#1 2024-07-07 12:02:22
vazhnov
OpenSSH fails to start with the latest update in Devuan 6 Excalibur
Hi!
I have a Proxmox host with KVM virtual machine with Devuan GNU/Linux 6 (excalibur/ceres) + OpenRC init.
Yesterday I've installed updates in the virtual machine guest and after reboot, SSHD couldn't start:
/var/log/syslog:
2024-07-07T01:00:42.824732+02:00 devuan6-kube01 /etc/init.d/ssh[1822]: start-stop-daemon: pam error: Authentication failure
2024-07-07T01:00:42.830420+02:00 devuan6-kube01 /etc/init.d/ssh[1821]: start-stop-daemon: failed to start `/usr/sbin/sshd'
Updates, from /var/log/apt/history.log:
Start-Date: 2024-07-07  00:59:42
Commandline: apt-get -V --no-install-recommends dist-upgrade
Requested-By: alexey (1000)
Upgrade: base-passwd:amd64 (3.6.3, 3.6.4), libeinfo1:amd64 (0.54-2, 0.54.2-1), gping:amd64 (1.16.1-1, 1.16.1-2), debian-keyring:amd64 (2024.03.24, 2024.06.24), librc1t64:amd64 (0.54-2, 0.54.2-1), openrc:amd64 (0.54-2, 0.54.2-1), ruby-xmlrpc:amd64 (0.3.2-2, 0.3.3-2)
End-Date: 2024-07-07  00:59:56
When I login through KVM console and start the service manually with sudo service ssh start, it starts.
I will investigate this. Just wanted to notify users to not install the latest updates if they have similar configuration.
#2 2024-07-07 12:19:06
vazhnov
Re: OpenSSH fails to start with the latest update in Devuan 6 Excalibur
Also I found that after the upgrade, Devuan fails to stop some services at shutdown:
2024-07-07T01:00:07.694393+02:00 devuan6-kube01 shutdown[2776]: shutting down for system reboot
2024-07-07T01:00:07.802340+02:00 devuan6-kube01 init: Switching to runlevel: 6
2024-07-07T01:00:07.803922+02:00 devuan6-kube01 kernel: Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
2024-07-07T01:00:07.810263+02:00 devuan6-kube01 init: No inittab.d directory found
2024-07-07T01:00:07.916679+02:00 devuan6-kube01 start-stop-daemon: Will stop /usr/sbin/sshd
2024-07-07T01:00:07.916702+02:00 devuan6-kube01 start-stop-daemon: Will stop PID 1833
2024-07-07T01:00:07.917112+02:00 devuan6-kube01 start-stop-daemon: Sending signal 15 to PID 1833
2024-07-07T01:00:07.950597+02:00 devuan6-kube01 /etc/init.d/rsync[2806]: ERROR: rsync failed to stop
2024-07-07T01:00:08.032347+02:00 devuan6-kube01 start-stop-daemon: Will stop PID 1765
2024-07-07T01:00:08.032929+02:00 devuan6-kube01 start-stop-daemon: Sending signal 15 to PID 1765
2024-07-07T01:00:08.216425+02:00 devuan6-kube01 avahi-daemon[1643]: Got SIGTERM, quitting.
2024-07-07T01:00:08.217919+02:00 devuan6-kube01 avahi-daemon[1643]: Leaving mDNS multicast group on interface eth0.IPv6 with address 2a01:112f:xxx:yyy:zzz:xxx:yyy:zzz.
2024-07-07T01:00:08.218882+02:00 devuan6-kube01 avahi-daemon[1643]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.155.137.
2024-07-07T01:00:08.219253+02:00 devuan6-kube01 avahi-daemon[1643]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
2024-07-07T01:00:08.219426+02:00 devuan6-kube01 avahi-daemon[1643]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
2024-07-07T01:00:08.236026+02:00 devuan6-kube01 avahi-daemon[1643]: avahi-daemon 0.8 exiting.
