#1 2024-08-06 06:05:55
rdav
[SOLVED] Xorg not starting with error "(EE) [drm] Failed to open DRM device .."
Hi Devuan Brains Trust!
Xorg is failing with various kernels:
linux-image-6.10.3-amd64
linux-image-6.9.12-amd64
linux-image-5.10.0-31-amd64
However will start with linux-image-6.9.11-amd64.
Typical /var/log/Xorg.0.log:
[    24.913]
X.Org X Server 1.21.1.11
[    24.913] Current Operating System: Linux beanz 6.10.3-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.10.3-1 (2024-08-04) x86_64
[    24.913] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.10.3-amd64 root=UUID=59d2e3aa-fbb4-4c21-a3ad-d0d7af3337b7 ro video=1024x768 quiet pcie_aspm=off module_blacklist=pcspkr
[    24.913] xorg-server 2:21.1.12-1devuan1 (https://www.devuan.org/os/community)
[    24.913] Current version of pixman: 0.42.2
[    24.913]    Before reporting problems, check http://wiki.x.org
[    24.913] Markers: (--) probed, (**) from config file, (==) default setting,
[    24.913] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug  6 15:40:28 2024
[    24.915] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    24.915] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    24.916] (==) No Layout section.  Using the first Screen section.
[    24.916] (==) No screen section available. Using defaults.
[    24.916] (**) |-->Screen "Default Screen Section" (0)
[    24.916] (**) |   |-->Monitor "<default monitor>"
[    24.916] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[    24.916] (**) |   |-->Device "Nvidia card"
[    24.916] (==) No monitor specified for screen "Default Screen Section".
[    24.916] (**) Allowing byte-swapped clients
[    24.916] (==) Automatically adding devices
[    24.916] (==) Automatically enabling devices
[    24.916] (==) Automatically adding GPU devices
[    24.916] (==) Automatically binding GPU devices
[    24.916] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    24.920] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    24.920]    Entry deleted from font path.
[    24.924] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/X11/Type1".
[    24.924]    Entry deleted from font path.
[    24.924]    (Run 'mkfontdir' on "/usr/share/fonts/X11/Type1").
[    24.924] (==) FontPath set to:
        /usr/share/fonts/X11/misc,
        /usr/share/fonts/X11/100dpi,
        /usr/share/fonts/X11/75dpi,
        built-ins
[    24.924] (==) ModulePath set to "/usr/lib/xorg/modules"
[    24.924] (II) The server relies on udev to provide the list of input devices.
[    24.924] (II) Loader magic: 0x5643bfcf4ea0
[    24.924] (II) Module ABI versions:
[    24.924]    X.Org ANSI C Emulation: 0.4
[    24.924]    X.Org Video Driver: 25.2
[    24.924]    X.Org XInput driver : 24.4
[    24.924]    X.Org Server Extension : 10.0
[    24.924] (++) using VT number 7
[    24.924] (II) seat-libseat: libseat integration requires -keeptty and -keeptty was not provided, disabling libseat integration
[    24.926] (--) PCI:*(1@0:0:0) 10de:11be:103c:176c rev 161, Mem @ 0xd8000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/131072
[    24.926] (II) LoadModule: "glx"
[    24.927] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    24.934] (II) Module glx: vendor="X.Org Foundation"
[    24.934]    compiled for 1.21.1.11, module version = 1.0.0
[    24.934]    ABI class: X.Org Server Extension, version 10.0
[    24.934] (II) LoadModule: "nouveau"
[    24.935] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    24.937] (II) Module nouveau: vendor="X.Org Foundation"
[    24.937]    compiled for 1.21.1.11, module version = 1.0.17
[    24.937]    Module class: X.Org Video Driver
[    24.937]    ABI class: X.Org Video Driver, version 25.2
[    24.937] (II) NOUVEAU driver Date:   Sat Jan 23 12:24:42 2021 -0500
[    24.937] (II) NOUVEAU driver for NVIDIA chipset families :
[    24.937]    RIVA TNT            (NV04)
[    24.937]    RIVA TNT2           (NV05)
[    24.937]    GeForce 256         (NV10)
[    24.937]    GeForce 2           (NV11, NV15)
[    24.937]    GeForce 4MX         (NV17, NV18)
[    24.937]    GeForce 3           (NV20)
[    24.937]    GeForce 4Ti         (NV25, NV28)
[    24.937]    GeForce FX          (NV3x)
[    24.937]    GeForce 6           (NV4x)
[    24.937]    GeForce 7           (G7x)
[    24.937]    GeForce 8           (G8x)
[    24.937]    GeForce 9           (G9x)
[    24.937]    GeForce GTX 2xx/3xx (GT2xx)
[    24.937]    GeForce GTX 4xx/5xx (GFxxx)
[    24.937]    GeForce GTX 6xx/7xx (GKxxx)
[    24.937]    GeForce GTX 9xx     (GMxxx)
[    24.937]    GeForce GTX 10xx    (GPxxx)
[    25.501] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[    25.501] (EE) No devices detected.
[    25.501] (EE)
Fatal server error:
[    25.501] (EE) no screens found(EE)
[    25.501] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[    25.501] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    25.501] (EE)
[    25.590] (EE) Server terminated with error (1). Closing log file.
This is an oldish laptop wih Nvidia GPU which is now unsupported by Nvidia and current kerne.
However is runs nicely on nouveau driver. in 6.9.11.
inxi -M -G -m
Machine:
  Type: Laptop System: Hewlett-Packard product: HP EliteBook 8770w
    v: A1029CD10000 serial: <superuser required>
  Mobo: Hewlett-Packard model: 176C v: KBC Version 50.1F
    serial: <superuser required> BIOS: Hewlett-Packard v: 68IAV Ver. F.66
    date: 07/13/2017
Memory:
  System RAM: total: 32 GiB available: 31.28 GiB used: 6.96 GiB (22.2%)
  Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
 Graphics:
  Device-1: NVIDIA GK104GLM [Quadro K3000M] driver: nouveau v: kernel
  Device-2: Chicony Integrated HP HD Webcam driver: uvcvideo type: USB
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 24.1.0 driver: X:
    loaded: nouveau dri: nouveau gpu: nouveau resolution: 1: 1920x1080~60Hz
    2: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: nouveau,swrast
    platforms: gbm,x11,surfaceless,device
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.1.3-2 renderer: NVE4
Your help is very much appreciated!
#2 2024-08-06 07:00:43
Re: [SOLVED] Xorg not starting with error "(EE) [drm] Failed to open DRM device .."
Does the user that starts Xorg have due access to /dev/dri/card0 ?
#3 2024-08-06 07:09:04
rdav
Hi ralph.ronnquist!
Xorg works with kernel linux-image-6.9.11-amd64 which is what I am using now to write this reply.
Just checking now:
~$ ls -la /dev/dri/card0
crw-rw----+ 1 root video 226, 0 Aug  6 15:45 /dev/dri/card0
~$ groups
rd cdrom floppy sudo audio dip video plugdev netdev input bluetooth lpadmin scanner libvirt
appears so!
#4 2024-08-06 10:28:42
Good. I suppose that error code "-19" means something particular but I don't really know how to find out what. You might want to drop in to the #devuan IRC channel on lilbera.chat where you're likely to find people that knows about graphics.
#5 2024-08-06 21:59:32
soren
What does your xorg.conf look like? Seems strange that it will work with kernel linux-image-6.9.11-amd64, so sounds like a config error where modules are not being loaded correctly. Im no expert on this, just throwing my two cents in.
#6 2024-08-11 03:10:04
rdav
Hi Soren,
This was with both not having /etc/X11/xorg.conf and my bespoke xorg.conf
Looking at dmesg for kernel 6.10.3 with non-working xorg, there is no mention of "nouveau"
whereas in kernel 6.9.11 with working xorg there are multiple lines with "nouveau".
After removing linux-image-6.10.3, synaptic reported that there were files remaining in /var/lib/modules/6.10.3
I removed this directory.
Reinstalling linux-image-6.10.3, synaptic reports
W: Possible missing firmware /lib/firmware/nvidia/ad107/gsp/gsp-535.113.01.bin for module nouveau
(multiple lines not shown)
Using Synaptic: searched for "firmware"; synaptic selected packages which were installed.
installed amd64-microcode (3.20240116.2+nmu1)
firmware-amd-graphics (20240709-1)
firmware-linux (20240709-1)
firmware-linux-nonfree (20240709-1)
firmware-nvidia-graphics (20240709-1)
intel-microcode (3.20240531.1+nmu1)
iucode-tool (2.3.1-3)
Reinstalled linux-image-6.10.3 to no errors with missing firmware.
Rebooting into 6.10.3, still had no X, only a prompt.
/var/log/X11.0.log still has "(EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19"
dmesg has no reference to "nouveau"
These files are posted below.
Your help to solve this problem is appreaciated!
Thanks in advance!
X11.0.log:
1 [    24.414]
  2 X.Org X Server 1.21.1.11
  3 X Protocol Version 11, Revision 0
  4 [    24.414] Current Operating System: Linux beanz 6.10.3-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.10.3-1 (2024-08-04) x86_64
  5 [    24.414] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.10.3-amd64 root=UUID=59d2e3aa-fbb4-4c21-a3ad-d0d7af3337b7 ro video=1024x768 quiet pcie_aspm=off module_bl    acklist=pcspkr
  6 [    24.414] xorg-server 2:21.1.12-1devuan1 (https://www.devuan.org/os/community)
  7 [    24.414] Current version of pixman: 0.42.2
  8 [    24.414]    Before reporting problems, check http://wiki.x.org
  9         to make sure that you have the latest version.
 10 [    24.414] Markers: (--) probed, (**) from config file, (==) default setting,
 11         (++) from command line, (!!) notice, (II) informational,
 12         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
 13 [    24.414] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Aug 11 12:42:25 2024
 14 [    24.416] (==) Using config file: "/etc/X11/xorg.conf"
 15 [    24.416] (==) Using config directory: "/etc/X11/xorg.conf.d"        16 [    24.416] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
 17 [    24.420] (**) Option "defaultserverlayout" "LayoutDual"
 18 [    24.420] (**) ServerLayout "LayoutDual"
 19 [    24.420] (**) |-->Screen "Screen0" (0)
 20 [    24.420] (**) |   |-->Monitor "<default monitor>"
 21 [    24.420] (**) |   |-->Device "Nvidia0"
 22 [    24.420] (==) No monitor specified for screen "Screen0".
 23         Using a default monitor configuration.
 24 [    24.420] (**) |-->Screen "Screen1" (1)
 25 [    24.420] (**) |   |-->Monitor "<default monitor>"
 26 [    24.420] (**) |   |-->Device "Nvidia1"
 27 [    24.420] (==) No monitor specified for screen "Screen1".
