#1 2024-10-27 20:20:11
grunchy
[SOLVED] changing the size of udev filesystem on /dev
i cannot find the config file or setting used to specify the size of /dev
currently /dev is set to 50% of physical memory. there is nothing in
/etc/defaults or /lib/init and only a remount in /etc/init.d/eudev, which
specifies a variable setting: tmpfs_size="10M" (so that ain't it)
nothing appears in /var/log/boot
where could this setting/config be coming from?
seems odd that it would be hard-coded and not documented.
#2 2024-10-27 22:50:25
Re: [SOLVED] changing the size of udev filesystem on /dev
(I edited this post since my first suggestion was bogus)
The devtmpfs filesystem is set up and initially populated by the kernel, and that uses 50% RAM as its limit.
The first mounting happens in the initrd's init scripts which are provided by initramfs-tools at /usr/share/initramfs-tools/. In my case it's at /usr/share/initramfs-tools/init:36, where you may add a size=nnn limit. Then use update-initramfs so as to include your fix in the initrd, and then reboot. Perhaps like the following hands-on:
# sed '/devtmpfs/s|-o |-o size=100M,|' -i /usr/share/initramfs-tools/init
# update-initramfs -u -k all
# reboot
EDIT: This way worked for me and it's as early as possible (without rebuilding the kernel).
#3 2024-10-28 05:49:04
grunchy
thank you ralph.ronnquist.  this works.  i like ths solution: if there is no 'knob' to adjust then make one!
