#1 2024-08-31 10:23:45
deepforest
[SOLVED] Steam not launch
why?
nothing happens
webhelper-linux.txt
freeartist-devuan@devuan:/home/freeartist/Downloads/Devuan/freeartist$ steam
steam.sh[28756]: Running Steam on devuan 5 64-bit
steam.sh[28756]: STEAM_RUNTIME is enabled automatically
setup.sh[28825]: Steam runtime environment up-to-date!
steam.sh[28756]: Steam client's requirements are satisfied
[2024-08-31 13:20:34] Startup - updater built Jul 16 2024 23:21:18
[2024-08-31 13:20:34] Startup - Steam Client launched with: '/home/freeartist-devuan/.steam/debian-installation/ubuntu12_32/steam' '-srt-logger-opened' '-nominidumps' '-nobreakpad'
08/31 13:20:34 minidumps folder is set to /tmp/dumps
08/31 13:20:34 Init: Installing breakpad exception handler for appid(steam)/version(1721173382)/tid(28894)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2024-08-31 13:20:34] Loading cached metrics from disk (/home/freeartist-devuan/.steam/debian-installation/package/steam_client_metrics.bin)
[2024-08-31 13:20:34] Failed to load cached hosts file (File 'update_hosts_cached.vdf' not found), using defaults
[2024-08-31 13:20:34] Using the following download hosts for Public, Realm steamglobal
[2024-08-31 13:20:34] 1. https://cdn.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2024-08-31 13:20:34] Checking for update on startup
[2024-08-31 13:20:34] Checking for available updates...
[2024-08-31 13:20:34] Downloading manifest: https://cdn.steamstatic.com/client/steam_client_ubuntu12
[2024-08-31 13:20:34] Manifest download: send request
[2024-08-31 13:20:34] Manifest download: waiting for download to finish
[2024-08-31 13:20:35] Manifest download: finished
[2024-08-31 13:20:35] Download skipped: /client/steam_client_ubuntu12 version 1721173382, installed version 1721173382, existing pending version 0
[2024-08-31 13:20:35] Nothing to do
[2024-08-31 13:20:35] Verifying installation...
[2024-08-31 13:20:35] Performing checksum verification of executable files
[2024-08-31 13:20:37] Verification complete
UpdateUI: skip show logo
Steam logging initialized: directory: /home/freeartist-devuan/.steam/debian-installation/logs
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf4707780
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf4706050
CAppInfoCacheReadFromDiskThread took 0 milliseconds to initialize
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 28971
bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
smile
#2 2024-08-31 23:07:56
Re: [SOLVED] Steam not launch
Hi, the text mentions egl errors numerous times, do you have libegl1 (mesa) installed? You may require the i386 (32bit) version as well for steam.
If you're using the "nVidia".run install package from nVidia, make sure you have also installed the 32bit section when running the installer .run package (blob).
#3 2024-09-01 07:48:19
deepforest
thanks for reply,
flatpak steam version is launched,
before i install steam from repos
smile