 28         Using a default monitor configuration.
 29 [    24.421] (**) Allowing byte-swapped clients
 30 [    24.421] (==) Automatically adding devices
 31 [    24.421] (==) Automatically enabling devices
 32 [    24.421] (==) Automatically adding GPU devices
 33 [    24.421] (==) Automatically binding GPU devices
 34 [    24.421] (==) Max clients allowed: 256, resource mask: 0x1fffff
 35 [    24.424] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
 36 [    24.424]    Entry deleted from font path.
 37 [    24.428] (==) FontPath set to:
 38         /usr/share/fonts/X11/misc,
 39         /usr/share/fonts/X11/100dpi/:unscaled,
 40         /usr/share/fonts/X11/75dpi/:unscaled,        41         /usr/share/fonts/X11/Type1,
 42         /usr/share/fonts/X11/100dpi,
 43         /usr/share/fonts/X11/75dpi,
44         built-ins
 45 [    24.428] (==) ModulePath set to "/usr/lib/xorg/modules"
 46 [    24.428] (II) The server relies on udev to provide the list of input devices.        47         If no devices become available, reconfigure udev or disable AutoAddDevices.
 48 [    24.428] (II) Loader magic: 0x55e3ba91dea0
 49 [    24.428] (II) Module ABI versions:
 50 [    24.428]    X.Org ANSI C Emulation: 0.4
 51 [    24.428]    X.Org Video Driver: 25.2
 52 [    24.428]    X.Org XInput driver : 24.4
 53 [    24.428]    X.Org Server Extension : 10.0
 54 [    24.428] (++) using VT number 7
 55
 56 [    24.428] (II) seat-libseat: libseat integration requires -keeptty and -keeptty was not provided, disabling libseat integration
 57 [    24.430] (--) PCI:*(1@0:0:0) 10de:11be:103c:176c rev 161, Mem @ 0xd8000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x???    ?????/131072
 58 [    24.430] (II) LoadModule: "glx"
 59 [    24.431] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
 60 [    24.440] (II) Module glx: vendor="X.Org Foundation"
 61 [    24.440]    compiled for 1.21.1.11, module version = 1.0.0
 62 [    24.440]    ABI class: X.Org Server Extension, version 10.0
 63 [    24.440] (II) LoadModule: "nouveau"
 64 [    24.441] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
 65 [    24.444] (II) Module nouveau: vendor="X.Org Foundation"
 66 [    24.444]    compiled for 1.21.1.11, module version = 1.0.17
 67 [    24.444]    Module class: X.Org Video Driver
 68 [    24.444]    ABI class: X.Org Video Driver, version 25.2
 69 [    24.444] (II) NOUVEAU driver Date:   Sat Jan 23 12:24:42 2021 -0500
 70 [    24.444] (II) NOUVEAU driver for NVIDIA chipset families :
 71 [    24.444]    RIVA TNT            (NV04)
 72 [    24.444]    RIVA TNT2           (NV05)
 73 [    24.444]    GeForce 256         (NV10)
 74 [    24.444]    GeForce 2           (NV11, NV15)
 75 [    24.444]    GeForce 4MX         (NV17, NV18)
 76 [    24.444]    GeForce 3           (NV20)
 77 [    24.444]    GeForce 4Ti         (NV25, NV28)
 78 [    24.444]    GeForce FX          (NV3x)
 79 [    24.444]    GeForce 6           (NV4x)
 80 [    24.444]    GeForce 7           (G7x)
 81 [    24.444]    GeForce 8           (G8x)        82 [    24.444]    GeForce 9           (G9x)
 83 [    24.444]    GeForce GTX 2xx/3xx (GT2xx)
 84 [    24.444]    GeForce GTX 4xx/5xx (GFxxx)
85 [    24.444]    GeForce GTX 6xx/7xx (GKxxx)
 86 [    24.444]    GeForce GTX 9xx     (GMxxx)
 87 [    24.444]    GeForce GTX 10xx    (GPxxx)
 88 [    25.028] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
 89 [    25.533] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
 90 [    26.053] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
 91 [    26.584] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
 92 [    26.584] (EE) No devices detected.
 93 [    26.584] (EE)
 94 Fatal server error:
 95 [    26.584] (EE) no screens found(EE)
 96 [    26.585] (EE)
 97 Please consult the The X.Org Foundation support
 98          at http://wiki.x.org        99  for help.
100 [    26.585] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
101 [    26.585] (EE)
102 [    26.674] (EE) Server terminated with error (1). Closing log file.
dmesg:
[    0.000000] Linux version 6.10.3-amd64 (debian-kernel@lists.debian.org) (x86_64-linux-gnu-gcc-13 (Debian 13.3.0-4) 13.3.0, GNU ld (GNU Binutils for Debian) 2.42.90.20240720) #1 SMP PREEMPT_DYNAMIC Debian 6.10.3-1 (2024-08-04)
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.10.3-amd64 root=UUID=59d2e3aa-fbb4-4c21-a3ad-d0d7af3337b7 ro video=1024x768 quiet pcie_aspm=off module_blacklist=pcspkr
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dbff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009dc00-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bd8fefff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bd8ff000-0x00000000bec7efff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bec7f000-0x00000000bef4afff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bef4b000-0x00000000bef7efff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000bef7f000-0x00000000beffefff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000befff000-0x00000000beffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000bf000000-0x00000000bfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed13fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed18000-0x00000000fed19fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000083dffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Hewlett-Packard HP EliteBook 8770w/176C, BIOS 68IAV Ver. F.66 07/13/2017
[    0.000000] DMI: Memory slots populated: 4/4
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2693.716 MHz processor
[    0.000987] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000991] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001000] last_pfn = 0x83e000 max_arch_pfn = 0x400000000
[    0.001005] MTRR map: 7 entries (3 fixed + 4 variable; max 23), built from 10 variable MTRRs
[    0.001008] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001296] last_pfn = 0xbf000 max_arch_pfn = 0x400000000
[    0.012669] RAMDISK: [mem 0x19d45000-0x28e99fff]
[    0.012675] ACPI: Early table checksum verification disabled
[    0.012679] ACPI: RSDP 0x00000000000F2F10 000024 (v02 HPQOEM)
[    0.012683] ACPI: XSDT 0x00000000BEFFE120 0000A4 (v01 HPQOEM SLIC-MPC 0000000F      01000013)
[    0.012689] ACPI: FACP 0x00000000BEFFC000 00010C (v05 HPQOEM 176C     0000000F HP   00000001)
[    0.012695] ACPI: DSDT 0x00000000BEFD6000 020987 (v02 HPQOEM 176C     00000001 INTL 20110112)
[    0.012699] ACPI: FACS 0x00000000BEC34000 000040
[    0.012702] ACPI: FACS 0x00000000BEC34000 000040
[    0.012705] ACPI: HPET 0x00000000BEFFB000 000038 (v01 HPQOEM 176C     00000001 HP   00000001)
[    0.012708] ACPI: APIC 0x00000000BEFFA000 0000BC (v01 HPQOEM 176C     00000001 HP   00000001)
[    0.012712] ACPI: MCFG 0x00000000BEFF9000 00003C (v01 HPQOEM 176C     00000001 HP   00000001)
[    0.012716] ACPI: TCPA 0x00000000BEFF7000 000032 (v02 HPQOEM 176C     00000000 HP   00000001)
[    0.012719] ACPI: SSDT 0x00000000BEFD3000 0002CA (v01 HPQOEM SataAhci 00001000 INTL 20110112)
[    0.012723] ACPI: SSDT 0x00000000BEFD2000 00048A (v01 HPQOEM PtidDevc 00001000 INTL 20110112)
[    0.012726] ACPI: SLIC 0x00000000BEFD1000 000176 (v01 HPQOEM SLIC-MPC 00000001 HP   00000001)
[    0.012730] ACPI: MSDM 0x00000000BEFD0000 000055 (v03 HPQOEM SLIC-MPC 00000000 HP   00000001)
[    0.012733] ACPI: FPDT 0x00000000BEFCF000 000044 (v01 HPQOEM 176C     00000001 HP   00000001)
[    0.012737] ACPI: BGRT 0x00000000BEFCE000 000038 (v00 HPQOEM 176C     00000001 HP   00000001)
[    0.012740] ACPI: SSDT 0x00000000BEFCB000 0019EF (v01 HPQOEM NVIDIAGF 00000001 INTL 20110112)
[    0.012744] ACPI: SSDT 0x00000000BEFCA000 0009B6 (v01 PmRef  Cpu0Ist  00003000 INTL 20110112)
[    0.012748] ACPI: SSDT 0x00000000BEFC9000 000AAD (v01 PmRef  CpuPm    00003000 INTL 20110112)
[    0.012751] ACPI: DMAR 0x00000000BEFC8000 000080 (v01 INTEL  SNB      00000001 INTL 00000001)
[    0.012755] ACPI: ASF! 0x00000000BEFF8000 0000A5 (v32 HPQOEM 176C     00000001 HP   00000001)
[    0.012758] ACPI: Reserving FACP table memory at [mem 0xbeffc000-0xbeffc10b]
[    0.012759] ACPI: Reserving DSDT table memory at [mem 0xbefd6000-0xbeff6986]
[    0.012760] ACPI: Reserving FACS table memory at [mem 0xbec34000-0xbec3403f]
[    0.012761] ACPI: Reserving FACS table memory at [mem 0xbec34000-0xbec3403f]
[    0.012762] ACPI: Reserving HPET table memory at [mem 0xbeffb000-0xbeffb037]
[    0.012764] ACPI: Reserving APIC table memory at [mem 0xbeffa000-0xbeffa0bb]
[    0.012764] ACPI: Reserving MCFG table memory at [mem 0xbeff9000-0xbeff903b]
[    0.012765] ACPI: Reserving TCPA table memory at [mem 0xbeff7000-0xbeff7031]
[    0.012766] ACPI: Reserving SSDT table memory at [mem 0xbefd3000-0xbefd32c9]
[    0.012768] ACPI: Reserving SSDT table memory at [mem 0xbefd2000-0xbefd2489]
[    0.012768] ACPI: Reserving SLIC table memory at [mem 0xbefd1000-0xbefd1175]
[    0.012769] ACPI: Reserving MSDM table memory at [mem 0xbefd0000-0xbefd0054]
[    0.012771] ACPI: Reserving FPDT table memory at [mem 0xbefcf000-0xbefcf043]
[    0.012772] ACPI: Reserving BGRT table memory at [mem 0xbefce000-0xbefce037]
[    0.012773] ACPI: Reserving SSDT table memory at [mem 0xbefcb000-0xbefcc9ee]
[    0.012774] ACPI: Reserving SSDT table memory at [mem 0xbefca000-0xbefca9b5]
[    0.012775] ACPI: Reserving SSDT table memory at [mem 0xbefc9000-0xbefc9aac]
[    0.012776] ACPI: Reserving DMAR table memory at [mem 0xbefc8000-0xbefc807f]
[    0.012777] ACPI: Reserving ASF! table memory at [mem 0xbeff8000-0xbeff80a4]
[    0.012842] No NUMA configuration found
[    0.012843] Faking a node at [mem 0x0000000000000000-0x000000083dffffff]
[    0.012854] NODE_DATA(0) allocated [mem 0x83dfb9000-0x83dfe3fff]
[    0.013156] Zone ranges:
[    0.013157]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.013159]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.013161]   Normal   [mem 0x0000000100000000-0x000000083dffffff]
[    0.013162]   Device   empty
[    0.013164] Movable zone start for each node
[    0.013167] Early memory node ranges
[    0.013167]   node   0: [mem 0x0000000000001000-0x000000000009cfff]
[    0.013169]   node   0: [mem 0x0000000000100000-0x00000000bd8fefff]
[    0.013171]   node   0: [mem 0x00000000bec7f000-0x00000000bef4afff]
[    0.013172]   node   0: [mem 0x00000000befff000-0x00000000beffffff]
[    0.013173]   node   0: [mem 0x0000000100000000-0x000000083dffffff]
[    0.013177] Initmem setup node 0 [mem 0x0000000000001000-0x000000083dffffff]
[    0.013183] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.013207] On node 0, zone DMA: 99 pages in unavailable ranges
[    0.018104] On node 0, zone DMA32: 4992 pages in unavailable ranges
[    0.018111] On node 0, zone DMA32: 180 pages in unavailable ranges
[    0.018427] On node 0, zone Normal: 4096 pages in unavailable ranges
[    0.018509] On node 0, zone Normal: 8192 pages in unavailable ranges
[    0.018812] ACPI: PM-Timer IO Port: 0x408
