#1 2024-11-20 11:16:50
pequi
Lazarus weird after update
Updated Lazarus though synaptic from v 3.0 to v 3.6. Said it was upgrading. When it was done I removed Lazarus 3.0(usually done automatically, but I had to do it manually).
Lazarus 3.6 is working perfectly.
The problem is I keep getting nagged to remove Lazarus:
apt-get upgrade
Calculating upgrade... Done
  lazarus-ide lazarus-ide-3.6 lazarus-ide-gtk2-3.6 lazarus-src-3.6 lcl-3.6
  lcl-gtk2-3.6 lcl-nogui-3.6 lcl-units-3.6 lcl-utils-3.6
Use 'apt autoremove' to remove them.
"no longer required"? What's this , AI deciding what I do or don't require? LOL
Seriously, how do I get rid of that message? I've tried uninstalling and re-installing, message is the same.
PS I don't want to lose Lazarus configuration files.
TIA
#2 2024-11-20 15:33:24
Re: Lazarus weird after update
#3 2024-11-21 10:11:29
pequi
Something wrong with the package
apt remove --purge --autoremove lazarus-ide
  lazarus-ide* lazarus-ide-3.6* lazarus-ide-gtk2-3.6* lazarus-src-3.6*
  lcl-3.6* lcl-gtk2-3.6* lcl-nogui-3.6* lcl-units-3.6* lcl-utils-3.6*
0 upgraded, 0 newly installed, 9 to remove and 0 not upgraded.
After this operation, 710 MB disk space will be freed.
apt-get install lazarus-ide
  lazarus-ide-2.2 lazarus-ide-gtk2-2.2 lazarus-src-2.2 lcl-2.2 lcl-gtk2-2.2
  lcl-nogui-2.2 lcl-units-2.2 lcl-utils-2.2
  lazarus-ide lazarus-ide-2.2 lazarus-ide-gtk2-2.2 lazarus-src-2.2 lcl-2.2
  lcl-gtk2-2.2 lcl-nogui-2.2 lcl-units-2.2 lcl-utils-2.2
0 upgraded, 9 newly installed, 0 to remove and 0 not upgraded.
Need to get 10.6 MB/83.7 MB of archives.
After this operation, 666 MB of additional disk space will be used.
Do you want to continue? [Y/n] n
Abort.
I have synaptic configured to install the latest version. Yet it chose an old, obsolete version of Lazarus.
I had to force it to install v 3.6
apt-get install lazarus-ide-3.6
Which did not install the main files. Just non functional icons and menus.
apt-get install lazarus-ide-gtk2-3.6
  lazarus-src-3.6 lcl-3.6 lcl-gtk2-3.6 lcl-nogui-3.6 lcl-units-3.6
  lcl-utils-3.6
  lazarus-ide-gtk2-3.6 lazarus-src-3.6 lcl-3.6 lcl-gtk2-3.6 lcl-nogui-3.6
Which fixed the problem...
Don't know if I should mark it "solved". Anyone attempting to upgrade Lazarus to the latest version will have the same problem.
Anyways, thanks for the help.
I was uninstalling/re-installing it through synaptic, not the command line. Which gave me the error in the first message.
#4 2024-11-21 11:41:19
currently using Daedalus. when i search synaptic using just the "name" matching i get about a dozen search results. one of them is "lazarus-ide-gtk2-2.2 IDE for Free Pascal - GTK+ version" and as you described, it says "latest available version is  2.2.6+dfsg2-2"
there is also a Qt5 version which may explain why your "apt-get install lazarus-ide-3.6" didn't quite get the job done.
thanks for keeping us posted!
#5 2024-11-21 13:52:24
Checked on my Daedalus with backports enabled. Synaptic shows version 2.2 from the standard repo, and 3.0 from backports as available. Nothing about 3.6.
The metapackage lazarus-2.2 re. lazarus-3.0 should install the complete suite.
To get hold of version 3.6 you must have added an external repo. What exactly did you do regarding this "trick" to synaptic?
#6 2024-11-21 15:31:41
Checked under Excalibur: there version 3.6 is available.
You are mixing stable and testing. I would call this idea at least challenging, its no good idea if you do not know exactly what you are doing.
#7 2024-11-21 19:59:41
Assuming daedalus with backports:
# apt install  -t daedalus-backports  lazarus-ide
should have done the trick.
#8 2024-11-26 10:35:48
pequi
deb http://deb.devuan.org/merged/ daedalus main
deb http://deb.devuan.org/merged/ daedalus-updates main
deb http://deb.devuan.org/merged/ daedalus-security main
deb http://deb.devuan.org/merged/ daedalus-backports main
deb http://deb.devuan.org/merged/ daedalus non-free
deb http://deb.devuan.org/merged/ daedalus non-free-firmware
deb http://deb.devuan.org/merged/ daedalus contrib
So yes, I use backports. Not marking this as "solved" because package is broken. Synaptic marked Lazarus 3.6 as an "available upgrade", I clicked OK and instead it installed v3.6 and kept v3.0, so effectively I had two versions installed. And when I uninstalled both, and tried to reinstall Lazarus, it installed v2.2.
Under preferences I have "install latest version".
