The zramen script (by atweiden) from Void Linux is like my guinea pig for learning to package on other distributions. It is a simple script that creates a zram device and uses environment variables to configure the size and compression algorithm. I've made a DEB package with a sysvinit script for Devuan which you can find here: https://git.disroot.org/hunter0one/devu … ter/zramen
Updated to 1.0.0