[    0.018823] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.018824] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.018826] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.018827] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.018828] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.018829] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.018830] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.018831] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.018841] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[    0.018844] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.018847] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.018852] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.018853] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.018859] TSC deadline timer available
[    0.018865] CPU topo: Max. logical packages:   1
[    0.018866] CPU topo: Max. logical dies:       1
[    0.018867] CPU topo: Max. dies per package:   1
[    0.018873] CPU topo: Max. threads per core:   2
[    0.018874] CPU topo: Num. cores per package:     4
[    0.018875] CPU topo: Num. threads per package:   8
[    0.018876] CPU topo: Allowing 8 present CPUs plus 0 hotplug CPUs
[    0.018894] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.018896] PM: hibernation: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[    0.018898] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[    0.018898] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.018899] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.018901] PM: hibernation: Registered nosave memory: [mem 0xbd8ff000-0xbec7efff]
[    0.018903] PM: hibernation: Registered nosave memory: [mem 0xbef4b000-0xbef7efff]
[    0.018904] PM: hibernation: Registered nosave memory: [mem 0xbef7f000-0xbeffefff]
[    0.018906] PM: hibernation: Registered nosave memory: [mem 0xbf000000-0xbfffffff]
[    0.018907] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xdfffffff]
[    0.018908] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.018909] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfebfffff]
[    0.018910] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.018911] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
[    0.018911] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed13fff]
[    0.018912] PM: hibernation: Registered nosave memory: [mem 0xfed14000-0xfed17fff]
[    0.018913] PM: hibernation: Registered nosave memory: [mem 0xfed18000-0xfed19fff]
[    0.018914] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
[    0.018915] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.018916] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.018917] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.018918] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffafffff]
[    0.018919] PM: hibernation: Registered nosave memory: [mem 0xffb00000-0xffffffff]
[    0.018921] [mem 0xc0000000-0xdfffffff] available for PCI devices
[    0.018923] Booting paravirtualized kernel on bare hardware
[    0.018926] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.024583] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[    0.025196] percpu: Embedded 65 pages/cpu s229376 r8192 d28672 u524288
[    0.025203] pcpu-alloc: s229376 r8192 d28672 u524288 alloc=1*2097152
[    0.025206] pcpu-alloc: [0] 0 1 2 3 [0] 4 5 6 7
[    0.025231] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.10.3-amd64 root=UUID=59d2e3aa-fbb4-4c21-a3ad-d0d7af3337b7 ro video=1024x768 quiet pcie_aspm=off module_blacklist=pcspkr
[    0.025312] PCIe ASPM is disabled
[    0.025318] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.10.3-amd64", will be passed to user space.
[    0.025327] random: crng init done
[    0.028679] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.030397] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.030535] Fallback order for Node 0: 0
[    0.030539] Built 1 zonelists, mobility grouping on.  Total pages: 8371048
[    0.030540] Policy zone: Normal
[    0.030550] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.030560] software IO TLB: area num 8.
[    0.058128] Memory: 2925784K/33484192K available (16384K kernel code, 2422K rwdata, 11044K rodata, 4104K init, 5320K bss, 935124K reserved, 0K cma-reserved)
[    0.058420] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.058453] Kernel/User page tables isolation: enabled
[    0.058496] ftrace: allocating 44506 entries in 174 pages
[    0.066873] ftrace: allocated 174 pages with 5 groups
[    0.067622] Dynamic Preempt: voluntary
[    0.067684] rcu: Preemptible hierarchical RCU implementation.
[    0.067685] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
[    0.067687] 	Trampoline variant of Tasks RCU enabled.
[    0.067687] 	Rude variant of Tasks RCU enabled.
[    0.067688] 	Tracing variant of Tasks RCU enabled.
[    0.067689] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.067690] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.067699] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.067701] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.067703] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1.
[    0.070978] NR_IRQS: 524544, nr_irqs: 488, preallocated irqs: 16
[    0.071187] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.071273] Console: colour dummy device 80x25
[    0.071276] printk: legacy console [tty0] enabled
[    0.071319] ACPI: Core revision 20240322
[    0.071475] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.071490] APIC: Switch to symmetric I/O mode setup
[    0.071492] DMAR: Host address width 36
[    0.071494] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[    0.071499] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c9008020660262 ecap f0105a
[    0.071502] DMAR: RMRR base: 0x000000bec0f000 end: 0x000000bec2efff
[    0.071505] DMAR-IR: IOAPIC id 0 under DRHD base  0xfed90000 IOMMU 0
[    0.071507] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[    0.071508] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.071801] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.071804] x2apic enabled
[    0.071870] APIC: Switched APIC routing to: cluster x2apic
[    0.072296] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.091492] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x26d40e71c15, max_idle_ns: 440795300989 ns
[    0.091497] Calibrating delay loop (skipped), value calculated using timer frequency.. 5387.43 BogoMIPS (lpj=10774864)
[    0.091524] CPU0: Thermal monitoring enabled (TM1)
[    0.091550] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[    0.091552] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.091555] process: using mwait in idle threads
[    0.091557] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.091560] Spectre V2 : Mitigation: Retpolines
[    0.091561] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.091562] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[    0.091563] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.091565] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.091566] Spectre V2 : User space: Mitigation: STIBP via prctl
[    0.091568] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.091570] MDS: Mitigation: Clear CPU buffers
[    0.091571] MMIO Stale Data: Unknown: No mitigations
[    0.091572] SRBDS: Vulnerable: No microcode
[    0.091577] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.091578] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.091579] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.091581] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.091582] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.112886] Freeing SMP alternatives memory: 40K
[    0.112894] pid_max: default: 32768 minimum: 301
[    0.112939] LSM: initializing lsm=lockdown,capability,landlock,yama,apparmor,tomoyo,bpf,ima,evm
[    0.112954] landlock: Up and running.
[    0.112955] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.112982] AppArmor: AppArmor initialized
[    0.112984] TOMOYO Linux initialized
[    0.112989] LSM support for eBPF active
[    0.113046] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.113080] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.115102] smpboot: CPU0: Intel(R) Core(TM) i7-3740QM CPU @ 2.70GHz (family: 0x6, model: 0x3a, stepping: 0x9)
[    0.115334] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.115352] ... version:                3
[    0.115353] ... bit width:              48
[    0.115354] ... generic registers:      4
[    0.115355] ... value mask:             0000ffffffffffff
[    0.115356] ... max period:             00007fffffffffff
[    0.115357] ... fixed-purpose events:   3
[    0.115358] ... event mask:             000000070000000f
[    0.115495] signal: max sigframe size: 1776
[    0.115495] Estimated ratio of average max frequency by base frequency (times 1024): 1327
[    0.115495] rcu: Hierarchical SRCU implementation.
[    0.115495] rcu: 	Max phase no-delay instances is 1000.
[    0.115495] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.115495] smp: Bringing up secondary CPUs ...
[    0.115495] smpboot: x86: Booting SMP configuration:
[    0.115495] .... node  #0, CPUs:      #2 #4 #6 #1 #3 #5 #7
[    0.121500] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.127541] smp: Brought up 1 node, 8 CPUs
[    0.127541] smpboot: Total of 8 processors activated (43099.45 BogoMIPS)
[    0.177394] node 0 deferred pages initialised in 52ms
[    0.180525] devtmpfs: initialized
[    0.180525] x86/mm: Memory block size: 128MB
[    0.184553] ACPI: PM: Registering ACPI NVS region [mem 0xbef4b000-0xbef7efff] (212992 bytes)
[    0.184553] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.184553] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.184553] pinctrl core: initialized pinctrl subsystem
[    0.184553] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.184627] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.184895] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.185166] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.185190] audit: initializing netlink subsys (disabled)
[    0.185213] audit: type=2000 audit(1723344120.112:1): state=initialized audit_enabled=0 res=1
[    0.185213] thermal_sys: Registered thermal governor 'fair_share'
[    0.185213] thermal_sys: Registered thermal governor 'bang_bang'
[    0.185213] thermal_sys: Registered thermal governor 'step_wise'
[    0.185213] thermal_sys: Registered thermal governor 'user_space'
[    0.185213] thermal_sys: Registered thermal governor 'power_allocator'
[    0.185213] cpuidle: using governor ladder
[    0.185213] cpuidle: using governor menu
[    0.185213] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.185213] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.185213] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.185213] PCI: Using configuration type 1 for base access
[    0.185213] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[    0.185213] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.185213] mtrr: probably your BIOS does not setup all CPUs.
[    0.185213] mtrr: corrected configuration.
