-Stop:      0 6
### END INIT INFO
#7 2025-02-22 13:18:26
francesco
Hello again, i edited umountfs script (same as for umountnfs.sh and umountroot):
#! /bin/sh
### BEGIN INIT INFO
# Required-Start:
# Default-Start:     2 3 4 5
# Default-Stop:      S s 1 0 6
# Description:
### END INIT INFO
And still nothing (filesystems won't unmount); so i installed runit, runit-helper, runit-run and runit-services in order to have runit integrated in sysv (maybe it's useless in this case, but i'll give it a try). So i read the instructions on smarden.org (https://smarden.org/runit/useinit#sysv), which say to add runsvdir-start; so i edited /etc/inittab:
#runit-sysv maintscript -- BEGIN
SV:123456:respawn:/sbin/runsvdir-start
#runit-sysv maintscript -- END
But: i couldn't find runsvdir-start in /sbin, nor in /usr/bin, /bin and /usr/sbin... Has the file been removed from runit's package?
#8 2025-02-22 14:55:55
Note that the scripts don't do anything at start, so your "# Default-Start:  2 3 4 5" are without effects.
Also, umountroot doesn't actually unmount the root filesystem, but it remounts the filesytem root as read-only, and that should be enough to usually avoid fsck on boot-up.
And, I'm sure you wouldn't want unmounting to be done upon "S s 1", and you should restore the normal "# Default-Stop: 0 6".
It appears you are using runit rather than sysvinit? If that's the case I wonder if you have set up it's start/stop configuration to execute those scripts? I believe it's done differently from the sysvinit setup although many sysvinit scripts may be used with runit.
#9 2025-09-13 18:02:41
francesco
Hello, only now i can rejoin the forum. I've installed OpenRc (therefore i removed sysvinit) - keeping runit as process supervisor -: now everything works well, including filesystems unmounting.
