#1 2024-09-04 09:50:04
Lomax
Removing Apparmor
Hi all,
I've purged apparmor and added security=none to kernel params. I've also deleted /etc/apparmor.d and /var/cache/apparmor. But I still have lots of /proc/[some pid]/task/[some pid]/attr/apparmor directories as well as a /sys/module/apparmor directory - can I safely rm -rf these as well?
"I cannot lie to you about your chances, but you have my sympathies."
#2 2024-09-04 10:41:02
Re: Removing Apparmor
as long as you are adequately backed-up, you can always make alterations and see what happens(especially after a warm-restart and/or cold-boot)
#3 2024-09-04 10:51:50
Lomax
Thanks. I am adequately-ish backed up, but the problem is this is on a Raspberry Pi which is somewhat inaccessible, which makes taking a new image of the card quite fiddly. Not to mention how long it takes to image a 64Gb card... So it's not something I do very frequently; most recent back-up was made yesterday and I've done a fair bit of work on it since then. I guess I could copy just those folders back onto the card if I bork it, though physically retrieving it is a bit of a hassle.
#4 2024-09-04 11:08:27
#5 2024-09-05 00:19:35
Note that /proc is a virtual filesystem tree giving insight into the running kernel. Not to be played with by hand.
#6 2024-09-05 14:48:43
Lomax
Thanks, I thought so, and haven't touched it. Strange that these directories are created despite setting the security=none kernel parameter. What about /sys/module/apparmor?
$ dpkg -S apparmor
libapparmor1:arm64: /usr/share/doc/libapparmor1/copyright
man-db: /etc/apparmor.d/usr.bin.man
libapparmor1:arm64: /usr/lib/aarch64-linux-gnu/libapparmor.so.1.8.4
isc-dhcp-client: /etc/apparmor.d/sbin.dhclient
libapparmor1:arm64: /usr/share/doc/libapparmor1/changelog.Debian.gz
man-db, isc-dhcp-client: /etc/apparmor.d
#7 2024-09-05 14:52:00
quickfur
In theory you could probably remove libapparmor1 as well. But first check the reverse dependencies to see if it will inadvertently also remove some essential packages, or packages that you need.
#8 2024-09-05 14:54:14
Lomax
Thanks - that would remove dbus as well, which I think I need:
  dbus dbus-daemon libapparmor1 libsystemd-shared udisks2
#9 2024-09-05 15:18:30
Sometimes such command lines work:
$ apt install dbus apparmor- -s
dbus is already the newest version (1.14.10-1~deb12u1devuan1).
  apparmor
Remv apparmor [3.0.8-3]
"apparmor-" has a trailing "-" and "-s" is for simulation.
Computer: daedalus notebook
#10 2024-09-05 15:28:55
Lomax
Thanks, strangely it now wants a load of armhf packages, though I'm on aarch64:
$ sudo apt install dbus libapparmor1- -s
dbus is already the newest version (1.14.10-1~deb12u1).
dbus set to manually installed.
  dbus-daemon:armhf gcc-12-base:armhf libapparmor1:armhf libaudit1:armhf libc6:armhf libcap-ng0:armhf libcap2:armhf
  libdbus-1-3:armhf libexpat1:armhf libgcc-s1:armhf libgcrypt20:armhf libgpg-error0:armhf liblz4-1:armhf liblzma5:armhf
  libpcre2-8-0:armhf libselinux1:armhf libsystemd0:armhf libzstd1:armhf
Suggested packages:
  glibc-doc:armhf locales:armhf libnss-nis:armhf libnss-nisplus:armhf rng-tools:armhf
Recommended packages:
  libidn2-0:armhf libgpg-error-l10n:armhf
0 upgraded, 18 newly installed, 3 to remove and 0 not upgraded.