[    0.185213] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.185213] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.185213] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.185213] Demotion targets for Node 0: null
[    0.185213] ACPI: Added _OSI(Module Device)
[    0.185213] ACPI: Added _OSI(Processor Device)
[    0.185213] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.185213] ACPI: Added _OSI(Processor Aggregator Device)
[    0.199277] ACPI: 6 ACPI AML tables successfully acquired and loaded
[    0.200116] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.219744] ACPI: Dynamic OEM Table Load:
[    0.219753] ACPI: SSDT 0xFFFF8EAC40D30000 000861 (v01 PmRef  Cpu0Cst  00003001 INTL 20110112)
[    0.220268] ACPI: Dynamic OEM Table Load:
[    0.220274] ACPI: SSDT 0xFFFF8EB288FC2000 000303 (v01 PmRef  ApIst    00003000 INTL 20110112)
[    0.220702] ACPI: Dynamic OEM Table Load:
[    0.220706] ACPI: SSDT 0xFFFF8EB288F7BA00 000119 (v01 PmRef  ApCst    00003000 INTL 20110112)
[    0.221990] ACPI: _OSC evaluated successfully for all CPUs
[    0.222033] ACPI: EC: EC started
[    0.222034] ACPI: EC: interrupt blocked
[    2.208937] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    2.208941] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    2.208943] ACPI: Interpreter enabled
[    2.208963] ACPI: PM: (supports S0 S3 S4 S5)
[    2.208964] ACPI: Using IOAPIC for interrupt routing
[    2.208991] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    2.208993] PCI: Using E820 reservations for host bridge windows
[    2.209193] ACPI: Enabled 7 GPEs in block 00 to 3F
[    2.211480] ACPI: \_SB_.PCI0.HDEF.APPR: New power resource
[    2.213972] ACPI: \_SB_.PCI0.LPCB.SIO_.COM1.COMP: New power resource
[    2.214532] ACPI: \_SB_.PCI0.LPCB.SIO_.LPT0.LPP_: New power resource
[    2.217483] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    2.217490] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig Segments MSI HPX-Type3]
[    2.217493] acpi PNP0A08:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
[    2.217852] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    2.218312] PCI host bridge to bus 0000:00
[    2.218315] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    2.218317] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    2.218319] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    2.218320] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff window]
[    2.218322] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfedfffff window]
[    2.218324] pci_bus 0000:00: root bus resource [mem 0xfee01000-0xffffffff window]
[    2.218326] pci_bus 0000:00: root bus resource [bus 00-3e]
[    2.218342] pci 0000:00:00.0: [8086:0154] type 00 class 0x060000 conventional PCI endpoint
[    2.218422] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400 PCIe Root Port
[    2.218434] pci 0000:00:01.0: PCI bridge to [bus 01]
[    2.218437] pci 0000:00:01.0:   bridge window [io  0x5000-0x5fff]
[    2.218440] pci 0000:00:01.0:   bridge window [mem 0xd8000000-0xd90fffff]
[    2.218445] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    2.218475] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    2.218586] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330 conventional PCI endpoint
[    2.218605] pci 0000:00:14.0: BAR 0 [mem 0xd9520000-0xd952ffff 64bit]
[    2.218672] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    2.218756] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000 conventional PCI endpoint
[    2.218777] pci 0000:00:16.0: BAR 0 [mem 0xd9535000-0xd953500f 64bit]
[    2.218858] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    2.218924] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000 conventional PCI endpoint
[    2.218939] pci 0000:00:19.0: BAR 0 [mem 0xd9500000-0xd951ffff]
[    2.218947] pci 0000:00:19.0: BAR 1 [mem 0xd953b000-0xd953bfff]
[    2.218956] pci 0000:00:19.0: BAR 2 [io  0x6040-0x605f]
[    2.219021] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[    2.219098] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320 conventional PCI endpoint
[    2.219115] pci 0000:00:1a.0: BAR 0 [mem 0xd953a000-0xd953a3ff]
[    2.219206] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    2.219292] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300 PCIe Root Complex Integrated Endpoint
[    2.219310] pci 0000:00:1b.0: BAR 0 [mem 0xd9530000-0xd9533fff 64bit]
[    2.219393] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    2.219493] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400 PCIe Root Port
[    2.219524] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    2.219531] pci 0000:00:1c.0:   bridge window [mem 0xd9400000-0xd94fffff]
[    2.219611] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    2.219636] pci 0000:00:1c.0: Enabling MPC IRBNCE
[    2.219639] pci 0000:00:1c.0: Intel PCH root port ACS workaround enabled
[    2.219724] pci 0000:00:1c.1: [8086:1e12] type 01 class 0x060400 PCIe Root Port
[    2.219754] pci 0000:00:1c.1: PCI bridge to [bus 03-23]
[    2.219759] pci 0000:00:1c.1:   bridge window [io  0x3000-0x4fff]
[    2.219764] pci 0000:00:1c.1:   bridge window [mem 0xd4000000-0xd7ffffff]
[    2.219843] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    2.219865] pci 0000:00:1c.1: Enabling MPC IRBNCE
[    2.219868] pci 0000:00:1c.1: Intel PCH root port ACS workaround enabled
[    2.219958] pci 0000:00:1c.2: [8086:1e14] type 01 class 0x060400 PCIe Root Port
[    2.219988] pci 0000:00:1c.2: PCI bridge to [bus 24]
[    2.219995] pci 0000:00:1c.2:   bridge window [mem 0xd9300000-0xd93fffff]
[    2.220074] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    2.220097] pci 0000:00:1c.2: Enabling MPC IRBNCE
[    2.220100] pci 0000:00:1c.2: Intel PCH root port ACS workaround enabled
[    2.220194] pci 0000:00:1c.3: [8086:1e16] type 01 class 0x060400 PCIe Root Port
[    2.220224] pci 0000:00:1c.3: PCI bridge to [bus 25]
[    2.220231] pci 0000:00:1c.3:   bridge window [mem 0xd9200000-0xd92fffff]
[    2.220309] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    2.220332] pci 0000:00:1c.3: Enabling MPC IRBNCE
[    2.220335] pci 0000:00:1c.3: Intel PCH root port ACS workaround enabled
[    2.220427] pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400 PCIe Root Port
[    2.220457] pci 0000:00:1c.4: PCI bridge to [bus 26]
[    2.220462] pci 0000:00:1c.4:   bridge window [io  0x2000-0x2fff]
[    2.220466] pci 0000:00:1c.4:   bridge window [mem 0xd9100000-0xd91fffff]
[    2.220545] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    2.220567] pci 0000:00:1c.4: Enabling MPC IRBNCE
[    2.220570] pci 0000:00:1c.4: Intel PCH root port ACS workaround enabled
[    2.220655] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320 conventional PCI endpoint
[    2.220671] pci 0000:00:1d.0: BAR 0 [mem 0xd9539000-0xd95393ff]
[    2.220762] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    2.220850] pci 0000:00:1f.0: [8086:1e55] type 00 class 0x060100 conventional PCI endpoint
[    2.221044] pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601 conventional PCI endpoint
[    2.221058] pci 0000:00:1f.2: BAR 0 [io  0x6068-0x606f]
[    2.221065] pci 0000:00:1f.2: BAR 1 [io  0x6074-0x6077]
[    2.221073] pci 0000:00:1f.2: BAR 2 [io  0x6060-0x6067]
[    2.221081] pci 0000:00:1f.2: BAR 3 [io  0x6070-0x6073]
[    2.221089] pci 0000:00:1f.2: BAR 4 [io  0x6020-0x603f]
[    2.221096] pci 0000:00:1f.2: BAR 5 [mem 0xd9538000-0xd95387ff]
[    2.221143] pci 0000:00:1f.2: PME# supported from D3hot
[    2.221215] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500 conventional PCI endpoint
[    2.221233] pci 0000:00:1f.3: BAR 0 [mem 0xd9534000-0xd95340ff 64bit]
[    2.221254] pci 0000:00:1f.3: BAR 4 [io  0xef80-0xef9f]
[    2.221377] pci 0000:01:00.0: [10de:11be] type 00 class 0x030000 PCIe Endpoint
[    2.221389] pci 0000:01:00.0: BAR 0 [mem 0xd8000000-0xd8ffffff]
[    2.221398] pci 0000:01:00.0: BAR 1 [mem 0xc0000000-0xcfffffff 64bit pref]
[    2.221408] pci 0000:01:00.0: BAR 3 [mem 0xd0000000-0xd1ffffff 64bit pref]
[    2.221415] pci 0000:01:00.0: BAR 5 [io  0x5000-0x507f]
[    2.221421] pci 0000:01:00.0: ROM [mem 0xfff80000-0xffffffff pref]
[    2.221448] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    2.221507] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    2.222009] pci 0000:01:00.1: [10de:0e0a] type 00 class 0x040300 PCIe Endpoint
[    2.222022] pci 0000:01:00.1: BAR 0 [mem 0xd9000000-0xd9003fff]
[    2.222138] pci 0000:00:01.0: PCI bridge to [bus 01]
[    2.222184] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    2.222260] acpiphp: Slot [1] registered
[    2.222288] pci 0000:00:1c.1: PCI bridge to [bus 03-23]
[    2.222408] pci 0000:24:00.0: [197b:2380] type 00 class 0x0c0010 PCIe Endpoint
[    2.222450] pci 0000:24:00.0: BAR 0 [mem 0xd9300000-0xd93007ff]
[    2.222474] pci 0000:24:00.0: BAR 1 [mem 0xd9305000-0xd93050ff]
[    2.222892] pci 0000:24:00.1: [197b:2392] type 00 class 0x088000 PCIe Endpoint
[    2.222928] pci 0000:24:00.1: BAR 0 [mem 0xd9304000-0xd93040ff]
[    2.223042] pci 0000:24:00.1: ROM [mem 0xffff8000-0xffffffff pref]
[    2.223319] pci 0000:24:00.2: [197b:2391] type 00 class 0x080501 PCIe Endpoint
