#1 2024-09-05 05:43:40
amaro
[SOLVED] safely remove xfce
hello everybody,
is this good enough to safely remove 'xfce' desktop
apt-get purge xfconf xfce4-utils xfwm4 xfce4-session xfdesktop4 exo-utils xfce4-panel xfce4-terminal thunar xfce4* xserver-xorg*
is there anything missing or redundant?
thank you in advance?
p.s. there are different suggestions on different websites so better to be safe than sorry.
#2 2024-09-05 08:48:25
Re: [SOLVED] safely remove xfce
searching the forum for "task-xfce-desktop" gives over a page of results.
adding "metapackage" narrows it down to three.
one of those three contained this threadpost by administrator fsmithred:
https://dev1galaxy.org/viewtopic.php?pid=321#p321
it should also be noted that there is a difference between using "purge" and "remove"
#3 2024-09-05 10:25:08
One thing missing. Try it like this first.
apt-get --simulate purge <packages>
#4 2024-09-05 11:29:03
amaro
thank you guys! those were very helpful suggestions.
after the simulation there is a huge list of files for auto-remove because there were already some files for auto-remove and this command just adds some more
# apt-get --simulate remove task-xfce-desktop xfconf xfwm4 xfdesktop4 exo-utils xfce4-* thunar xfce4*
Note, selecting 'xfce4-weather-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-statusnotifier-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-session-dbgsym' for glob 'xfce4-*'
Note, selecting 'xfce4-xkb-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-diskperf-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-dict' for glob 'xfce4-*'
Note, selecting 'xfce4-battery-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-cpugraph-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-dev-tools' for glob 'xfce4-*'
Note, selecting 'xfce4-power-manager-data' for glob 'xfce4-*'
Note, selecting 'xfce4-netload-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-smartbookmark-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-sntray-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-panel' for glob 'xfce4-*'
Note, selecting 'xfce4-eyes-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-panel-profiles' for glob 'xfce4-*'
Note, selecting 'xfce4-goodies' for glob 'xfce4-*'
Note, selecting 'xfce4-cpufreq-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-taskmanager' for glob 'xfce4-*'
Note, selecting 'xfce4-mailwatch-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-radio-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-power-manager' for glob 'xfce4-*'
Note, selecting 'xfce4-timer-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-clipman-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-helpers' for glob 'xfce4-*'
Note, selecting 'xfce4-settings' for glob 'xfce4-*'
Note, selecting 'xfce4-terminal' for glob 'xfce4-*'
Note, selecting 'xfce4-session' for glob 'xfce4-*'
Note, selecting 'xfce4-windowck-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-places-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-appfinder' for glob 'xfce4-*'
Note, selecting 'xfce4-appmenu-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-clipman' for glob 'xfce4-*'
Note, selecting 'xfce4-power-manager-plugins' for glob 'xfce4-*'
Note, selecting 'xfce4-wavelan-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-sntray-plugin-common' for glob 'xfce4-*'
Note, selecting 'xfce4-systemload-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-notes' for glob 'xfce4-*'
Note, selecting 'xfce4-notes-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-volstatus-icon' for glob 'xfce4-*'
Note, selecting 'xfce4-verve-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-screenshooter' for glob 'xfce4-*'
Note, selecting 'xfce4-genmon-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-indicator-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-utils' for glob 'xfce4-*'
