#1 2017-06-11 13:04:30
spartrekus
How to change the Hostname in DEVUAN ?
Hello,
Probably the method echo "mynewpcname" > /etc/hostname with after a reboot, is not the official one wink
thank you
#2 2017-06-11 19:27:27
Re: How to change the Hostname in DEVUAN ?
spartrekus wrote:
Hello,
thank you
well that's how I do it, it actually says in the man page for hostname, that editing etc/hostname is the only way of permanently changing it.
#3 2017-06-11 20:13:57
Change it permanently:
(or open it in your favorite root editor)
Change it now:
hostname mynewpcname
Then log out and log in again. No need to reboot.
And if the old name is in /etc/hosts, change it there, too.
#4 2017-06-18 17:13:50
spartrekus
Change it now:
I do this way too wink thanks for confirming me....
However on a PI III B, the above method does not work.
About Hostname: SystemD is ugly, isn't it??
Plus, So, it means the following:  This page would need a small update.
https://wiki.debian.org/HowTo/ChangeHostname