[    2.223355] pci 0000:24:00.2: BAR 0 [mem 0xd9303000-0xd93030ff]
[    2.223723] pci 0000:00:1c.2: PCI bridge to [bus 24]
[    2.224004] pci 0000:25:00.0: [8086:422b] type 00 class 0x028000 PCIe Endpoint
[    2.224181] pci 0000:25:00.0: BAR 0 [mem 0xd9200000-0xd9201fff 64bit]
[    2.225063] pci 0000:25:00.0: PME# supported from D0 D3hot D3cold
[    2.225620] pci 0000:00:1c.3: PCI bridge to [bus 25]
[    2.225720] pci 0000:26:00.0: [197b:2360] type 00 class 0x010601 PCIe Legacy Endpoint
[    2.225756] pci 0000:26:00.0: BAR 0 [io  0x2018-0x201f]
[    2.225775] pci 0000:26:00.0: BAR 1 [io  0x2024-0x2027]
[    2.225795] pci 0000:26:00.0: BAR 2 [io  0x2010-0x2017]
[    2.225814] pci 0000:26:00.0: BAR 3 [io  0x2020-0x2023]
[    2.225833] pci 0000:26:00.0: BAR 4 [io  0x2000-0x200f]
[    2.225852] pci 0000:26:00.0: BAR 5 [mem 0xd9100000-0xd91001ff]
[    2.225872] pci 0000:26:00.0: ROM [mem 0xffff0000-0xffffffff pref]
[    2.225992] pci 0000:26:00.0: PME# supported from D3hot
[    2.226108] pci 0000:00:1c.4: PCI bridge to [bus 26]
[    2.227123] ACPI: PCI: Interrupt link LNKA configured for IRQ 10
[    2.227162] ACPI: PCI: Interrupt link LNKB configured for IRQ 5
[    2.227198] ACPI: PCI: Interrupt link LNKC configured for IRQ 10
[    2.227233] ACPI: PCI: Interrupt link LNKD configured for IRQ 10
[    2.227269] ACPI: PCI: Interrupt link LNKE configured for IRQ 11
[    2.227304] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    2.227305] ACPI: PCI: Interrupt link LNKF disabled
[    2.227340] ACPI: PCI: Interrupt link LNKG configured for IRQ 10
[    2.227376] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    2.227378] ACPI: PCI: Interrupt link LNKH disabled
[    2.227783] ACPI: EC: interrupt unblocked
[    2.227785] ACPI: EC: event unblocked
[    2.227787] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    2.227788] ACPI: EC: GPE=0x16
[    2.227790] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[    2.227792] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[    2.227851] iommu: Default domain type: Translated
[    2.227851] iommu: DMA domain TLB invalidation policy: lazy mode
[    2.227851] pps_core: LinuxPPS API ver. 1 registered
[    2.227851] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    2.227851] PTP clock support registered
[    2.227851] EDAC MC: Ver: 3.0.0
[    2.227851] NetLabel: Initializing
[    2.227851] NetLabel:  domain hash size = 128
[    2.227851] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    2.227851] NetLabel:  unlabeled traffic allowed by default
[    2.227851] PCI: Using ACPI for IRQ routing
[    2.231926] PCI: pci_cache_line_size set to 64 bytes
[    2.232047] e820: reserve RAM buffer [mem 0x0009dc00-0x0009ffff]
[    2.232050] e820: reserve RAM buffer [mem 0xbd8ff000-0xbfffffff]
[    2.232051] e820: reserve RAM buffer [mem 0xbef4b000-0xbfffffff]
[    2.232053] e820: reserve RAM buffer [mem 0xbf000000-0xbfffffff]
[    2.232054] e820: reserve RAM buffer [mem 0x83e000000-0x83fffffff]
[    2.232092] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    2.232092] pci 0000:01:00.0: vgaarb: bridge control possible
[    2.232092] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    2.232092] vgaarb: loaded
[    2.232092] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    2.232092] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    2.235496] clocksource: Switched to clocksource tsc-early
[    2.235505] VFS: Disk quotas dquot_6.6.0
[    2.235505] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.235505] AppArmor: AppArmor Filesystem Enabled
[    2.235505] pnp: PnP ACPI init
[    2.235505] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    2.235505] system 00:00: [mem 0xfed10000-0xfed17fff] could not be reserved
[    2.235505] system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
[    2.235505] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
[    2.235505] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[    2.235505] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
[    2.235505] system 00:00: [mem 0xfed90000-0xfed93fff] could not be reserved
[    2.235505] system 00:00: [mem 0xfed45000-0xfed8ffff] has been reserved
[    2.235505] system 00:00: [mem 0xfec00000-0xfec00fff] could not be reserved
[    2.236842] system 00:02: [io  0x0200-0x027f] has been reserved
[    2.236845] system 00:02: [io  0x1000-0x100f] has been reserved
[    2.236847] system 00:02: [io  0xffff] has been reserved
[    2.236849] system 00:02: [io  0xffff] has been reserved
[    2.236851] system 00:02: [io  0x0400-0x047f] has been reserved
[    2.236852] system 00:02: [io  0x0500-0x057f] has been reserved
[    2.236854] system 00:02: [io  0xef80-0xef9f] has been reserved
[    2.237463] pnp 00:05: [dma 0 disabled]
[    2.237881] pnp: PnP ACPI: found 8 devices
[    2.243847] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    2.243908] NET: Registered PF_INET protocol family
[    2.244058] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    2.259023] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    2.259066] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    2.259192] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    2.259522] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    2.259799] TCP: Hash tables configured (established 262144 bind 65536)
[    2.259930] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[    2.260021] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    2.260105] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    2.260201] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    2.260209] NET: Registered PF_XDP protocol family
[    2.260215] pci 0000:24:00.1: ROM [mem 0xffff8000-0xffffffff pref]: can't claim; no compatible bridge window
[    2.260219] pci 0000:26:00.0: ROM [mem 0xffff0000-0xffffffff pref]: can't claim; no compatible bridge window
[    2.260226] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-23] add_size 200000 add_align 100000
[    2.260239] pci 0000:00:1c.1: bridge window [mem 0xd2000000-0xd21fffff 64bit pref]: assigned
[    2.260243] pci 0000:00:01.0: PCI bridge to [bus 01]
[    2.260246] pci 0000:00:01.0:   bridge window [io  0x5000-0x5fff]
[    2.260249] pci 0000:00:01.0:   bridge window [mem 0xd8000000-0xd90fffff]
[    2.260251] pci 0000:00:01.0:   bridge window [mem 0xc0000000-0xd1ffffff 64bit pref]
[    2.260255] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    2.260260] pci 0000:00:1c.0:   bridge window [mem 0xd9400000-0xd94fffff]
[    2.260269] pci 0000:00:1c.1: PCI bridge to [bus 03-23]
[    2.260272] pci 0000:00:1c.1:   bridge window [io  0x3000-0x4fff]
[    2.260293] pci 0000:00:1c.1:   bridge window [mem 0xd4000000-0xd7ffffff]
[    2.260299] pci 0000:00:1c.1:   bridge window [mem 0xd2000000-0xd21fffff 64bit pref]
[    2.260328] pci 0000:24:00.1: ROM [mem 0xd9308000-0xd930ffff pref]: assigned
[    2.260331] pci 0000:00:1c.2: PCI bridge to [bus 24]
[    2.260336] pci 0000:00:1c.2:   bridge window [mem 0xd9300000-0xd93fffff]
[    2.260345] pci 0000:00:1c.3: PCI bridge to [bus 25]
[    2.260350] pci 0000:00:1c.3:   bridge window [mem 0xd9200000-0xd92fffff]
[    2.260359] pci 0000:26:00.0: ROM [mem 0xd9110000-0xd911ffff pref]: assigned
[    2.260361] pci 0000:00:1c.4: PCI bridge to [bus 26]
[    2.260364] pci 0000:00:1c.4:   bridge window [io  0x2000-0x2fff]
[    2.260369] pci 0000:00:1c.4:   bridge window [mem 0xd9100000-0xd91fffff]
[    2.260378] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    2.260380] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    2.260382] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    2.260383] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xdfffffff window]
[    2.260385] pci_bus 0000:00: resource 8 [mem 0xf0000000-0xfedfffff window]
[    2.260386] pci_bus 0000:00: resource 9 [mem 0xfee01000-0xffffffff window]
[    2.260388] pci_bus 0000:01: resource 0 [io  0x5000-0x5fff]
[    2.260389] pci_bus 0000:01: resource 1 [mem 0xd8000000-0xd90fffff]
[    2.260391] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xd1ffffff 64bit pref]
[    2.260393] pci_bus 0000:02: resource 1 [mem 0xd9400000-0xd94fffff]
[    2.260394] pci_bus 0000:03: resource 0 [io  0x3000-0x4fff]
[    2.260396] pci_bus 0000:03: resource 1 [mem 0xd4000000-0xd7ffffff]
[    2.260397] pci_bus 0000:03: resource 2 [mem 0xd2000000-0xd21fffff 64bit pref]
[    2.260399] pci_bus 0000:24: resource 1 [mem 0xd9300000-0xd93fffff]
[    2.260400] pci_bus 0000:25: resource 1 [mem 0xd9200000-0xd92fffff]
[    2.260402] pci_bus 0000:26: resource 0 [io  0x2000-0x2fff]
[    2.260404] pci_bus 0000:26: resource 1 [mem 0xd9100000-0xd91fffff]
[    2.260482] pci 0000:00:14.0: enabling device (0000 -> 0002)
[    2.260586] pci 0000:00:14.0: can't derive routing for PCI INT A
[    2.260588] pci 0000:00:14.0: PCI INT A: no GSI
[    2.261065] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[    2.261099] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    2.261150] PCI: CLS 64 bytes, default 64
[    2.261209] DMAR: No ATSR found
[    2.261211] DMAR: No SATC found
[    2.261213] DMAR: dmar0: Using Queued invalidation
[    2.261282] Trying to unpack rootfs image as initramfs...
