#1 2024-09-01 22:38:42
USB Stick, File Size > 4GB
The USB stick was factory formated with 'vfat' and allowed a file size of up to 4GB. I need more.
Formating it with mkfs.vfat /dev/sde1 -S 4096 should allow 16GB file size, but it's still 4GB. Using -S 32768 makes the drive disappear.
Using ntfs (NeanderTal File System) is as always slow as fuck.
Two questions:
(a) How to formate vfat, that can have files bigger than 4GB?
(b) Where is Paragon's (compared to ntfs-3g) super-fast-kernel-ntfs-driver? Or how can it be enabled?
What really makes me sick is the following: That little box I want to feed most likely runs on Linux, but it reads fuck Microsoft file systems only. Such s**t costs hours for nothing.
#2 2024-09-01 23:21:59
Re: USB Stick, File Size > 4GB
If you don't need window$ formatting for window$ machines, format to ext4.
fat32 or vfat has a file size limit of 4096Mb (4gig) that's it, split the file or else...
ntfs-3g package is in "otherosfs main" ver 1.2022.10.3-1+b1
I keep mine at vfat so they work in the car, on the tv and my friends pc's.
#3 2024-09-02 10:12:50
pcalvert
Use GParted and format the drive as exFAT. Before doing this, make sure that exfatprogs is installed.
Another one is called Luxxle.
#4 2024-09-02 12:58:16
Thanks for the replies.
The stick is for a TV set-top-box.
4 GB file size is easy to hit. Sadly, ext[3,4] file systems are not recognised.
Tried exfat: File size is good, but the file system is not recognised either.
Found some information on Paragon's "ntfs3" driver, e.g. https://forum.manjaro.org/t/how-to-enable-ntfs3/86049/4
$ cat /boot/config-6.9.12-amd64 | grep -i ntfs3
# CONFIG_NTFS3_FS is not set
Means recompiling the kernel to enable it.
#5 2024-09-02 22:22:14
pcalvert
It sounds like that TV box may be running a very old version of Linux, in which case it may only support the older filesystems. Try formatting the USB stick as XFS and, if that doesn't work, try ext2.
#6 2024-09-03 08:20:58
s1mple
If formatting is slow you can pass -f to mkfs.ntfs to skip zeroing the drive.
#7 2024-09-03 11:15:07
pcalvert
If it turns out that you absolutely must use NTFS, then I recommend using a Liquorix kernel. According to my research, ntfs-3g is enabled in Liquorix kernels.
See: https://liquorix.net/
#8 2024-09-04 12:20:36
Great advice, thanks a lot! Totally forgot about liquorix.
My shiny new computer does not suffer on windows, but the old one has a (more or less) big data partition formated with ntfs. For the fist time the transfer speed is in a reasonable dimension. I'm quite happy with that.
No news on the USB-stick front so far.