2024-07-07T01:00:08.364213+02:00 devuan6-kube01 start-stop-daemon: Will stop PID 1625
2024-07-07T01:00:08.364234+02:00 devuan6-kube01 start-stop-daemon: Will stop processes owned by UID 100
2024-07-07T01:00:08.364783+02:00 devuan6-kube01 start-stop-daemon: Sending signal 15 to PID 1625
2024-07-07T01:00:08.387275+02:00 devuan6-kube01 /etc/init.d/dbus[2928]: ERROR: dbus failed to stop
#3 2024-07-08 13:35:28
I'm not seeing this problem before or after upgrade today of excalibur amd64 on hardware with sysvinit. SSH login from remote works, rsync and dbus stop/start normally as do other services.
#4 2024-07-08 22:34:16
vazhnov
fsmithred, thanks. This is OpenRC-related issue, probably connected with an upgrade openrc:amd64 (0.54-2, 0.54.2-1).
I've added rc_verbose=yes into /etc/rc.conf and now I see in /var/log/boot:
Tue Jul  9 00:07:18 2024: Starting system message bus: dbus * start-stop-daemon: fopen `/var/run/dbus/pid': No such file or directory
Tue Jul  9 00:07:18 2024:  * Detaching to start `/usr/bin/dbus-daemon' ...
Tue Jul  9 00:07:18 2024: .
Tue Jul  9 00:07:18 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/avahi-daemon start
Tue Jul  9 00:07:18 2024: Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Tue Jul  9 00:07:18 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/bootlogs start
Tue Jul  9 00:07:19 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/console-setup.sh start
Tue Jul  9 00:07:19 2024: Setting up console font and keymap...done.
Tue Jul  9 00:07:19 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/cron start
Tue Jul  9 00:07:19 2024: Starting periodic command scheduler: cron.
Tue Jul  9 00:07:19 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/earlyoom start
Tue Jul  9 00:07:19 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/elogind start
Tue Jul  9 00:07:19 2024: Starting session management daemon: elogind * start-stop-daemon: fopen `/run/elogind.pid': No such file or directory
Tue Jul  9 00:07:19 2024:  * Detaching to start `/usr/libexec/elogind' ...
Tue Jul  9 00:07:19 2024: .
Tue Jul  9 00:07:19 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/sudo start
Tue Jul  9 00:07:19 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/rmnologin start
Tue Jul  9 00:07:19 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/rsync start
Tue Jul  9 00:07:19 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/ssh start
Tue Jul  9 00:07:19 2024: Starting OpenBSD Secure Shell server: sshd * start-stop-daemon: fopen `/run/sshd.pid': No such file or directory
Tue Jul  9 00:07:19 2024:  * Detaching to start `/usr/sbin/sshd' ...
Tue Jul  9 00:07:19 2024:  *   start-stop-daemon: pam error: Authentication failure
Tue Jul  9 00:07:20 2024:  *   start-stop-daemon: failed to start `/usr/sbin/sshd'
Tue Jul  9 00:07:20 2024:  failed!
Tue Jul  9 00:07:20 2024:  * ERROR: rc.local needs service(s) 0, 6
Tue Jul  9 00:07:20 2024:  * Executing: /usr/lib/rc/sh/openrc-run.sh /usr/lib/rc/sh/openrc-run.sh /etc/init.d/stop-bootlogd start
I don't have custom records in /etc/fstab to mount /run…
Analysing git diff debian/0.54-2 debian/0.54.2-1 in https://salsa.debian.org/debian/openrc (web diff).
