#1 2024-05-16 10:22:29
Firefox 'diversion' to 'firefox.real'?
Still on Devuan Beowulf with a backported kernel:
~$ uname -a
Linux devuan 5.10.0-0.deb10.16-amd64 #1 SMP Debian 5.10.127-2~bpo10+1 (2022-07-28) x86_64 GNU/Linux
During my weekly update, apt offered to upgrade Firefox to 115.11.0esr.
I went ahead and in the process the output read:
Preparing to unpack .../firefox-esr_115.11.0esr-1~deb10u1_amd64.deb ...
Leaving 'diversion of /usr/bin/firefox to /usr/bin/firefox.real by firefox-esr'               ### <---
Unpacking firefox-esr (115.11.0esr-1~deb10u1) over (115.10.0esr-1~deb10u1) ...
Setting up firefox-esr (115.11.0esr-1~deb10u1) ...
--- snip ----
I do not recall seeing this Leaving 'diversion ...   line ever before.
Looked at /usr/bin and got two instances of firefox:
~$ ls /usr/bin | grep firefox
firefox
firefox-esr
Checked with apt and found one instance of firefox:
~$ apt list | grep installed | grep firefox
firefox-esr/oldoldstable-security,now 115.11.0esr-1~deb10u1 amd64 [installed]
webext-ublock-origin-firefox/oldoldstable,oldoldstable,now 1.42.0+dfsg-1~deb10u1 all [installed]
mc shows them as *firefox and @firefox-esr.
~$ cat /usr/bin/firefox
FIREFOX="$(command -v firefox)"
[ -x "$FIREFOX.real" ] && exec "$FIREFOX.real" "$@"
exec firefox-esr "$@"
So /usr/bin/firefox-esr is a symbolic link to /lib/firefox-esr/firefox-esr.
Is all this related to the 'merge'?
Is there anything I have to do or does it stay like that?
#2 2024-05-16 16:35:37
Re: Firefox 'diversion' to 'firefox.real'?
Daedalus, same thing, same teams.
No merger.
#3 2024-05-16 19:06:49
Daedalus, same thing ...
I see.
Not a merge after-effect then.
Poked around some more and found this.
Debian Bug report logs - #1033594
The diversion of "/usr/bin/firefox" by "firefox-esr" package does not respect a previously added local diversion
Looked some more and found a definition/explanation of diversion
linux.die.net wrote:
File diversions are a way of forcing dpkg(1) not to install a file into its location, but to a diverted location. Diversions can be used through the Debian package scripts to move a file away when it causes a conflict.
Right ...
But why is this happening in my box? (and apparently in yours also ...)
Thanks for your input.
