#1 2024-06-13 13:47:52
igorzwx
HiRes Binaural+ with ALSA
Binaural recording is a method of recording sound that uses two microphones, arranged with the intent to create a 3D stereo sound sensation for the listener of actually being in the room with the performers or instruments.
https://en.wikipedia.org/wiki/Binaural_recording
Dr. Chesky's Ultimate Headphone Demonstration Disc [Binaural]
_https://youtu.be/qB41sm1QCKI
EXAMPLE:
Dreams of New Orleans
Wycliffe Gordon
Chesky Records, Binaural+
192kHz · 24bit
_https://www.discogs.com/release/7294719-Wycliffe-Gordon-Dreams-Of-New-Orleans
_https://www.hdtracks.com/#/album/5bffd45cc6e102670ab3fe9f
Minimal HW requirements:
1. Computer with Intel HDA codec on motherboard.
NOTE: Very old computers (e.g. of 2006) may not have Intel codecs which support 32bit 192kHz.
2. A cheap analog headset (e.g. Sennheiser PC 3 Chat), or headphones.
NOTE: USB and wireless headsets are not suitable for the purpose.
Software: ALSA, fftrate ALSA plugin, Audacious.
Audacious → Settings → Audio → ALSA Output 32bit
To prevent resampling, configure fftrate for 32bit 192kHz (although, of course, 99.99% of Linux users may hear the difference, if resampling was made by Petrov's fftrate)
|  Main menu  |
    Curr. | Used | Play (def) | Rec (def) | Available cards
0 - >>>>> |  *   |  *     *   |  *    *   | HDA-Intel - HDA Intel PCH
U - Toggle used flag
P - Set this device as default player
R - Set this device as default recorder
O - Output device: PCH,0
I - Input device : PCH,0
F - Format: 192000 Hz, 2 ch, 'S32_LE'
C - Converter: fftrate
There is a belief that Petrov's fftrate may cure deafness, but it may not help PulseAudio users.