#5 2024-07-10 22:03:51
vazhnov
Currently there are two versions of start-stop-daemon binaries from two packages:
 % dpkg -S start-stop-daemon|sort
dpkg: /usr/sbin/start-stop-daemon
dpkg: /usr/share/man/de/man8/start-stop-daemon.8.gz
dpkg: /usr/share/man/fr/man8/start-stop-daemon.8.gz
dpkg: /usr/share/man/man8/start-stop-daemon.8.gz
dpkg: /usr/share/man/nl/man8/start-stop-daemon.8.gz
dpkg: /usr/share/man/pt/man8/start-stop-daemon.8.gz
dpkg: /usr/share/man/sv/man8/start-stop-daemon.8.gz
openrc: /usr/lib/rc/sbin/start-stop-daemon
openrc: /usr/lib/rc/sh/start-stop-daemon.sh
They are different:
 % file /usr/sbin/start-stop-daemon /usr/lib/rc/sbin/start-stop-daemon
/usr/sbin/start-stop-daemon:        ELF 64-bit LSB pie executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=fb0de15cbe08c53aa308fddb2925afe3423ed34e, for GNU/Linux 3.2.0, stripped
/usr/lib/rc/sbin/start-stop-daemon: ELF 64-bit LSB pie executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=6b69feea4068615a048ce10c763efb5869f798f8, for GNU/Linux 3.2.0, stripped
As an experiment, I decided to make OpenRC version of start-stop-daemon as the main one:
sudo cp -pv /usr/sbin/start-stop-daemon /usr/sbin/start-stop-daemon.dpkg
sudo cp -pv /usr/lib/rc/sbin/start-stop-daemon /usr/sbin/start-stop-daemon
After this change, I see no difference in Devuan shutdown/start (the same errors and SSHD can't start), but this time I couldn't start SSHD manually with sudo /etc/init.d/ssh start, I received the same error "start-stop-daemon: pam error: Authentication failure". Before the binaries swap, I was able to start the SSHD manually.
Then I returned binaries back and made second experiment:
sudo cp -pv /usr/sbin/start-stop-daemon.dpkg /usr/lib/rc/sbin/start-stop-daemon
And now my system starts and stops normally, SSHD starts automatically!
#6 2024-07-21 22:51:57
vazhnov
Checked with clean minimal Devuan 5 Daedalus installation: the same issue.
  • put openrc package on hold,
  • installed usrmerge,
  • upgraded to Devuan 6 Excalibur,
     % dpkg -l | { head -n4; grep -E -i 'sysvinit|sysv-rc|openrc|runit|sinit|66-devuan'; }
    Desired=Unknown/Install/Remove/Purge/Hold
    | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
    |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
    ||/ Name                                Version                  Architecture Description
    ii  openrc                              0.45.2-2+deb12u1         amd64        dependency based service manager (runlevel change mechanism)
    ii  runit-helper                        2.16.3                   all          dh-runit implementation detail
    rc  sysv-rc                             3.06-4devuan3            all          System-V-like runlevel change mechanism
    ii  sysvinit-core                       3.09-2devuan1            amd64        System-V-like init
    ii  sysvinit-utils                      3.09-2devuan1            amd64        System-V-like utilities
     % sudo tail /var/log/boot
    Mon Jul 22 02:29:13 2024: bound to 10.0.2.15 -- renewal in 35829 seconds.
    Mon Jul 22 02:29:13 2024: done.
    Mon Jul 22 02:29:13 2024: Cleaning up temporary files....
    Mon Jul 22 02:29:13 2024:  * Mounting cgroup filesystem ...        [ ok ]
    INIT: Entering runlevel: 2
    Mon Jul 22 02:29:14 2024: Setting up console font and keymap...done.
    Mon Jul 22 02:29:14 2024: Starting enhanced syslogd: rsyslogd.
    Mon Jul 22 02:29:14 2024: Starting periodic command scheduler: cron.
    Mon Jul 22 02:29:14 2024: Starting system message bus: dbus.
    Mon Jul 22 02:29:14 2024: Starting session management daemon: elogind.
    Mon Jul 22 02:29:14 2024: Starting OpenBSD Secure Shell server: sshd.
    Mon Jul 22 02:29:14 2024:  * ERROR: rc.local needs service(s) 0, 6
  • restarted the OS,
  • then upgraded the openrc package only:
    alexey@devuan6-aqemu1 ~ % sudo apt-get -V --no-install-recommends dist-upgrade
    Calculating upgrade... Done
       librc1 (0.45.2-2+deb12u1)
       librc1t64 (0.54.2-1)
       openrc (0.45.2-2+deb12u1 => 0.54.2-1)
    1 upgraded, 1 newly installed, 1 to remove and 0 not upgraded.