[    2.261313] pci 0000:00:00.0: Adding to iommu group 0
[    2.261338] pci 0000:00:01.0: Adding to iommu group 1
[    2.261353] pci 0000:00:14.0: Adding to iommu group 2
[    2.261375] pci 0000:00:16.0: Adding to iommu group 3
[    2.261392] pci 0000:00:19.0: Adding to iommu group 4
[    2.261407] pci 0000:00:1a.0: Adding to iommu group 5
[    2.261424] pci 0000:00:1b.0: Adding to iommu group 6
[    2.261440] pci 0000:00:1c.0: Adding to iommu group 7
[    2.261457] pci 0000:00:1c.1: Adding to iommu group 8
[    2.261473] pci 0000:00:1c.2: Adding to iommu group 9
[    2.261490] pci 0000:00:1c.3: Adding to iommu group 10
[    2.261506] pci 0000:00:1c.4: Adding to iommu group 11
[    2.261521] pci 0000:00:1d.0: Adding to iommu group 12
[    2.261553] pci 0000:00:1f.0: Adding to iommu group 13
[    2.261570] pci 0000:00:1f.2: Adding to iommu group 13
[    2.261586] pci 0000:00:1f.3: Adding to iommu group 13
[    2.261593] pci 0000:01:00.0: Adding to iommu group 1
[    2.261600] pci 0000:01:00.1: Adding to iommu group 1
[    2.261634] pci 0000:24:00.0: Adding to iommu group 14
[    2.261651] pci 0000:24:00.1: Adding to iommu group 14
[    2.261668] pci 0000:24:00.2: Adding to iommu group 14
[    2.261684] pci 0000:25:00.0: Adding to iommu group 15
[    2.261699] pci 0000:26:00.0: Adding to iommu group 16
[    2.263638] DMAR: Intel(R) Virtualization Technology for Directed I/O
[    2.263644] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    2.263646] software IO TLB: mapped [mem 0x00000000b98ff000-0x00000000bd8ff000] (64MB)
[    2.264332] Initialise system trusted keyrings
[    2.264344] Key type blacklist registered
[    2.264403] workingset: timestamp_bits=36 max_order=23 bucket_order=0
[    2.264415] zbud: loaded
[    2.264528] fuse: init (API version 7.40)
[    2.264713] integrity: Platform Keyring initialized
[    2.264719] integrity: Machine keyring initialized
[    2.287505] Key type asymmetric registered
[    2.287512] Asymmetric key parser 'x509' registered
[    3.242770] Freeing initrd memory: 247124K
[    3.248311] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    3.248347] io scheduler mq-deadline registered
[    3.250103] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    3.272306] tsc: Refined TSC clocksource calibration: 2693.876 MHz
[    3.272321] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26d4a4ff17e, max_idle_ns: 440795216455 ns
[    3.272371] clocksource: Switched to clocksource tsc
[    3.276478] thermal LNXTHERM:00: registered as thermal_zone0
[    3.276485] ACPI: thermal: Thermal Zone [CPUZ] (69 C)
[    3.300440] thermal LNXTHERM:01: registered as thermal_zone1
[    3.300446] ACPI: thermal: Thermal Zone [GFXZ] (63 C)
[    3.316369] thermal LNXTHERM:02: registered as thermal_zone2
[    3.316377] ACPI: thermal: Thermal Zone [EXTZ] (53 C)
[    3.331314] thermal LNXTHERM:03: registered as thermal_zone3
[    3.331321] ACPI: thermal: Thermal Zone [LOCZ] (52 C)
[    3.346348] thermal LNXTHERM:04: registered as thermal_zone4
[    3.346355] ACPI: thermal: Thermal Zone [BATZ] (32 C)
[    3.346686] thermal LNXTHERM:05: registered as thermal_zone5
[    3.346690] ACPI: thermal: Thermal Zone [PCHZ] (127 C)
[    3.346958] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.347222] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    3.348416] Linux agpgart interface v0.103
[    3.353820] tpm_tis 00:01: 1.2 TPM (device-id 0xB, rev-id 16)
[    3.408426] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    3.410261] i8042: Detected active multiplexing controller, rev 1.1
[    3.411025] serio: i8042 KBD port at 0x60,0x64 irq 1
[    3.411032] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[    3.411067] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[    3.411089] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[    3.411108] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[    3.411370] mousedev: PS/2 mouse device common for all mice
[    3.411419] rtc_cmos 00:03: RTC can wake from S4
[    3.411795] rtc_cmos 00:03: registered as rtc0
[    3.411832] rtc_cmos 00:03: setting system clock to 2024-08-11T02:42:04 UTC (1723344124)
[    3.411865] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram
[    3.412102] intel_pstate: Intel P-state driver initializing
[    3.413006] ledtrig-cpu: registered to indicate activity on CPUs
[    3.413333] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[    3.413338] vesafb: scrolling: redraw
[    3.413340] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    3.413362] vesafb: framebuffer at 0xd1000000, mapped to 0x0000000028111cbd, using 3072k, total 3072k
[    3.413603] Console: switching to colour frame buffer device 128x48
[    3.456067] fb0: VESA VGA frame buffer device
[    3.456212] NET: Registered PF_INET6 protocol family
[    3.466378] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[    3.466404] Segment Routing with IPv6
[    3.466420] In-situ OAM (IOAM) with IPv6
[    3.466445] mip6: Mobile IPv6
[    3.466450] NET: Registered PF_PACKET protocol family
[    3.466585] mpls_gso: MPLS GSO support
[    3.467628] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    3.468020] microcode: Current revision: 0x00000021
[    3.468025] microcode: Updated early from: 0x00000016
[    3.468244] IPI shorthand broadcast: enabled
[    3.469727] sched_clock: Marking stable (3468003273, 275907)->(3478976122, -10696942)
[    3.469979] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    3.470236] registered taskstats version 1
[    3.470388] Loading compiled-in X.509 certificates
[    3.498322] Loaded X.509 cert 'Build time autogenerated kernel key: ed38225d83298b5ecbfa5ee2532ab8e8e5ec2419'
[    3.500403] Demotion targets for Node 0: null
[    3.500655] Key type .fscrypt registered
[    3.500660] Key type fscrypt-provisioning registered
[    3.527894] Key type encrypted registered
[    3.527910] AppArmor: AppArmor sha256 policy hashing enabled
[    3.527935] ima: Allocated hash algorithm: sha256
[    3.650573] ima: No architecture policies found
[    3.650620] evm: Initialising EVM extended attributes:
[    3.650622] evm: security.selinux
[    3.650624] evm: security.SMACK64 (disabled)
[    3.650625] evm: security.SMACK64EXEC (disabled)
[    3.650626] evm: security.SMACK64TRANSMUTE (disabled)
[    3.650627] evm: security.SMACK64MMAP (disabled)
[    3.650628] evm: security.apparmor
[    3.650629] evm: security.ima
[    3.650630] evm: security.capability
[    3.650632] evm: HMAC attrs: 0x1
[    3.850593] RAS: Correctable Errors collector initialized.
[    3.875969] clk: Disabling unused clocks
[    3.875978] PM: genpd: Disabling unused power domains
[    3.878611] Freeing unused decrypted memory: 2028K
[    3.879712] Freeing unused kernel image (initmem) memory: 4104K
[    3.879848] Write protecting the kernel read-only data: 28672k
[    3.881020] Freeing unused kernel image (rodata/data gap) memory: 1244K
[    3.956024] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    3.956027] x86/mm: Checking user space page tables
[    3.994199] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    3.994205] Run /init as init process
[    3.994206]   with arguments:
[    3.994207]     /init
[    3.994208]   with environment:
[    3.994209]     HOME=/
[    3.994210]     TERM=linux
[    3.994210]     BOOT_IMAGE=/boot/vmlinuz-6.10.3-amd64
[    4.021110] udevd[198]: starting version 3.2.14
[    4.022161] udevd[199]: starting eudev-3.2.14
[    4.038943] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5
[    4.038993] ACPI: button: Sleep Button [SLPB]
[    4.039056] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input6
[    4.039107] ACPI: button: Lid Switch [LID]
[    4.039163] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
[    4.040588] wmi_bus wmi_bus-PNP0C14:01: [Firmware Info]: 8F1F6436-9F42-42C8-BADC-0E9424F20C9A has zero instances
[    4.044690] ACPI: video: Video Device [DGFX] (multi-head: yes  rom: yes  post: no)
[    4.046534] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input8
[    4.048322] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20240322/utaddress-204)
[    4.048330] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    4.048335] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20240322/utaddress-204)
[    4.048341] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    4.048343] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20240322/utaddress-204)
[    4.048347] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    4.048349] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20240322/utaddress-204)
[    4.048354] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[    4.048355] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    4.053311] ACPI: button: Power Button [PWRF]
[    4.058208] e1000e: Intel(R) PRO/1000 Network Driver
[    4.058210] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.058364] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    4.065950] ACPI: bus type USB registered
[    4.065973] usbcore: registered new interface driver usbfs
[    4.065980] usbcore: registered new interface driver hub
[    4.065991] usbcore: registered new device driver usb
[    4.147621] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
[    4.148226] ACPI: battery: Slot [BAT0] (battery present)
[    4.148319] ACPI: battery: Slot [BAT1] (battery absent)
[    4.151258] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    4.152307] i2c i2c-0: Successfully instantiated SPD at 0x50
[    4.152654] i2c i2c-0: Successfully instantiated SPD at 0x51
[    4.153224] i2c i2c-0: Successfully instantiated SPD at 0x52
[    4.153318] sdhci: Secure Digital Host Controller Interface driver
[    4.153320] sdhci: Copyright(c) Pierre Ossman
[    4.153559] i2c i2c-0: Successfully instantiated SPD at 0x53
[    4.156723] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    4.156734] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    4.156748] ehci-pci 0000:00:1a.0: debug port 2
[    4.159788] sdhci-pci 0000:24:00.1: SDHCI controller found [197b:2392] (rev 30)
[    4.159789] sdhci-pci 0000:24:00.2: SDHCI controller found [197b:2391] (rev 30)
[    4.159958] sdhci-pci 0000:24:00.2: Refusing to bind to secondary interface.
[    4.159978] mmc0 bounce up to 128 segments into one, max segment size 65536 bytes
[    4.160405] mmc0: SDHCI controller on PCI [0000:24:00.1] using DMA
[    4.160689] ehci-pci 0000:00:1a.0: irq 16, io mem 0xd953a000
[    4.164554] SCSI subsystem initialized
[    4.176295] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    4.176386] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
[    4.176390] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.176391] usb usb1: Product: EHCI Host Controller
[    4.176393] usb usb1: Manufacturer: Linux 6.10.3-amd64 ehci_hcd
[    4.176394] usb usb1: SerialNumber: 0000:00:1a.0
[    4.176536] hub 1-0:1.0: USB hub found
[    4.176543] hub 1-0:1.0: 3 ports detected
[    4.176729] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    4.176735] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    4.176748] ehci-pci 0000:00:1d.0: debug port 2
[    4.180663] ehci-pci 0000:00:1d.0: irq 16, io mem 0xd9539000
[    4.196287] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    4.196325] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
[    4.196328] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.196329] usb usb2: Product: EHCI Host Controller
[    4.196330] usb usb2: Manufacturer: Linux 6.10.3-amd64 ehci_hcd
[    4.196331] usb usb2: SerialNumber: 0000:00:1d.0
[    4.196432] hub 2-0:1.0: USB hub found
[    4.196438] hub 2-0:1.0: 3 ports detected
[    4.198400] xhci_hcd 0000:00:14.0: can't derive routing for PCI INT A
[    4.198403] xhci_hcd 0000:00:14.0: PCI INT A: no GSI
[    4.198429] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    4.198433] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    4.199515] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x000000000000b930
[    4.199713] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    4.199718] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    4.199722] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    4.199803] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
[    4.199807] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.199809] usb usb3: Product: xHCI Host Controller
[    4.199810] usb usb3: Manufacturer: Linux 6.10.3-amd64 xhci-hcd
[    4.199811] usb usb3: SerialNumber: 0000:00:14.0
[    4.199941] hub 3-0:1.0: USB hub found
[    4.199953] hub 3-0:1.0: 4 ports detected
[    4.200328] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
[    4.200331] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.200332] usb usb4: Product: xHCI Host Controller
[    4.200333] usb usb4: Manufacturer: Linux 6.10.3-amd64 xhci-hcd
[    4.200334] usb usb4: SerialNumber: 0000:00:14.0
[    4.200465] hub 4-0:1.0: USB hub found
[    4.200477] hub 4-0:1.0: 4 ports detected
[    4.214526] libata version 3.00 loaded.