Note, selecting 'xfce4-sensors-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-mount-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-pulseaudio-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-whiskermenu-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-screensaver' for glob 'xfce4-*'
Note, selecting 'xfce4-datetime-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-fsguard-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-mpc-plugin' for glob 'xfce4-*'
Note, selecting 'xfce4-notifyd' for glob 'xfce4-*'
Note, selecting 'xfce4-cddrive-plugin' for glob 'xfce4-*'
Package 'xfce4-cddrive-plugin' is not installed, so not removed
Package 'xfce4-volstatus-icon' is not installed, so not removed
Package 'xfce4-radio-plugin' is not installed, so not removed
Package 'xfce4-utils' is not installed, so not removed
Package 'xfce4-statusnotifier-plugin' is not installed, so not removed
Package 'xfce4-indicator-plugin' is not installed, so not removed
Package 'xfce4-sntray-plugin-common' is not installed, so not removed
Package 'xfce4-appmenu-plugin' is not installed, so not removed
Package 'xfce4-eyes-plugin' is not installed, so not removed
Package 'xfce4-mpc-plugin' is not installed, so not removed
Package 'xfce4-mount-plugin' is not installed, so not removed
Package 'xfce4-notes' is not installed, so not removed
Package 'xfce4-notes-plugin' is not installed, so not removed
Package 'xfce4-panel-profiles' is not installed, so not removed
Package 'xfce4-screensaver' is not installed, so not removed
Package 'xfce4-session-dbgsym' is not installed, so not removed
Package 'xfce4-sntray-plugin' is not installed, so not removed
Package 'xfce4-windowck-plugin' is not installed, so not removed
accountwizard apt-config-icons-hidpi apt-config-icons-large apt-config-icons-large-hidpi avahi-utils
clearlooks-phenix-deepsea-theme cryptsetup-run cups-pk-helper exfat-fuse fonts-liberation2 fonts-noto-hinted
ftp gdisk geoip-database gir1.2-handy-1 gir1.2-javascriptcoregtk-4.0 gir1.2-packagekitglib-1.0
gir1.2-polkit-1.0 gir1.2-secret-1 gir1.2-soup-2.4 gir1.2-webkit2-4.0 gsfonts gsfonts-x11 guile-2.2-libs
hddtemp hyphen-en-us intltool iucode-tool kde-config-updates kdepim-themeeditors kross kuserfeedback-doc
libabsl20220623 libappstream4 libappstreamqt2 libargon2-1 libatk1.0-data libavdevice58 libavdevice59
libavfilter7 libavfilter8 libavformat58 libavresample4 libblockdev-crypto2 libblockdev-fs2 libblockdev-loop2
libblockdev-part-err2 libblockdev-part2 libblockdev-swap2 libblockdev-utils2 libblockdev2
libboost-chrono1.74.0 libboost-dev libboost-filesystem1.74.0 libboost-iostreams1.74.0
libboost-program-options1.74.0 libboost-thread1.74.0 libboost1.83-dev libc++1-16 libc++abi1-16
libcanberra-gtk3-0 libcanberra-gtk3-module libcbor0 libcbor0.8 libck-connector0 libcmark-gfm-extensions0
libcmark-gfm0 libdaxctl1 libdraco7 libel-api-java libenca0 libexo-2-0 libexo-common
libextutils-pkgconfig-perl libffmpegthumbnailer4v5 libfilezilla34 libflac8 libfluidsynth2 libfmt7
libgarcon-1-0 libgarcon-common libgavl1 libgcab-1.0-0 libgeoip1 libgit2-1.1 libgit2-1.5 libglade2-0
libglew2.1 libglyr1 libgmerlin-avdec1 libgps28 libgs9-common libgssdp-1.2-0 libgtop-2.0-11 libgtop2-common
libgumbo1 libgupnp-1.2-0 libgupnp-igd-1.0-4 libhttrack2 libidn11 libigdgmm11 libilmbase25 libimobiledevice6
libixml10 libjim0.79 libjim0.81 libjsoncpp24 libkcolorpicker0 libkf5krosscore5 libkf5krossui5
libkf5mailimporterakonadi5 libkf5pulseaudioqt3 libkgantt2-l10n libkwalletbackend5-5 libldap-2.4-2 libllvm11
libllvm15 liblua5.3-0 libmagick++-6.q16-8 libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra
libmagickwand-6.q16-6 libmbedcrypto3 libmbedtls12 libmbedx509-0 libmousepad0 libmozjs-102-0 libmpdec3
libmujs2 libnautilus-extension1a libndctl6 libnetpbm10 libnfs13 libnma-common libnma0 libnotify-bin
libnsl-dev libntfs-3g883 libofa0 libokular5core10 libopenblas-dev libopenblas-pthread-dev libopenblas0
