#1 2024-06-28 18:22:16
zeitlos
Auto login
Please provide adequate instructions on how to configure desktop auto-login in Devuan.
#2 2024-06-28 19:19:24
igorzwx
Re: Auto login
It seems to be a philosophical problem. You may find such instructions in Arch Wiki.
Perhaps, you need SLiM manual
_https://wiki.archlinux.org/title/SLiM
See also
_https://wiki.archlinux.org/title/display_manager
If you have Mate Desktop, you are likely to have LightDM
_https://wiki.archlinux.org/title/LightDM
cat /etc/X11/default-display-manager
/usr/sbin/lightdm
#3 2024-06-28 20:41:55
Re: Auto login
In /etc/slim.conf, uncomment and edit default_user and auto_login lines:
# default user, leave blank to not pre-load the username.
#default_user        simone
# Focus the password field on start when default_user is set
# Set to "yes" to enable this feature
#focus_password      no
# Automatically login the default user (without entering
# the password. Set to "yes" to enable this feature
#auto_login          no
In /etc/lightdm/lightdm.conf, go down to the section that begins with [Seat:*] and uncomment the autologin-user line and add your user name.
#4 2024-06-29 06:15:09
Re: Auto login
It's not about Devuan, but about the chosen DE.
Full-featured ones (kde, tde, gnome, etc.) have settings for automatic configuration, passwordless login, permission to enter the root session, and other conveniences.