[    4.220082] ahci 0000:00:1f.2: version 3.0
[    4.220311] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[    4.230408] ahci 0000:00:1f.2: AHCI vers 0001.0300, 32 command slots, 6 Gbps, SATA mode
[    4.230412] ahci 0000:00:1f.2: 5/6 ports implemented (port mask 0x1f)
[    4.230414] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ems sxs apst
[    4.237983] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) fc:15:b4:e6:db:47
[    4.237987] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    4.238019] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: FFFFFF-0FF
[    4.268462] firewire_ohci 0000:24:00.0: added OHCI v1.10 device as card 0, 4 IR + 4 IT contexts, quirks 0x10
[    4.277725] scsi host0: ahci
[    4.278411] scsi host1: ahci
[    4.278841] scsi host2: ahci
[    4.279073] scsi host3: ahci
[    4.279279] scsi host4: ahci
[    4.279451] scsi host5: ahci
[    4.279517] ata1: SATA max UDMA/133 abar m2048@0xd9538000 port 0xd9538100 irq 35 lpm-pol 3
[    4.279522] ata2: SATA max UDMA/133 abar m2048@0xd9538000 port 0xd9538180 irq 35 lpm-pol 3
[    4.279526] ata3: SATA max UDMA/133 abar m2048@0xd9538000 port 0xd9538200 irq 35 lpm-pol 3
[    4.279529] ata4: SATA max UDMA/133 abar m2048@0xd9538000 port 0xd9538280 irq 35 lpm-pol 0
[    4.279533] ata5: SATA max UDMA/133 abar m2048@0xd9538000 port 0xd9538300 irq 35 lpm-pol 0
[    4.279535] ata6: DUMMY
[    4.279876] ahci 0000:26:00.0: AHCI vers 0001.0100, 32 command slots, 3 Gbps, SATA mode
[    4.279883] ahci 0000:26:00.0: 1/1 ports implemented (port mask 0x1)
[    4.279886] ahci 0000:26:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[    4.280294] scsi host6: ahci
[    4.280399] ata7: SATA max UDMA/133 abar m512@0xd9100000 port 0xd9100100 irq 36 lpm-pol 0
[    4.432341] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    4.452374] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[    4.456362] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    4.589104] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    4.589118] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.590126] hub 1-1:1.0: USB hub found
[    4.590300] hub 1-1:1.0: 6 ports detected
[    4.595700] ata7: SATA link down (SStatus 0 SControl 300)
[    4.595703] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.598207] ata1.00: ACPI cmd 00/00:00:00:00:00:a0(NOP) rejected by device (Stat=0x51 Err=0x04)
[    4.598334] ata1.00: supports DRM functions and may not be fully accessible
[    4.598343] ata1.00: ATA-11: Samsung SSD 860 EVO 500GB, RVT04B6Q, max UDMA/133
[    4.598983] ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    4.600652] usb 3-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    4.600674] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.601494] hub 3-1:1.0: USB hub found
[    4.601535] hub 3-1:1.0: 2 ports detected
[    4.603159] ata1.00: Features: Trust Dev-Sleep NCQ-sndrcv
[    4.603543] ata1.00: ACPI cmd 00/00:00:00:00:00:a0(NOP) rejected by device (Stat=0x51 Err=0x04)
[    4.603608] ata1.00: supports DRM functions and may not be fully accessible
[    4.608349] ata1.00: configured for UDMA/133
[    4.612684] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    4.612693] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.613274] hub 2-1:1.0: USB hub found
[    4.613404] hub 2-1:1.0: 8 ports detected
[    4.618643] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 860  4B6Q PQ: 0 ANSI: 5
[    4.728309] usb 3-3: new high-speed USB device number 3 using xhci_hcd
[    4.772848] firewire_core 0000:24:00.0: created device fw0: GUID ffe473fffffffffe, S400
[    4.884385] usb 1-1.3: new high-speed USB device number 3 using ehci-pci
[    4.900354] usb 2-1.6: new full-speed USB device number 3 using ehci-pci
[    4.935829] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.937819] ata2.00: ACPI cmd 00/00:00:00:00:00:a0(NOP) rejected by device (Stat=0x51 Err=0x04)
[    4.964435] ata2.00: ATA-10: ST2000LM015-2E8174, SDM1, max UDMA/133
[    4.973623] ata2.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    4.987969] ata2.00: ACPI cmd 00/00:00:00:00:00:a0(NOP) rejected by device (Stat=0x51 Err=0x04)
[    5.012954] usb 2-1.6: New USB device found, idVendor=0a5c, idProduct=21e1, bcdDevice= 1.12
[    5.012970] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.012974] usb 2-1.6: Product: BCM20702A0
[    5.012978] usb 2-1.6: Manufacturer: Broadcom Corp
[    5.012980] usb 2-1.6: SerialNumber: 8056F2D40A73
[    5.023769] ata2.00: configured for UDMA/133
[    5.033422] scsi 1:0:0:0: Direct-Access     ATA      ST2000LM015-2E81 SDM1 PQ: 0 ANSI: 5
[    5.036130] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input9
[    5.042400] usb 1-1.3: New USB device found, idVendor=04f2, idProduct=b230, bcdDevice=51.71
[    5.042415] usb 1-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[    5.042420] usb 1-1.3: Product: HP HD Webcam [Fixed]
[    5.042424] usb 1-1.3: Manufacturer: Chicony Electronics Co., Ltd.
[    5.042427] usb 1-1.3: SerialNumber: SN0001
[    5.128376] usb 1-1.4: new high-speed USB device number 4 using ehci-pci
[    5.237083] usb 1-1.4: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    5.237097] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.237864] hub 1-1.4:1.0: USB hub found
[    5.238067] hub 1-1.4:1.0: 4 ports detected
[    5.347480] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    5.357297] ata3.00: ACPI cmd 00/00:00:00:00:00:a0(NOP) rejected by device (Stat=0x51 Err=0x04)
[    5.357318] ata3.00: ATAPI: hp      DVD A  DS8A9SH, EH61, max UDMA/100
[    5.359004] ata3.00: ACPI cmd 00/00:00:00:00:00:a0(NOP) rejected by device (Stat=0x51 Err=0x04)
[    5.359027] ata3.00: configured for UDMA/100
[    5.385494] scsi 2:0:0:0: CD-ROM            hp       DVD A  DS8A9SH   EH61 PQ: 0 ANSI: 5
[    5.523764] psmouse serio4: synaptics: queried max coordinates: x [..5648], y [..4806]
[    5.524354] usb 1-1.4.4: new low-speed USB device number 5 using ehci-pci
[    5.563824] psmouse serio4: synaptics: queried min coordinates: x [1292..], y [1048..]
[    5.563850] psmouse serio4: synaptics: Your touchpad (PNP: SYN018d SYN0100 SYN0002 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[    5.620505] usb 4-3: new SuperSpeed USB device number 2 using xhci_hcd
[    5.635066] psmouse serio4: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xd40123/0x840300/0x26c00/0x0, board id: 2009, fw id: 1119621
[    5.638269] usb 1-1.4.4: New USB device found, idVendor=045e, idProduct=0040, bcdDevice= 3.00
[    5.638284] usb 1-1.4.4: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[    5.638289] usb 1-1.4.4: Product: Microsoft 3-Button Mouse with IntelliEye(TM)
[    5.638292] usb 1-1.4.4: Manufacturer: Microsoft
[    5.641506] usb 4-3: New USB device found, idVendor=059f, idProduct=1088, bcdDevice= 0.01
[    5.641520] usb 4-3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[    5.641525] usb 4-3: Product: Rugged Mini USB 3.0
[    5.641528] usb 4-3: Manufacturer: LaCie
[    5.641531] usb 4-3: SerialNumber: 0000NL68B77B
[    5.653907] usbcore: registered new interface driver usb-storage
[    5.659059] hid: raw HID events driver (C) Jiri Kosina
[    5.687184] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input12
[    5.720381] usb 3-1.1: new high-speed USB device number 4 using xhci_hcd
[    5.739528] ata4: SATA link down (SStatus 0 SControl 300)
[    5.919270] usb 3-1.1: New USB device found, idVendor=046d, idProduct=0825, bcdDevice= 0.21
[    5.919285] usb 3-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[    5.919290] usb 3-1.1: Product: C270 HD WEBCAM
[    5.919293] usb 3-1.1: SerialNumber: 200901010001
[    6.056130] ata5: SATA link down (SStatus 0 SControl 300)
[    6.063139] scsi host7: uas
[    6.063237] usbcore: registered new interface driver uas
[    6.063682] scsi 7:0:0:0: Direct-Access     LaCie    Rugged Mini USB3 153E PQ: 0 ANSI: 6
[    6.066321] usbcore: registered new interface driver usbhid
[    6.066323] usbhid: USB HID core driver
[    6.067711] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4:1.0/0003:045E:0040.0001/input/input13
[    6.067777] hid-generic 0003:045E:0040.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-0000:00:1a.0-1.4.4/input0
[    6.083979] ata1.00: Enabling discard_zeroes_data
[    6.084019] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    6.084023] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[    6.084026] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[    6.084048] sd 0:0:0:0: [sda] Write Protect is off
[    6.084052] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    6.084052] sd 1:0:0:0: [sdb] Write Protect is off
[    6.084056] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    6.084070] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    6.084083] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    6.084136] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[    6.084145] sd 1:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[    6.084392] ata1.00: Enabling discard_zeroes_data
[    6.087825]  sda: sda1 sda2 sda3
[    6.088847] sd 0:0:0:0: [sda] supports TCG Opal
[    6.088851] sd 0:0:0:0: [sda] Attached SCSI disk
[    6.121038]  sdb: sdb1 sdb2 sdb3
[    6.121902] sd 1:0:0:0: [sdb] Attached SCSI disk
[    6.161756] sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    6.161766] cdrom: Uniform CD-ROM driver Revision: 3.20
[    6.220699] sr 2:0:0:0: Attached scsi CD-ROM sr0
[    6.221506] sd 7:0:0:0: [sdc] Spinning up disk...
