#1 2024-12-13 01:14:58
delvasto1
[SOLVED] Firmware update for AMD GPU certificate error ?? or old source.list
[root@mimas apt]# apt search amd-graphics
Sorting... Done
Full Text Search... Done
firmware-amd-graphics/stable 20230210-5 all
  Binary firmware for AMD/ATI graphics chips
[root@mimas apt]# apt update
Ign:1 https://deb.devuan.org/merged daedalus InRelease
Ign:2 https://deb.devuan.org/merged daedalus-updates InRelease
Ign:3 https://deb.devuan.org/merged daedalus-security InRelease
Err:1 https://deb.devuan.org/merged daedalus InRelease
  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 198.58.118.8 443]
Err:2 https://deb.devuan.org/merged daedalus-updates InRelease
Err:3 https://deb.devuan.org/merged daedalus-security InRelease
345 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: Failed to fetch https://deb.devuan.org/merged/dists/daedalus/InRelease  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 198.58.118.8 443]
W: Failed to fetch https://deb.devuan.org/merged/dists/dae … /InRelease  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 198.58.118.8 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
[root@mimas apt]# apt info amd-graphics
N: Unable to locate package amd-graphics
E: No packages found
[root@mimas apt]# apt install firmware-amd-graphics/stable
Selected version '20230210-5' (Devuan:5.0/stable [all]) for 'firmware-amd-graphics'
0 upgraded, 1 newly installed, 0 to remove and 345 not upgraded.
Need to get 11.9 MB of archives.
After this operation, 82.6 MB of additional disk space will be used.
Ign:1 https://deb.devuan.org/merged daedalus/non-free-firmware amd64 firmware-amd-graphics all 20230210-5
Err:1 https://deb.devuan.org/merged daedalus/non-free-firmware amd64 firmware-amd-graphics all 20230210-5
  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 23.169.200.138 443]
E: Failed to fetch https://deb.devuan.org/merged/pool/DEBI … -5_all.deb  Certificate verification failed: The certificate is NOT trusted. The name in the certificate does not match the expected.  Could not handshake: Error in the certificate verification. [IP: 23.169.200.138 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
#2 2024-12-13 01:25:33
Re: [SOLVED] Firmware update for AMD GPU certificate error ?? or old source.list
This may be one of the DNS errors some folks are experiencing.
I'm having the same DNS problem, so my current sources.list that works is:
deb http://gnlug.org/pub/devuan/merged daedalus main contrib non-free non-free-firmware
deb http://gnlug.org/pub/devuan/merged daedalus-updates main
deb http://gnlug.org/pub/devuan/merged daedalus-security main
I used this to download/install the very AMD firmware you mentioned.
Hope this helps!
#3 2024-12-13 02:00:09
delvasto1
the source list worked, I just changed to https:
#4 2024-12-13 02:23:17
then just change it back to http.
btw there are "code" tags to use for enclosing log text.
