#1 2024-11-17 15:22:11
vrgovinda
Waydroid on Daedalus
I'm trying to install Waydroid on my machine running Daedalus.
I get the following message.
~$ curl -s https://repo.waydro.id | sudo bash
[!] Distribution ""daedalus"" is not supported
Is there any workaround?
Thanks!!
know who you are and be who you are.
#2 2024-11-17 15:39:37
Re: Waydroid on Daedalus
Try bookworm instead. You may need to download the file directly, not using curl.
#3 2024-11-18 13:14:00
mostly for future thread visitors:
https://docs.waydro.id/usage/install-on-desktops
#4 2025-01-14 10:23:06
SpongeBOB
Hey,
I would like too, to make run waydroid on devuan.
I see waydroid required wayland, so it seem the only supproted Window environment is KDE Plasma. (devuan) right ?
Then we need to apt install so first adding their repo
like this ?
/etc/apt/sources.list
deb http://deb.devuan.org/merged daedalus          main
deb http://deb.devuan.org/merged daedalus-updates  main
deb http://deb.devuan.org/merged daedalus-security main
deb https://repo.waydro.id bookworm main
