#1 2024-08-15 14:59:21
bunnymnemonic
Laptop shuts down instead of suspend
After I suspend my laptop, it randomly shuts down during the process. It does no matter whether it is on battery or not, lid closed or not. It happens on about every 4th suspend.
Do you know where could I start inspecting the problem? Which log should I check?
System specs:
Devuan 5 (up to date)
Linux 6.1.0-23-amd64
XFCE 4.18
Dell Vostro 15 3530
13th Gen Intel Core i5-1335U
8 GB memory
#2 2024-08-15 17:32:27
Re: Laptop shuts down instead of suspend
without knowing the history of the machine and components one can only speculate.
what other operating system(s) have you had complete successful operation(s) with?
perhaps a stick of ram is going bad, or random hdd/ssd glitches, have had brand new equipment that wasn't functioning properly and have corrected the proper operation by unplugging and replugging cables/cards/drives/etc.
as always, your mileage may vary and some procedures may void some warranties.
#3 2025-11-11 08:58:42
saw your recent post and wondered if you ever figured out why your machine was failing to perform as you desired/expected?
#4 2026-05-18 17:27:58
bunnymnemonic
Wow, thank you very much for remembering me. As far as I can remember, changing the "Block Sleep Option" in the BIOS settings solved the problem. I found the solution there:
https://www.dell.com/support/kbdoc/en-u … l-power-on