libopenexr25 libopts25 libpangox-1.0-0 libpcre16-3 libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5
libperl5.32 libperl5.36 libphonon4qt5-data libplacebo208 libplist3 libpmem1 libpodofo0.9.7 libpoppler-cpp0v5
libpoppler-qt6-3t64 libpoppler102 libpoppler126 libpostproc55 libpostproc56 libpthread-stubs0-dev
libpython3-all-dev libpython3.11 libpython3.11-dev libpython3.9 libpython3.9-dev libpython3.9-minimal
libpython3.9-stdlib libqalculate22 libqpdf28 libqt5script5 libqt5webview5 libqt6jsonrpc6
libqt6labsfolderlistmodel6 libqt6labsqmlmodels6 libqt6labssettings6 libqt6languageserver6 libqt6pdf6
libqt6pdfquick6 libqt6pdfwidgets6 libqt6positioning6-plugins libqt6positioningquick6 libqt6qmlcompiler6
libqt6qmlcore6 libqt6qmllocalstorage6 libqt6qmlworkerscript6 libqt6qmlxmllistmodel6 libqt6quicktest6
libqt6serialport6 libqt6webenginequickdelegatesqml6 libquvi-0.9-0.9.3 libquvi-scripts-0.9 libraw20 libre2-9
librecode0 librest-0.7-0 libsdl-image1.2 libsdl1.2debian libservlet3.1-java libsidplayfp5 libsmbios-c2
libsoup-gnome-2.4-1 libspdlog1.10 libsrt1.4-gnutls libswscale5 libswscale6 libtesseract4 libtexlua53
libtexluajit2 libtidy5deb1 libtiff5 libtinyxml2-8 libtinyxml2-9 libtirpc-dev libtorrent-rasterbar10
libtotem-plparser-common libtotem-plparser18 libtumbler-1-0t64 libu2f-udev libunwind-16 libupnp13
libusb-0.1-4 libusbmuxd6 libwebsocket-api-java libwmf-0.2-7 libwmf0.2-7 libwxbase3.0-0v5
libwxgtk3.0-gtk3-0v5 libxfce4panel-2.0-4 libxfce4ui-common libxfce4util-bin libxfce4util-common
libxfce4util7 libxklavier16 libxnvctrl0 libxsimd-dev libzxing2 lua-bitop lua-expat lua-json lua-lpeg
lua-socket mbox-importer mousepad mythes-en-us network-manager-gnome ntpsec-ntpdig p7zip-full
perl-modules-5.32 perl-modules-5.36 pigz pim-data-exporter pim-sieve-editor policykit-1-gnome
python-apt-common python-apt-common-devuan python3-all-dev python3-apt python3-backcall python3-beniget
python3-blinker python3-cups python3-cupshelpers python3-debconf python3-debian python3-debianbts
python3-docopt python3-gast python3-httplib2 python3-jinja2 python3-jwt python3-lazr.restfulclient
python3-lazr.uri python3-ldb python3-magic python3-markupsafe python3-mistune python3-mock python3-oauthlib
python3-pickleshare python3-ply python3-pysimplesoap python3-pythran python3-rfc3986 python3-smbc
python3-talloc python3-wadllib python3.11-dev python3.9 python3.9-dev python3.9-minimal qt6-declarative-dev
qt6-declarative-dev-tools qt6-pdf-dev qt6-positioning-dev qt6-qmllint-plugins qt6-webchannel-dev
qt6-webengine-dev-tools ruby2.7 ruby2.7-dev ruby2.7-doc slim sntp system-config-printer
system-config-printer-common system-config-printer-udev tango-icon-theme telnet thunar-data tumbler
tumbler-common ueberzug xarchiver xfdesktop4-data xiccd xscreensaver xscreensaver-data xscreensaver-gl
xtl-dev
Use 'apt autoremove' to remove them.
exo-utils fontsnaps libgarcon-gtk3-1-0 libthunarx-3-0 libxfce4ui-2-0 libxfce4ui-utils libxfconf-0-3
ristretto task-xfce-desktop thunar thunar-archive-plugin thunar-media-tags-plugin thunar-volman xfburn xfce4
xfce4-appfinder xfce4-battery-plugin xfce4-clipman xfce4-clipman-plugin xfce4-cpufreq-plugin
xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dev-tools xfce4-dict xfce4-diskperf-plugin
xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-goodies xfce4-helpers xfce4-mailwatch-plugin
xfce4-netload-plugin xfce4-notifyd xfce4-panel xfce4-places-plugin xfce4-power-manager
xfce4-power-manager-data xfce4-power-manager-plugins xfce4-pulseaudio-plugin xfce4-screenshooter
xfce4-sensors-plugin xfce4-session xfce4-settings xfce4-smartbookmark-plugin xfce4-systemload-plugin
xfce4-taskmanager xfce4-terminal xfce4-timer-plugin xfce4-verve-plugin xfce4-wavelan-plugin
xfce4-weather-plugin xfce4-whiskermenu-plugin xfce4-xkb-plugin xfconf xfdesktop4 xfwm4
The following held packages will be changed:
xfce4
0 upgraded, 0 newly installed, 55 to remove and 42 not upgraded.
