#1 2024-09-27 12:27:17
Taz
[SOLVED] Power cut during upgrade
I am running an almost fully updated Excalibur. This morning there were 108 packages to update. I lost power with about 5 packages to install. On reboot I get a message about no functioning init found with the 6.10.9 kernel, 6.10.6 boots fine. After start up there were 4 broken packages all to do with gtk which I fixed with sudo dpkg --configure -a.
Everything is working fine but 6.10.9 remains unbootable. What should I do now to fix that?
#2 2024-09-27 12:39:21
Re: [SOLVED] Power cut during upgrade
The random guess is that it got interrupted in the "middle" of preparing the initramfs, and then perhaps it gets sorted with a simple:
# update-initramfs -u -k all
#3 2024-09-27 21:06:44
Taz
Good random guess that fixed it thank you.
