#1 2024-05-03 00:30:32
zeitlos
Result of rkhunter check
Hello everyone. I checked the system using rkhunter. There were two suspicious points. Should you worry? Or a false alarm? Thanks in advance for your answer.
Warning: Suspicious file types found in /dev:
[03:09:51]          /dev/shm/jack_db-1000/metadata.db: Berkeley DB (Hash, version 9, native byte-order)
[03:09:51]          /dev/shm/jack_db-1000/__db.003: a.out little-endian 32-bit pure executable
[03:09:51]          /dev/shm/jack_db-1000/__db.002: a.out little-endian 32-bit pure executable
[03:09:52]          /dev/shm/jack_db-1000/__db.001: Applesoft BASIC program data, first line number 18
Warning: The following suspicious (large) shared memory segments have been found:
[03:09:22]          Process: /usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1    PID: 2069    Owner:    Size: 4,0MB (configured size allowed: 1,0MB)
[03:09:22]          Process: /usr/bin/xfce4-panel    PID: 1968    Owner:    Size: 4,0MB (configured size allowed: 1,0MB)
[03:09:22]          Process: /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-2.0    PID: 2002    Owner:     Size: 32MB (configured size allowed: 1,0MB)
[03:09:22]          Process: /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-2.0    PID: 1980    Owner:   Size: 4,0MB (configured size allowed: 1,0MB)
[03:09:22]          Process: /usr/bin/xfdesktop    PID: 1977    Owner:     Size: 64MB (configured size allowed: 1,0MB)
[03:09:22]          Process: /usr/bin/thunar    PID: 1496    Owner:    Size: 16MB (configured size allowed: 1,0MB)
[03:09:22]          Process: /usr/bin/nm-applet    PID: 2047    Owner:     Size: 16MB (configured size allowed: 1,0MB)
[03:09:22]          Process: /usr/bin/nemo    PID: 11619    Owner:     Size: 16MB (configured size allowed: 1,0MB)
[03:09:22]          Process: /usr/bin/nemo    PID: 18777    Owner: root    Size: 16MB (configured size allowed: 1,0MB)
[03:09:22]
#2 2024-05-03 06:39:57
Re: Result of rkhunter check
re: suspect -
ttps://www.reddit.com/r/voidlinux/comments/n6eo9m/strange_directory_persisting_in_devshm/?rdt=53428
re: size -
ttps://forums.linuxmint.com/viewtopic.php?t=360159
#3 2024-05-04 21:15:41
zeitlos
Thank you
