#1 2024-05-27 18:57:24
devuan_dk_fan
[SOLVED] Exe GNU/Linux live user name and login?
Trying to test Exe GNU/Linux, but I can't get past the cli login. Shouldn't it boot into a graphical environment, and why can't I find any information about user name and password? Trying to use exegnu64_daedalus-20231220
I’ve had a perfectly wonderful evening, but this wasn’t it. - Groucho Marx
#2 2024-05-27 21:48:29
Re: [SOLVED] Exe GNU/Linux live user name and login?
I'm 99.9% sure that login:password is user:user and root:root and that it should boot to a desktop without logging in.
#3 2024-05-28 07:57:48
devuan_dk_fan
Thanks for the reply. I found that I am able to get to the Trinity desktop by choosing “nomodeset” in GRUB. There appears to be a problem using my Nvidia graphics card. All I can get is what looks like an 800x600 resolution. The card on my computer is an Nvidia GeForce GTX 1660 SUPER.
#4 2024-05-28 14:44:52
Maybe also add set gfxpayload=1280x1024 to the boot command. (or use your favorite resolution)
#5 2024-05-29 08:32:06
Driver for Nvidia GeForce GTX 1660 is supported by Debian 12 (Bookworm).
https://debian.pkgs.org/12/debian-nonfr … 4.deb.html
Edit. A link to the Debian repository is not needed.
#6 2024-05-29 14:23:03
I think adding a debian repo without pinning it to a low priority is asking for trouble. You bypass amprolla which filters out systemd. It's also unnecessary because the same package is available through devuan repos in the non-free section.
$ apt policy nvidia-driver
nvidia-driver:
  Installed: (none)
  Candidate: 525.147.05-7~deb12u1
  Version table:
     535.161.08-2~deb12u1 100
        100 http://pkgmaster.devuan.org/merged daedalus-proposed-updates/non-free amd64 Packages
     525.147.05-7~deb12u1 500
        500 http://deb.devuan.org/merged daedalus-updates/non-free amd64 Packages
     525.147.05-4~deb12u1 500
        500 http://deb.devuan.org/merged daedalus/non-free amd64 Packages
Note: I have proposed-updates pinned to low priority (100) and that's why the newest version isn't shown as the Candidate.
#7 2024-05-29 16:51:16
Yes, you are right, you need to install the package from the Devuan repository.
#8 2024-05-30 13:58:34
devuan_dk_fan
Many thanks for the replies.
