Pages: 1
as normal user
ping google.com
ping: socktype: SOCK_RAW
ping: socket: Operation not permitted
ping: => missing cap_net_raw+p capability or setuid?
as root user
ping -c 5 google.com
PING google.com(fra02s19-in-x0e.1e100.net (2a00:1450:4001:808::200e)) 56 data bytes
64 bytes from fra15s46-in-x0e.1e100.net (2a00:1450:4001:808::200e): icmp_seq=1 ttl=116 time=34.9 ms
64 bytes from fra15s46-in-x0e.1e100.net (2a00:1450:4001:808::200e): icmp_seq=2 ttl=116 time=40.8 ms
64 bytes from fra15s46-in-x0e.1e100.net (2a00:1450:4001:808::200e): icmp_seq=3 ttl=116 time=38.1 ms
64 bytes from fra15s46-in-x0e.1e100.net (2a00:1450:4001:808::200e): icmp_seq=4 ttl=116 time=37.4 ms
64 bytes from fra15s46-in-x0e.1e100.net (2a00:1450:4001:808::200e): icmp_seq=5 ttl=116 time=35.0 ms
--- google.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4006ms
rtt min/avg/max/mdev = 34.934/37.240/40.754/2.157 ms
that is happening in devuan stable ... any ideas ?
Dev1 Stable | openrc | XFCE
Greetings from Greece
it seems that the issue of not being able to ping from a normal user account.
The error message
followed by
indicates that the user does not have the necessary permissions to use the ping command.
The error message
suggests that the user needs to have the cap_net_raw capability or
setuid permission
The user can add the cap_net_raw capability to their account using the following command:
sudo setcap cap_net_raw+ep /bin/ping
P.S.
You're not sending an ICMP echo request, most likely (check "ip a" at the time) you don't have a lease but only the IPv6 link local address.
thank you very much .. its solved
Pages: 1