Remv task-xfce-desktop [3.75devuan1]
Remv xfce4 [4.16]
Remv xfce4-goodies [4.14.0]
Remv xfce4-places-plugin [1.8.1-1]
Remv thunar [4.18.11-1] [thunar-archive-plugin:amd64 thunar-volman:amd64 thunar-media-tags-plugin:amd64 ]
Remv xfce4-verve-plugin [2.0.1-1] [thunar-archive-plugin:amd64 thunar-volman:amd64 thunar-media-tags-plugin:amd64 ]
Remv exo-utils [4.18.0-1+b2] [xfce4-panel:amd64 xfdesktop4:amd64 thunar-archive-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 thunar-media-tags-plugin:amd64 ]
Remv fontsnaps [1.4] [xfce4-panel:amd64 xfdesktop4:amd64 thunar-archive-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 thunar-media-tags-plugin:amd64 ]
Remv xfce4-panel [4.16.2-1] [xfdesktop4:amd64 thunar-archive-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 thunar-media-tags-plugin:amd64 ]
Remv xfdesktop4 [4.18.1-1+b1] [thunar-archive-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 thunar-media-tags-plugin:amd64 ]
Remv libgarcon-gtk3-1-0 [4.18.1-1+b2] [thunar-archive-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 thunar-media-tags-plugin:amd64 ]
Remv thunar-media-tags-plugin [0.4.0-1+b2] [thunar-archive-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 ]
Remv libthunarx-3-0 [4.18.11-1] [thunar-archive-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 ]
Remv xfce4-session [4.16.0-1+devuan1] [thunar-archive-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 ]
Remv xfce4-xkb-plugin [1:0.8.2-1] [thunar-archive-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 ]
Remv libxfce4ui-2-0 [4.18.6-1] [xfce4-weather-plugin:amd64 xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-battery-plugin:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfburn:amd64 xfwm4:amd64 libxfce4ui-utils:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 thunar-archive-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 xfce4-appfinder:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 ristretto:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv libxfce4ui-utils [4.18.6-1] [xfce4-weather-plugin:amd64 xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-battery-plugin:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfburn:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 thunar-archive-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 xfce4-appfinder:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 ristretto:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-weather-plugin [0.11.0-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-battery-plugin:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64xfburn:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 thunar-archive-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 xfce4-appfinder:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 ristretto:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv libxfconf-0-3 [4.18.3-2] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-battery-plugin:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfburn:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 thunar-archive-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 xfce4-appfinder:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 ristretto:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv ristretto [0.13.2-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-battery-plugin:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfburn:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 thunar-archive-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 xfce4-appfinder:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv thunar-archive-plugin [0.5.2-1+b2] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-battery-plugin:amd64xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfburn:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 thunar-volman:amd64 xfce4-appfinder:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv thunar-volman [4.18.0-1+b1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-battery-plugin:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfburn:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-appfinder:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfburn [0.7.2-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-battery-plugin:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-appfinder:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-appfinder [4.16.1-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-battery-plugin:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-battery-plugin [1.1.3-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-clipman-plugin:amd64 xfce4-settings:amd64xfce4-terminal:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-clipman-plugin [2:1.6.1-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-clipman:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-clipman [2:1.6.1-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfce4-cpufreq-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-cpufreq-plugin [1.2.4-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-cpugraph-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-cpugraph-plugin [1.2.1-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-datetime-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-datetime-plugin [0.8.1-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-dev-tools [4.16.0-1] [xfce4-diskperf-plugin:amd64 xfce4-dict:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-dict [0.8.4-1] [xfce4-diskperf-plugin:amd64 xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64xfce4-whiskermenu-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-diskperf-plugin [2.6.3-1] [xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-fsguard-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-fsguard-plugin [1.1.2-1] [xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-genmon-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-genmon-plugin [4.1.1-1] [xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-settings:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-settings [4.16.0-1+deb11u1] [xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-helpers [4.16.0-1+deb11u1] [xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-mailwatch-plugin:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-mailwatch-plugin [1.3.0-1] [xfce4-netload-plugin:amd64 xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-netload-plugin [1.3.2-1] [xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 xfce4-notifyd:amd64 ]
Remv xfce4-notifyd [0.6.2-1] [xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-power-manager-plugins:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-power-manager-plugins [4.16.0-1] [xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-power-manager:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-power-manager [4.16.0-1] [xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-power-manager-data [4.16.0-1] [xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-pulseaudio-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-pulseaudio-plugin [0.4.3-1] [xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-screenshooter:amd64 xfce4-sensors-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-screenshooter [1.9.8-1] [xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-sensors-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-sensors-plugin [1.3.0-3] [xfce4-smartbookmark-plugin:amd64 xfwm4:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-smartbookmark-plugin [0.5.2-1] [xfwm4:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-wavelan-plugin:amd64 xfce4-systemload-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-systemload-plugin [1.2.4-1] [xfwm4:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-wavelan-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-taskmanager [1.4.0-1] [xfwm4:amd64 xfce4-timer-plugin:amd64 xfce4-terminal:amd64 xfce4-wavelan-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-terminal [0.8.10-1] [xfwm4:amd64 xfce4-timer-plugin:amd64 xfce4-wavelan-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-timer-plugin [1.7.1-1] [xfwm4:amd64 xfce4-wavelan-plugin:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-wavelan-plugin [0.6.2-1] [xfwm4:amd64 xfce4-whiskermenu-plugin:amd64 ]
Remv xfce4-whiskermenu-plugin [2.5.3-1] [xfwm4:amd64 ]
Remv xfconf [4.18.3-2] [xfwm4:amd64 ]
Remv xfwm4 [4.18.0-1+b1]
#5 2024-09-05 12:30:48
amaro
apt autoremove
apt clean
reboot
everything works!
thank you!
