#1 2024-06-13 19:22:26
webman
Need acoustic signalling (sound) where only root account is present
Hello!
How can I send sound from scripts or services, running at root?
Know not much about this, but pulseaudio seems to be a problem.
Although I found this:
pulseaudio --start --log-target=syslog --system
BUT, this is systemd, or not?
The man file says:
--system[=BOOL]
              Run as system-wide instance instead of per-user. Please note that this disables
             certain features of ..... (without mentioning them!)
So it is unclear about this!
Just an "aplay <file>" would enough for me!
Probably remove pulse and install pipewire?
Woudl they run without something like the
xdg-desktop(-portal) and can I remove these?
Thanks,
Manfred
#2 2024-06-14 00:52:14
Re: Need acoustic signalling (sound) where only root account is present
Remove pulseaudio and just use alsa. aplay should work just fine for that.
I suppose you could use pipewire if you know about that. I don't.
#3 2024-06-15 20:39:37
webman
Hello!
Thanks, will try that!
--br,
Manfred
