#1 2024-10-26 21:05:44
[SOLVED] Repository sync: How to reduce download size of 'apt-get update'?
I'm running excalibur on a amd64 computer with i386 achitechture enabled (to play old games). Additionally, some packages from ceres and daedalus are installed too. 'deb-src' repositories are commented-in on occasion, not permanently.
This resulted not seldom in having +100 MB to download just for syncing the repositories.
A reasonable reduction was archived by "i386 packages are installed from excalibur, all other repositories can be fixed to amd64". 'sources.list' looks as follows:
cat /etc/apt/sources.list
deb http://deb.devuan.org/merged excalibur                      main contrib non-free non-free-firmware
# virtualbox, nomacs
deb [arch=amd64] http://deb.devuan.org/merged ceres             main contrib non-free non-free-firmware
# lxde-gtk2 - lxpannel-gtk3 doesn't work
deb [arch=amd64] http://deb.devuan.org/merged daedalus          main contrib non-free non-free-firmware
deb [arch=amd64] http://deb.devuan.org/merged daedalus-updates  main contrib non-free non-free-firmware
deb [arch=amd64] http://deb.devuan.org/merged daedalus-security main contrib non-free non-free-firmware
# kpackage
deb [arch=amd64] http://mirror.ppa.trinitydesktop.org/trinity/deb/trinity-sb excalibur deps-r14 main-r14
What else can be done (or excluded or specified) to further reduce the download when apt is syncing?
Thanks for any input and regards.
EDIT 2024-Oct-30:
Decided to use "daedalus main" and "ceres main contrib" as a further reduction. And closing the topic.
#2 2024-10-27 11:07:00
Re: [SOLVED] Repository sync: How to reduce download size of 'apt-get update'?