    Need to get 217 kB of archives.
    After this operation, 82.9 kB of additional disk space will be used.
     * Caching service dependencies ...
    Service `rc.local' needs non existent service `0'
    Service `rc.local' needs non existent service `6'
    Error: udev is the name of a real and virtual service.        [ ok ]
  • and restarted the OS. OpenSSH couldn't start, I had to start it manually from console:
    alexey@devuan6-aqemu1 ~ % sudo tail /var/log/boot
    Mon Jul 22 02:39:27 2024: Setting up console font and keymap...done.
    Mon Jul 22 02:39:27 2024: Starting enhanced syslogd: rsyslogd.
    Mon Jul 22 02:39:28 2024: Starting periodic command scheduler: cron.
    Mon Jul 22 02:39:28 2024: Starting system message bus: dbus.
    Mon Jul 22 02:39:28 2024: Starting session management daemon: elogind.
    Mon Jul 22 02:39:28 2024: Starting OpenBSD Secure Shell server: sshd * start-stop-daemon: pam error: Authentication failure
    Mon Jul 22 02:39:28 2024:  * start-stop-daemon: failed to start `/usr/sbin/sshd'
    Mon Jul 22 02:39:28 2024:  failed!
    Mon Jul 22 02:39:28 2024:  * ERROR: rc.local needs service(s) 0, 6
And also workaround with copying /usr/sbin/start-stop-daemon into /usr/lib/rc/sbin/start-stop-daemon solves the issue.
#7 2024-08-21 18:58:31
vazhnov
Where should I file a ticket — in bugs.devuan.org or in bugs.debian.org?
#8 2024-08-21 20:59:30
Lorenzo
Hi!
Is this is a side effects of the fix for #1038789 ? (not sure)
https://bugs.debian.org/cgi-bin/bugrepo … %231038789
the openrc package is not forked in Devuan, so please report directly to Debian!
Cheers,
Lorenzo
#9 2025-05-10 21:22:13
deepforest
try install openrc, same error
its bug? how to workaround?
root@devuan:/home/freeartist-devuan# apt install openrc
Installing:
  openrc
Installing dependencies:
  libeinfo1  librc1t64
Suggested packages:
  policycoreutils
REMOVING:
  sysv-rc
Summary:
  Upgrading: 0, Installing: 3, Removing: 1, Not Upgrading: 0
  Download size: 234 kB
  Space needed: 1,944 kB / 39.1 GB available
Continue? [Y/n]
Get:1 http://deb.devuan.org/merged ceres/main amd64 libeinfo1 amd64 0.56-1 [14.5 kB]
Get:2 http://deb.devuan.org/merged ceres/main amd64 librc1t64 amd64 0.56-1 [33.8 kB]
Get:3 http://deb.devuan.org/merged ceres/main amd64 openrc amd64 0.56-1 [186 kB]
Fetched 234 kB in 2s (125 kB/s)
Selecting previously unselected package libeinfo1:amd64.
(Reading database ... 352727 files and directories currently installed.)
Preparing to unpack .../libeinfo1_0.56-1_amd64.deb ...
Unpacking libeinfo1:amd64 (0.56-1) ...
Selecting previously unselected package librc1t64:amd64.
Preparing to unpack .../librc1t64_0.56-1_amd64.deb ...
Adding 'diversion of /lib/x86_64-linux-gnu/librc.so.1 to /lib/x86_64-linux-gnu/librc.so.1.usr-is-merged by librc1t64'
Unpacking librc1t64:amd64 (0.56-1) ...
dpkg: sysv-rc: dependency problems, but removing anyway as you requested:
 sysvinit-core depends on sysv-rc | openrc | file-rc; however:
  Package sysv-rc is to be removed.
  Package openrc is not installed.
  Package file-rc is not installed.
 initscripts depends on sysv-rc | file-rc | openrc; however:
(Reading database ... 352740 files and directories currently installed.)
