#1 2024-10-21 16:13:55
Micronaut
Repository not found.
My Devuan 4 install in a VM cannot find a major repository today.
E: Failed to fetch http://mirrors.dotsrc.org/debian-security/pool/updates/main/f/ffmpeg/ffmpeg_4.3.8-0+deb11u1_amd64.deb: 404  Not Found [IP: 130.225.254.116 80]
Has something been moved? Or is there a problem with the repository?
#2 2024-10-21 19:24:20
Re: Repository not found.
someone@somewhere:~$ curl -I https://mirrors.dotsrc.org/debian-security/pool/updates/main/f/ffmpeg/ffmpeg_4.3.8-0+deb11u1_amd64.deb
HTTP/2 200
server: nginx/1.18.0 (Ubuntu)
date: Mon, 21 Oct 2024 19:22:46 GMT
content-type: application/octet-stream
content-length: 1602824
last-modified: Mon, 21 Oct 2024 14:32:21 GMT
etag: "671665f5-187508"
x-frame-options: SAMEORIGIN
referrer-policy: strict-origin
accept-ranges: bytes
#3 2024-10-22 17:58:29
Micronaut
Retrieving it manually is a pretty clumsy work-around. They should have the repositories working. And it did work later in the day when I tried again.
#4 2024-10-22 20:37:49
just used curl -I to see if it was available...
