#1 2024-12-20 12:08:55
SpongeBOB
How recompile Kernel ? ( fresh install )
I need to recompile my Kernel in order to activate some missing options...
I've tried few way but failed...
It can be done on a freshly install Devuan 5 Daedalus.
Thanks.
#2 2024-12-20 14:56:09
Re: How recompile Kernel ? ( fresh install )
Same as you would on Debian.
OTOH, compiling a kernel is much the same on any distro and hasn't changed significantly in decades, the only real difference here is using the debian specific make targets (included in linux-source-[version]) to build .deb packages rather than manually installing the image/modules.
And if you also fail to elaborate, nobody will know why.
#3 2024-12-20 15:04:09
SpongeBOB
Thank you Steve_v ! for the links
I didn't want to create a big post smile
But If I fail following the links you give, for sure I'll share what I'm facing smile
#4 2024-12-20 16:28:19
SpongeBOB
ok compiling now...
I've used make bindeb-pkg
Does someone already tried with -j$(nproc) ?
in full: make bindeb-pkg -j$(nproc)
it's should be faster, but might be prone to error ? did you already tried ?
in the section 4.4 Out-of-tree kernel modules of Debian Linux Kernel Handbook
Should I do it ?
If I understand well the document is either 4.4.1 or 4.4.2 method , right ?
#5 2024-12-20 22:23:03
man make
#6 2024-12-22 06:44:19
SpongeBOB
Thank you Steve_v the man don't about risks/error with -j , damn if I knew I will have run it with it smile
I'm still wondering for the
Should I do it ?
#7 2024-12-22 08:47:48
Indeed, because that option simply specifies the number of parallel jobs to run. The only "error" possible is that the build fails because things are compiled out-of-order (which means upstream needs to fix their makefile / build process), and the only "risk" is wasting time and trying again with those options omitted.
To put it another way: The function of '-j' and friends is not complicated, and I have no idea why anyone would need handholding over such an option. Try it and find out, like everyone else.
The choice is whether to use DKMS or module-assistant... That choice is up to you.