[    7.236366] ......ready
[   13.100785] sd 7:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[   13.100798] sd 7:0:0:0: [sdc] 4096-byte physical blocks
[   13.100972] sd 7:0:0:0: [sdc] Write Protect is off
[   13.100979] sd 7:0:0:0: [sdc] Mode Sense: 43 00 00 00
[   13.101252] sd 7:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   13.101439] sd 7:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes
[   13.101445] sd 7:0:0:0: [sdc] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
[   13.153511]  sdc: sdc1 sdc2 sdc3 sdc4 sdc5
[   13.154485] sd 7:0:0:0: [sdc] Attached SCSI disk
[   13.161165] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   13.161274] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   13.161373] sr 2:0:0:0: Attached scsi generic sg2 type 5
[   13.161520] sd 7:0:0:0: Attached scsi generic sg3 type 0
[   14.184392] PM: Image not found (code -22)
[   14.292739] EXT4-fs (sda1): mounted filesystem 59d2e3aa-fbb4-4c21-a3ad-d0d7af3337b7 ro with ordered data mode. Quota mode: none.
[   14.367341] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   14.603327] udevd[521]: starting version 3.2.14
[   14.642278] udevd[522]: starting eudev-3.2.14
[   14.703364] ACPI: AC: AC Adapter [AC] (on-line)
[   14.706137] hp_accel: laptop model unknown, using default axes configuration
[   14.719372] parport_pc 00:05: reported by Plug and Play ACPI
[   14.719457] parport0: PC-style at 0x378 (0x778), irq 5 [PCSPP,TRISTATE,EPP]
[   14.727762] iTCO_vendor_support: vendor-support=0
[   14.733855] iTCO_wdt iTCO_wdt.1.auto: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
[   14.734018] iTCO_wdt iTCO_wdt.1.auto: initialized. heartbeat=30 sec (nowayout=0)
[   14.804377] snd_hda_intel 0000:01:00.1: Disabling MSI
[   14.804386] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[   14.843923] lis3lv02d: 8 bits 3DC sensor found
[   14.850777] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.851034] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[   14.851222] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[   14.851454] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.851697] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   14.857058] snd_hda_codec_idt hdaudioC0D0: autoconfig for 92HD81B1X5: line_outs=1 (0xa/0x0/0x0/0x0/0x0) type:line
[   14.857064] snd_hda_codec_idt hdaudioC0D0:    speaker_outs=1 (0xd/0x0/0x0/0x0/0x0)
[   14.857065] snd_hda_codec_idt hdaudioC0D0:    hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
[   14.857067] snd_hda_codec_idt hdaudioC0D0:    mono: mono_out=0x0
[   14.857069] snd_hda_codec_idt hdaudioC0D0:    inputs:
[   14.857071] snd_hda_codec_idt hdaudioC0D0:      Mic=0xc
[   14.857073] snd_hda_codec_idt hdaudioC0D0:      Internal Mic=0x11
[   14.857075] snd_hda_codec_idt hdaudioC0D0:      Line=0xf
[   14.860814] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[   14.860917] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[   14.861014] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[   14.861093] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[   14.904836] Intel(R) Wireless WiFi driver for Linux
[   14.908108] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[   14.908155] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input19
[   14.908195] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input20
[   14.908233] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input21
[   14.908272] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input22
[   14.912465] iwlwifi 0000:25:00.0: Detected crf-id 0xa5a5a5a1, cnv-id 0xa5a5a5a1 wfpm id 0xa5a5a5a1
[   14.912502] iwlwifi 0000:25:00.0: PCI dev 422b/1101, rev=0x74, rfid=0xd55555d5
[   14.916167] iwlwifi 0000:25:00.0: loaded firmware version 9.221.4.1 build 25532 6000-4.ucode op_mode iwldvm
[   14.980377] pcieport 0000:00:1c.0: Enabling MPC IRBNCE
[   14.980384] pcieport 0000:00:1c.0: Intel PCH root port ACS workaround enabled
[   15.024359] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input23
[   15.041162] at24 0-0050: supply vcc not found, using dummy regulator
[   15.043583] at24 0-0050: 256 byte spd EEPROM, read-only
[   15.043657] at24 0-0051: supply vcc not found, using dummy regulator
[   15.046119] at24 0-0051: 256 byte spd EEPROM, read-only
[   15.046400] at24 0-0052: supply vcc not found, using dummy regulator
[   15.048231] at24 0-0052: 256 byte spd EEPROM, read-only
[   15.048260] at24 0-0053: supply vcc not found, using dummy regulator
[   15.051506] at24 0-0053: 256 byte spd EEPROM, read-only
[   15.070460] iwlwifi 0000:25:00.0: CONFIG_IWLWIFI_DEBUG disabled
[   15.070466] iwlwifi 0000:25:00.0: CONFIG_IWLWIFI_DEBUGFS disabled
[   15.070468] iwlwifi 0000:25:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[   15.070470] iwlwifi 0000:25:00.0: Detected Intel(R) Centrino(R) Ultimate-N 6300 AGN, REV=0x74
[   15.071794] input: HP WMI hotkeys as /devices/virtual/input/input24
[   15.084474] resource: resource sanity check: requesting [mem 0x00000000fed10000-0x00000000fed15fff], which spans more than Reserved [mem 0xfed10000-0xfed13fff]
[   15.084482] caller snb_uncore_imc_init_box+0x84/0xe0 [intel_uncore] mapping multiple BARs
[   15.104685] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[   15.104691] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[   15.104693] RAPL PMU: hw unit of domain package 2^-16 Joules
[   15.106764] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[   15.109774] cryptd: max_cpu_qlen set to 1000
[   15.184888] mc: Linux media interface: v0.10
[   15.185016] AVX version of gcm_enc/dec engaged.
[   15.185057] AES CTR mode by8 optimization enabled
[   15.232181] videodev: Linux video capture interface: v2.00
[   15.238971] ppdev: user-space parallel port driver
[   15.254184] usb 3-1.1: current rate 16000 is different from the runtime rate 32000
[   15.258562] usb 3-1.1: current rate 24000 is different from the runtime rate 16000
[   15.260288] usb 3-1.1: 3:3: cannot set freq 24000 to ep 0x82
[   15.268099] usb 1-1.3: Found UVC 1.00 device HP HD Webcam [Fixed] (04f2:b230)
[   15.382827] usb 3-1.1: set resolution quirk: cval->res = 384
[   15.383099] usbcore: registered new interface driver snd-usb-audio
[   15.439839] intel_rapl_common: Found RAPL domain package
[   15.439843] intel_rapl_common: Found RAPL domain core
[   15.529479] usb 3-1.1: Found UVC 1.00 device C270 HD WEBCAM (046d:0825)
[   15.534427] usbcore: registered new interface driver uvcvideo
[   15.824616] warning: `iwconfig' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[   15.872546] usb 3-1.1: reset high-speed USB device number 4 using xhci_hcd
[   16.412763] usb 3-1.1: reset high-speed USB device number 4 using xhci_hcd
[   17.705331] Bluetooth: Core ver 2.22
[   17.705360] NET: Registered PF_BLUETOOTH protocol family
[   17.705361] Bluetooth: HCI device and connection manager initialized
[   17.705374] Bluetooth: HCI socket layer initialized
[   17.705376] Bluetooth: L2CAP socket layer initialized
[   17.705379] Bluetooth: SCO socket layer initialized
[   17.748065] usbcore: registered new interface driver btusb
[   18.676462] Adding 33997820k swap on /dev/sdb1.  Priority:-2 extents:1 across:33997820k
[   18.730227] EXT4-fs (sda1): re-mounted 59d2e3aa-fbb4-4c21-a3ad-d0d7af3337b7 r/w. Quota mode: none.
[   20.256563] lp0: using parport0 (interrupt-driven).
[   20.316688] EXT4-fs (sda2): mounted filesystem 3841b6d3-74c1-4a31-b6c8-d2c83a5b90d3 r/w with ordered data mode. Quota mode: none.
[   20.411300] ACPI: bus type drm_connector registered
[   20.414314] EXT4-fs (sdb2): mounted filesystem caa9a71c-da8b-4fb7-a97c-f79b44a6e92c r/w with ordered data mode. Quota mode: none.
[   20.591878] EXT4-fs (sdc4): mounted filesystem 40059d2d-66dd-426e-b30f-d0e109e42125 r/w with ordered data mode. Quota mode: none.
[   20.729512] audit: type=1400 audit(1723344141.659:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="torbrowser_tor" pid=6767 comm="apparmor_parser"
[   20.729520] audit: type=1400 audit(1723344141.659:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=6762 comm="apparmor_parser"
[   20.729737] audit: type=1400 audit(1723344141.659:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=6763 comm="apparmor_parser"
[   20.729741] audit: type=1400 audit(1723344141.659:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=6763 comm="apparmor_parser"
[   20.730950] audit: type=1400 audit(1723344141.659:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="system_tor" pid=6765 comm="apparmor_parser"
[   20.732466] Module pcspkr is blacklisted
[   20.734212] audit: type=1400 audit(1723344141.663:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=6780 comm="apparmor_parser"
[   20.753298] audit: type=1400 audit(1723344141.663:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=6780 comm="apparmor_parser"
[   20.753302] audit: type=1400 audit(1723344141.663:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=6780 comm="apparmor_parser"
[   20.753311] audit: type=1400 audit(1723344141.663:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="passt" pid=6782 comm="apparmor_parser"
[   20.753314] audit: type=1400 audit(1723344141.663:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=6764 comm="apparmor_parser"
[   20.962351] RPC: Registered named UNIX socket transport module.
[   20.962356] RPC: Registered udp transport module.
[   20.962357] RPC: Registered tcp transport module.
[   20.962357] RPC: Registered tcp-with-tls transport module.
[   20.962358] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   20.997472] netfs: FS-Cache loaded
[   21.377927] input: BRLTTY 6.6 Linux Screen Driver Keyboard as /devices/virtual/input/input25
[   21.696370] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   21.696373] Bluetooth: BNEP filters: protocol multicast
[   21.696378] Bluetooth: BNEP socket layer initialized
#7 2024-08-11 08:08:08
rdav
Re: [SOLVED] Xorg not starting with error "(EE) [drm] Failed to open DRM device .."
Fixed!
Found that nouveau module was blacklisted in /lib/modprobe.d/nvidia-installer-disable-nouveau.conf
This was installed by attempting to install nvidia drivers from nvidia binary package from Nvidia.com.
Which later on uninstall wasn't removed.
Solution came from https://wiki.archlinux.org/title/Nouveau
#8 2024-08-11 09:10:10
thanks for posting your resolution to this query.
