#1 2024-10-07 09:40:41
l3u
[SOLVED] Detached signature file is in unsupported binary format
Hi all,
I just wanted to update a server that hasn't been touched in a few months (3 or 4). When running apt update, I get:
# apt update
Hit:1 http://deb.devuan.org/merged daedalus InRelease
Ign:2 http://deb.devuan.org/merged daedalus-security InRelease
Ign:3 http://deb.devuan.org/merged daedalus-updates InRelease
Get:4 http://deb.devuan.org/merged daedalus-security Release [32.6 kB]
Get:5 http://deb.devuan.org/merged daedalus-updates Release [32.8 kB]
Get:6 http://deb.devuan.org/merged daedalus-security Release.gpg [310 B]
Ign:6 http://deb.devuan.org/merged daedalus-security Release.gpg
Get:7 http://deb.devuan.org/merged daedalus-updates Release.gpg [310 B]
Ign:7 http://deb.devuan.org/merged daedalus-updates Release.gpg
W: GPG error: http://deb.devuan.org/merged daedalus-security Release: Detached signature file '/var/lib/apt/lists/partial/deb.devuan.org_merged_dists_daedalus-security_Release.gpg' is in unsupported binary format
E: The repository 'http://deb.devuan.org/merged daedalus-security Release' is no longer signed.
W: GPG error: http://deb.devuan.org/merged daedalus-updates Release: Detached signature file '/var/lib/apt/lists/partial/deb.devuan.org_merged_dists_daedalus-updates_Release.gpg' is in unsupported binary format
E: The repository 'http://deb.devuan.org/merged daedalus-updates Release' is no longer signed.
What are those "unsupported binary format" errors? And how can I get rid of them?
Thanks a lot for all help!
#2 2024-10-07 10:06:07
Re: [SOLVED] Detached signature file is in unsupported binary format
Repeat the apt update?
Just done an update on my Daedalus workstation, worked fine.
#3 2024-10-07 10:43:02
l3u
Maybe this is some mirror problem?!
When I re-run apt update now, the result looks different:
# apt update
Hit:2 http://deb.devuan.org/merged daedalus-security InRelease
Hit:3 http://deb.devuan.org/merged daedalus-updates InRelease
Ign:4 http://deb.devuan.org/merged daedalus-security/non-free amd64 Packages
Ign:5 http://deb.devuan.org/merged daedalus-security/non-free Translation-en
Get:4 http://deb.devuan.org/merged daedalus-security/non-free amd64 Packages [13.0 kB]
Err:4 http://deb.devuan.org/merged daedalus-security/non-free amd64 Packages
  File has unexpected size (32 != 12976). Mirror sync in progress? [IP: 2001:638:a000:1021:21::1 80]
  Hashes of expected file:
   - Filesize:12976 [weak]
   - SHA256:2b3617386acb48e76447b0f86dfc152edbc8518081363f24fd034b1f74564dff
  Release file created at: Mon, 07 Oct 2024 03:21:32 +0000
W: Conflicting distribution: http://deb.devuan.org/merged daedalus-security InRelease (expected daedalus-security but got daedalus-updates)
E: Failed to fetch http://deb.devuan.org/merged/dists/daedalus-security/non-free/binary-amd64/Packages.xz  File has unexpected size (32 != 12976). Mirror sync in progress? [IP: 2001:638:a000:1021:21::1 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
#4 2024-10-07 11:23:31
Give it another try until it works.
#5 2024-10-08 06:48:13
l3u
Today, updating worked again. Seems like this was indeed some server problem.
Thanks for the feedback :-)
#6 2024-10-08 12:31:03
I3u wrote:
... some server problem.
So it seems:
File has unexpected size (32 != 12976). Mirror sync in progress?    # <- this
You may want to consider marking the problem as [Solved].  8^)
#7 2024-10-08 15:34:33
l3u
Yeah, of course.
In my defense, the first "unsupported binary format" messages did not include that hint ;-)
#8 2024-10-08 16:23:21
I3u wrote:
In my defense ...
Defense?
Whatever for?
None needed.
Not here.  8^)
I3u wrote:
... first "unsupported binary format" messages did not include that ...
Yes, you quite right.
And it was at that point that I realised what was going on.
