#1 2024-08-23 16:13:55
dyfi
[SOLVED] refractasnapshot
I'm using a fresh and updated Deveuan xfce system.  Snapshot copies file system through to /var and then crashes, /var/log info below:-
cpio: kernel/x86/microcode/GenuineIntel.bin not created: newer or same age version exists
15540 blocks
+ zcat
+ cpio -i
gzip: stdin: not in gzip format
cpio: premature end of archive
+ exit_code=2
+ '[' 2 -ne 0 ']'
+ cpio -i
15540 blocks
+ xzcat
+ cpio -i
xzcat: (stdin): File format not recognized
+ exit_code=2
+ '[' 2 -ne 0 ']'
+ echo 'Decompression error'
+ exit 1
Any suggestions would be appreciated.  Thanks in advance.
#2 2024-08-23 16:29:36
Re: [SOLVED] refractasnapshot
There are two ways to solve this. One way is to remove  intel-microcode to make the snapshot and then add it back after you install the system somewhere. The better solution is to use the version that's in excalibur/ceres:
https://pkgmaster.devuan.org/devuan/poo … .0_all.deb
Download and install with dpkg -i refractasnapshot*.deb
#3 2024-08-23 16:51:04
dyfi
Thank you for the prompt reply.  I am out of time today, will have a crack at it again in the morning.
#4 2024-08-23 17:18:10
dyfi
Couldn't wait till morning, just had to try it.  Works fine now.  Thank you again.
#5 2024-10-13 10:07:38
odie2
This problem is solved in Refracta Snapshot 10.4.1.
Download Refracta Snapshot BASE
Download Refracta Snapshot GUI
ref: Issue 3764
