#1 2024-08-02 21:49:02
Danielsan
[HELP] Hotspot through nm-applet
Hi There,
I am trying to set up an hotspot with my laptop through the nm-applet but it doesn't work.
In my memories there were plenty of articles about hotspot and nm-applet but looks like all them were cannibalized by the latest Ubuntu/Gnome3... hmm
I wonder if this is actually possible with the default Xfce4 and desktop, plus nm-applet... I have runit as init system but if I need to change to openrc, for instance, I am willing to make this change.
May anyone of you guide me through this process?
Thanks in advance! smile
#2 2024-08-02 23:14:57
soren
Re: [HELP] Hotspot through nm-applet
Does your network card support AP mode?
https://wiki.archlinux.org/title/Softwa … rt_AP_mode
Also see here
https://wiki.archlinux.org/title/Networ … over_Wi-Fi
I know they are archlinux links but the arch wiki is usually pretty good when it comes to stuff like this.
#3 2024-08-02 23:29:03
You'll need to install hostapd and read through its documentation.
#4 2024-08-04 04:25:00
Danielsan
Thank you guys, apparently it is supported:
sudo iw list | grep AP
		 * AP
		 * AP/VLAN
		 * AP/VLAN
	Driver supports full state transitions for AP/GO clients
		 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
However I am not sure I want go that route, it is easier using my phone as access point and connect my workstation to the laptop through RDP...
