#1 2024-10-07 07:27:56
bai4Iej2need
firefox 128 urlbar and searchbar background color
Hi , they keep playing around with things, nobody needs to change. Now I have a grey urlbar and search bar,
which change color when the mouse hovers over it.
What a waste, because now I have to search the bars with the eyes, before I can target them with the mouse.
This Guy, who did it, has no knowledge about workplace ergonomics and MMI design.
Somewhere else I found a huge css script about changing a simple parameter.
Does anyone have a better solution, maybe a parameter for the color in the about:config ?
Searched but was not successful.
I use Mate on daedalus.
Does anyone have a better solution, maybe another browser where they don't fiddle with such ?
Meanwhile I kicked version 128 out and keep version 115
broken by design :
#2 2024-10-07 07:49:58
Magnus
Re: firefox 128 urlbar and searchbar background color
Linux GUI today sucks. Once upon a time GTK and QT apps looked similar. Now we have the problem you describe. My best tips about Firefox is Firefox Color https://color.firefox.com/. To some extend you can even use it in Thunderbird , if you copy the extension file from Firefox to Thunderbird.
#3 2024-10-12 04:08:41
bai4Iej2need
was still not able to find the resetting of the search bar.
not in about:preferences / search
nor in about:config I find the setting for a visible search bar
broken by design :
