#1 2024-07-15 16:25:00
bai4Iej2need
[SOLVED] mate desktop pdf opens in terminal with vim
daedalus
From Desktop:
About Mate
mate 1.26.0
about Atril
Atril is a simple multi-page document viewer.   1.26.0
When I download or extract a pdf from a mail, it shows up in "latest documents". Then I click on It , and a terminal with vi opens it.
%PDF-1.7^M and so on.
System /Personal/ Preferred Applications /Büro (office) states atril for Documents . whatever documents means .
~/.config/mimeapps.list Line 21 :
application/pdf=atril.desktop
cd /usr/share/mime/application
#  grep "pdf" *
pdf.xml:<mime-type xmlns="http://www.freedesktop.org/standards/shared-mime-info" type="application/pdf">
pdf.xml:  <glob pattern="*.pdf"/>
pdf.xml:  <alias type="application/x-pdf"/>
pdf.xml:  <alias type="image/pdf"/>
pdf.xml:  <alias type="application/nappdf"/>
x-bzpdf.xml:<mime-type xmlns="http://www.freedesktop.org/standards/shared-mime-info" type="application/x-bzpdf">
x-bzpdf.xml:  <glob pattern="*.pdf.bz2"/>
x-gzpdf.xml:<mime-type xmlns="http://www.freedesktop.org/standards/shared-mime-info" type="application/x-gzpdf">
x-gzpdf.xml:  <glob pattern="*.pdf.gz"/>
x-lzpdf.xml:<mime-type xmlns="http://www.freedesktop.org/standards/shared-mime-info" type="application/x-lzpdf">
x-lzpdf.xml:  <glob pattern="*.pdf.lz"/>
x-wwf.xml:  <sub-class-of type="application/pdf"/>
x-xzpdf.xml:<mime-type xmlns="http://www.freedesktop.org/standards/shared-mime-info" type="application/x-xzpdf">
x-xzpdf.xml:  <glob pattern="*.pdf.xz"/>
What points the application wrongly to vi ?
top:
30511 md        20   0  553320  53296  34844 S   0,0   0,1   1:00.55              `- mate-panel
30514 md        20   0  553320  53296  34844 S   0,0   0,1   0:06.22                  `- mate-panel
30515 md        20   0  553320  53296  34844 S   0,0   0,1   0:00.14                  `- mate-panel
30516 md        20   0  553320  53296  34844 S   0,0   0,1   0:00.00                  `- mate-panel
 9803 md        20   0  562952  59816  41856 S   3,3   0,1   0:11.46                  `- mate-terminal
 9806 md        20   0  562952  59816  41856 S   0,0   0,1   0:00.00                      `- mate-terminal
 9808 md        20   0  562952  59816  41856 S   0,0   0,1   0:00.00                      `- mate-terminal
 9809 md        20   0  562952  59816  41856 S   0,0   0,1   0:00.00                      `- mate-terminal
10188 md        20   0   14064   7808   4828 S   0,0   0,0   0:00.17                      `- zsh
10590 md        20   0    8468   4876   2760 R   0,3   0,0   0:01.03                          `- top
10585 md        20   0   36664  17880  10032 S   0,0   0,0   0:00.02                      `- vim /tmp/240703_Importstrategie-2.pdf
10587 md        20   0   36664  17880  10032 S   0,0   0,0   0:00.00                          `- vim /tmp/240703_Importstrategie-2.pdf
broken by design :
#2 2024-07-15 23:19:34
igorzwx
Re: [SOLVED] mate desktop pdf opens in terminal with vim
MATE 1.26.0
$ atril --version
MATE Document Viewer 1.26.0
Atril opens PDFs without problems.
Check your pdf with mediainfo
mediainfo *.pdf
$ file *.pdf
Graphics_with_Maxima.pdf: PDF document, version 1.4, 6 pages
Try to open the pdf file with Firefox.
#3 2024-07-16 08:07:28
bai4Iej2need
Thanks for answering.
When opening with atril , the file opens and displays properly. This is not the problem.
file 240703_Importstrategie-2.pdf
240703_Importstrategie-2.pdf: PDF document, version 1.7, 38 pages
The problem is in the calling structure of the mate menu tree, where a flawed command reference is stored somewhere.
See the 'top' listing.
mate-panel invokes vim over a terminal instead of invoking atril.
Where does mate panel store its preferences?
broken by design :
#4 2024-07-16 09:00:43
alexkemp
In XFCE it is "Default Applications" & they are discovered/changed via menu:Settings | Default Applications. I would imagine/hope that all DAs have a similar setup.
#5 2024-07-16 09:16:19
The way to find out is to use strace, focussing on the open or openat system calls and reducing it to the files concerned. Something like
$ strace -f -s 200 $program | sed '/open/!d;s|[^"]*"||;s|".*||' | sort -u
where $program is that program that handles the mouse click... your file browser(?).
EDIT: However if the click handling program farms out the decision logic to some dbus activated something, it breaks the call chain and becomes slightly more complext to trace. You might then need to trace dbus to work out where the decision logic is sited, and then set up a way to strace that.
#6 2024-07-16 11:03:41
igorzwx
$ cat /usr/share/applications/atril.desktop | grep Exec
TryExec=atril
Exec=atril %U
Is it "Open in Terminal"?
$ cat /usr/share/applications/atril.desktop | grep Terminal=
Terminal=false
ls ~/.local/share/applications | grep atr
Mozo - Mate Menu Editor
_https://wiki.mate-desktop.org/mate-desktop/applications/mozo/
mozo
EDIT:
Right mouse click on a pdf file > Select "Properties" in a drop-down menu > "Open With"
#7 2024-07-16 20:17:57
Ron
Go to Menu and under "All" find "Preferred Applications." In the Office tab, make sure Atril is selected under Document Viewer.
#8 2024-07-16 20:32:36
igorzwx
Method 1: Right mouse click on a pdf file > Select "Properties" in a drop-down menu > "Open With"
Method 2: "Preferred Applications"
mate-default-applications-properties
If you open a document file with a sort of vim, it may become a default for all documents.
If, for example, you open a wxMaxima worksheet *.wxmx with wxMaxima, then it is a default for all archives.
It seems to be a standard behaviour for all Linux Desktops (freedesktop.org)
#9 2024-10-02 17:50:57
bai4Iej2need
When now testing the case, I noted,  that the wrong behavior has disappeared.
It was limited to the "recent files" in the application menu of mate.
I did install some mate-menues-extras Items.
Probably it fixed the case. Possibly after a restart or a logout-login sequence.
broken by design :