Removing sysv-rc (3.14-4devuan1) ...
Selecting previously unselected package openrc.
(Reading database ... 352714 files and directories currently installed.)
Preparing to unpack .../openrc_0.56-1_amd64.deb ...
Unpacking openrc (0.56-1) ...
Setting up libeinfo1:amd64 (0.56-1) ...
Setting up librc1t64:amd64 (0.56-1) ...
Removing 'diversion of /lib/x86_64-linux-gnu/librc.so.1 to /lib/x86_64-linux-gnu/librc.so.1.usr-is-merged by librc1t64'
Setting up openrc (0.56-1) ...
Add existing services ...
 * rc-update: killprocs already installed in runlevel `recovery'; skipping
 * rc-update: single already installed in runlevel `recovery'; skipping
 * rc-update: bootlogs already installed in runlevel `recovery'; skipping
 * rc-update: console-setup.sh already installed in runlevel `default'; skipping
 * rc-update: binfmt-support already installed in runlevel `default'; skipping
 * rc-update: ipsec already installed in runlevel `default'; skipping
 * rc-update: pulseaudio-enable-autospawn already installed in runlevel `default'; skipping
 * rc-update: rsyslog already installed in runlevel `default'; skipping
 * rc-update: seatd already installed in runlevel `default'; skipping
 * rc-update: sudo already installed in runlevel `default'; skipping
 * rc-update: zfs-load-key already installed in runlevel `default'; skipping
 * rc-update: zfs-zed already installed in runlevel `default'; skipping
 * rc-update: acpid already installed in runlevel `default'; skipping
 * rc-update: anacron already installed in runlevel `default'; skipping
 * rc-update: binkd already installed in runlevel `default'; skipping
 * rc-update: cron already installed in runlevel `default'; skipping
 * rc-update: dbus already installed in runlevel `default'; skipping
 * rc-update: exim4 already installed in runlevel `default'; skipping
 * rc-update: gpm already installed in runlevel `default'; skipping
 * rc-update: inn already installed in runlevel `default'; skipping
 * rc-update: iodined already installed in runlevel `default'; skipping
 * rc-update: mdadm already installed in runlevel `default'; skipping
 * rc-update: ntpsec already installed in runlevel `default'; skipping
 * rc-update: openbsd-inetd already installed in runlevel `default'; skipping
 * rc-update: osspd already installed in runlevel `default'; skipping
 * rc-update: pcscd already installed in runlevel `default'; skipping
 * rc-update: rmnologin already installed in runlevel `default'; skipping
 * rc-update: rsync already installed in runlevel `default'; skipping
 * rc-update: sysstat already installed in runlevel `default'; skipping
 * rc-update: vboxdrv already installed in runlevel `default'; skipping
 * rc-update: xl2tpd already installed in runlevel `default'; skipping
 * rc-update: avahi-daemon already installed in runlevel `default'; skipping
 * rc-update: elogind already installed in runlevel `default'; skipping
 * rc-update: lightdm already installed in runlevel `default'; skipping
 * rc-update: network-manager already installed in runlevel `default'; skipping
 * rc-update: slim already installed in runlevel `default'; skipping
 * rc-update: vboxautostart-service already installed in runlevel `default'; skipping
 * rc-update: vboxballoonctrl-service already installed in runlevel `default'; skipping
 * rc-update: vboxweb-service already installed in runlevel `default'; skipping
 * rc-update: openvpn already installed in runlevel `default'; skipping
 * rc-update: cups already installed in runlevel `default'; skipping
 * rc-update: cups-browsed already installed in runlevel `default'; skipping
 * rc-update: saned already installed in runlevel `default'; skipping
 * rc-update: bootlogs already installed in runlevel `default'; skipping
 * rc-update: zfs-share already installed in runlevel `default'; skipping
 * rc-update: rc.local already installed in runlevel `default'; skipping
