#1 2024-09-10 19:28:59
pearmypie
[SOLVED] network manager doesn't see wi-fi connections on fresh install.
Hello!
I'm doing a fresh install of Devuan OpenRC (switching from Gentoo). I want a minimal Devuan server install & to use network-manager and nmtui to connect to Wi-Fi (at home and away). I selected my wlan0 interface as default in the installer, and that seems to have hardcoded my home wi-fi's SSID and passkey directly into /etc/network/interfaces.
I think the package that manages this is ifupdown, but I am not sure. In Gentoo I simply skipped dhcpcd and directly installed network-manager and everything worked out of the box.
Can someone please walk me through setting up Devuan OpenRC with network-manager?
#2 2024-09-10 21:17:56
pearmypie
Re: [SOLVED] network manager doesn't see wi-fi connections on fresh install.
Instructions for anyone with the same problem:
sudo nano /etc/network/interfaces
Comment your wifi interface:
# The primary network interface
allow-hotplug wlp2s0
iface wlp2s0 inet dhcp
       wpa-ssid [your wifi-name]
       wpa-psk  [password]
To become this:
#allow-hotplug wlp2s0
#iface wlp2s0 inet dhcp
#       wpa-ssid [your wifi-name]
#       wpa-psk  [password]
Then, edit your NetworkManager.conf:
sudo nano /etc/NetworkManager/NetworkManager.conf
And change it like so (below [ifupdown] change managed to `true`)
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=true
Now everything should work fine after a reboot (at least this was the exact fix I was looking for). Now the `nmtui` shows all the nearby Wi-Fi networks.
