#1 2024-12-06 07:44:09
SpongeBOB
Booting on USB on Raspberry pi 4
I'm using RPI 4, daedalus 6.1.93 arm64, 2024-11-26 img on my Raspberry pi 4.
Now, I try to boot on a USB dongle... but it keep booting on the SD card....
Any advice ?
Thanks.
#2 2024-12-06 08:58:35
FM81
Re: Booting on USB on Raspberry pi 4
Which bootorder ist defined in the EEPROM of the raspberry?
If USB is at position 2 or 3, it would be enough simply to remove the SD-card.
Otherwise you need to change it first.
Best regards, FM_81
The most brilliant role in comedy is that of a fool, he must not be in order to make it seem. (Miguel de Cervantes)
#3 2024-12-06 09:08:54
searching DDG shows multiple results using "raspberry pi 4 usb booting"(quotation marks only added for forum clarity, not used for the search)
#4 2024-12-06 09:32:59
Remove the sd card & it should boot from USB, (pendrive or HDD/SSD), otherwise you need to change the boot order....
https://www.raspberrystreet.com/learn/h … om-usb-ssd
#5 2025-10-30 13:52:08
Gnostic
This is probably too late for @SpongeBob, but might be useful for someone in future.
I used
sudo rpi-eeprom-config --edit
To boot usb first followed by nvme:
BOOT_ORDER=0xf461
To boot nvme first
BOOT_ORDER=0xf416
Also useful in the same config, to reduce power consumption when the Pi is shutdown but still plugged into the power supply:
POWER_OFF_ON_HALT=1
See
https://www.jeffgeerling.com/blog/2023/ … ption-140x
