#1 2024-11-14 23:03:14
Ron
Clearing the DNS cache
So I wanted to clear my DNS cache and did a search for how to do it. So I found to run either:
sudo /etc/init.d/networking restart or sudo service networking restart (from here). When I ran them (I ran both) I got a message that it was deprecated. The exact message on both was:
Running /etc/init.d/networking restart is deprecated because it may not re-enable some interfaces ... (warning).
Reconfiguring network interfaces...done.
So I have two questions: 1) Did one, or both, of these commands work or not? 2) Is there a better way to clear the DNS cache?
#2 2024-11-15 09:41:42
Re: Clearing the DNS cache
check /etc/resolv.conf for clues
cat /etc/resolv.conf
check NetworkManager settings
sudo NetworkManager --print-config
also a further note regarding DNS resolving.
i used DDG to search the terms "force pihole usage"(quotation marks only for forum post clarity, didn't use them for the search)
there were multiple pages of results given the popularity of raspberry pi units these days(not to mention trying to stop all the ads/beacons/click-bait/cookies/iframes/javascript/pop-ups/redirects/super-cookies/third-party-cookies/trackers/zomg-and now all the AI generated garbage as well)
here is one that might be helpful even if more as an overview:
https://labzilla.io/blog/force-dns-pihole
and just for additional amusement: zomg
https://english.stackexchange.com/questions/4075/what-is-the-origin-of-zomg
bonus: don't forget that some/most? browsers cache dns as well...sigh... _neverending_whackamole_
#3 2024-11-25 18:15:35
devur
I hawent tried this, but the description looks right
/etc/rc.d/init.d/nscd restart
#4 2024-11-25 22:04:12
Ron
I don't have an rc.d folder in /etc. I have a rc0.d, rc1.d, rc2.d, rc3.d, rc4.d, rc5.d, rc6.d, and a rcS.d folder. But according to a post in another forum, Devuan doesn't cache DNS. Is that true?
#5 2024-11-25 23:52:14
@Ron
See https://www.linux.org/threads/clearing- … ost-250695
GatorsFan wrote:
Since you are using Devuan you do not need to flush the DNS Cache it does not cache DNS lookups - depending if you installed it with SysVInit or RunIt - since there is no systemd any systemd commands will not work such as systemctl
You router may cache them but all non-systemd Linux OSes do not DNS cache as far as I know
That said, I run a Chimaera VM with pi-hole and unbound inside my Daedalus box.
There is a DNS cache but it is mine.
It can be flushed though the UI.
#6 2025-01-12 18:31:11
kaiyel
There are times when I need to clear DNS cache quickly as well ... which is not possible if you rely on an upstream resolver.  So I generally always install "bind" on my systems and configure it as a local resolver.  This article will provide a solid foundation on how to do that :
How To Configure BIND as a Private Network DNS Server on Ubuntu 14.04
https://www.digitalocean.com/community/ … untu-14-04
Then, when I need to flush the DNS resolver cache, it's as easy as :
# rndc flush
Cheers,
--K