 * rc-update: stop-bootlogd already installed in runlevel `default'; skipping
 * rc-update: mountkernfs.sh already installed in runlevel `sysinit'; skipping
 * rc-update: eudev already installed in runlevel `sysinit'; skipping
 * rc-update: mountdevsubfs.sh already installed in runlevel `sysinit'; skipping
 * rc-update: udev already installed in runlevel `sysinit'; skipping
 * rc-update: keyboard-setup.sh already installed in runlevel `sysinit'; skipping
 * rc-update: bootlogd already installed in runlevel `sysinit'; skipping
 * rc-update: hostname.sh already installed in runlevel `sysinit'; skipping
 * rc-update: hwclock.sh already installed in runlevel `sysinit'; skipping
 * rc-update: checkroot.sh already installed in runlevel `sysinit'; skipping
 * rc-update: cryptdisks-early already installed in runlevel `sysinit'; skipping
 * rc-update: checkroot-bootclean.sh already installed in runlevel `sysinit'; skipping
 * rc-update: kmod already installed in runlevel `sysinit'; skipping
 * rc-update: zfs-import already installed in runlevel `sysinit'; skipping
 * rc-update: cryptdisks already installed in runlevel `sysinit'; skipping
 * rc-update: checkfs.sh already installed in runlevel `sysinit'; skipping
 * rc-update: mount-configfs already installed in runlevel `sysinit'; skipping
 * rc-update: zfs-mount already installed in runlevel `sysinit'; skipping
 * rc-update: mountall.sh already installed in runlevel `sysinit'; skipping
 * rc-update: mountall-bootclean.sh already installed in runlevel `sysinit'; skipping
 * rc-update: brightness already installed in runlevel `sysinit'; skipping
 * rc-update: procps already installed in runlevel `sysinit'; skipping
 * rc-update: stop-bootlogd-single already installed in runlevel `sysinit'; skipping
 * rc-update: urandom already installed in runlevel `sysinit'; skipping
 * rc-update: networking already installed in runlevel `sysinit'; skipping
 * rc-update: rpcbind already installed in runlevel `sysinit'; skipping
 * rc-update: mountnfs.sh already installed in runlevel `sysinit'; skipping
 * rc-update: mountnfs-bootclean.sh already installed in runlevel `sysinit'; skipping
 * rc-update: alsa-utils already installed in runlevel `sysinit'; skipping
 * rc-update: bootmisc.sh already installed in runlevel `sysinit'; skipping
 * rc-update: lm-sensors already installed in runlevel `sysinit'; skipping
 * rc-update: screen-cleanup already installed in runlevel `sysinit'; skipping
 * rc-update: x11-common already installed in runlevel `sysinit'; skipping
 * rc-update: sendsigs already installed in runlevel `off'; skipping
 * rc-update: umountnfs.sh already installed in runlevel `off'; skipping
 * rc-update: umountfs already installed in runlevel `off'; skipping
 * rc-update: umountroot already installed in runlevel `off'; skipping
 * rc-update: mdadm-waitidle already installed in runlevel `off'; skipping
 * rc-update: savecache already installed in runlevel `off'; skipping
 * rc-update: cgroups already installed in runlevel `sysinit'; skipping
 * Found a solvable dependency loop: mountall-bootclean.sh p> mountall-bootclean u> zfs-import a> checkfs n> mountall.sh p> mountall n> mountall-bootclean.sh.
 * Solving the loop by breaking mountall-bootclean u> zfs-import.
 * Found a solvable dependency loop: mountall.sh p> mountall u> zfs-import a> checkfs n> mountall.sh.
 * Solving the loop by breaking mountall u> zfs-import.        [ ok ]
Processing triggers for man-db (2.13.1-1) ...
Processing triggers for libc-bin (2.41-7) ...
smile
pyzNi 3.14zDa! smile
#10 2025-05-10 22:25:06
vazhnov
deepforest, I don't think your problem is connected with the topic subject.
#11 2025-05-10 22:30:29
Same as what? In what way is this related to failure of starting OpenSSH?
It's bad form to wake an old thread with just an useless sentence and some copy-paste.
Start your own issue, and explain what you did, what you expected should happen and what happened.
