I an not using the internet on my pc installation for now
so i an installing package from a mounted iso and from the Downloads folder
package and dependency are downloaded from devuan package search and from the iso
the downloaded are stored in Downloads and install whit
# sudo dpkg -i
but is also added in synaptic as 'files. add downloaded packages' and path to Downloads
these files is not shoving op i synaptic, the only package i see are they already installed
packages all mark whit green. if i search for the 'tree' file i am getting a list i synaptic of 13 contain
installed dependency files. to find and install the 'tree' file i have to 'cp' it to Downloads
or use the ls and the absolute path too the mounted iso. and first there after is the 'tree' file visible in synaptic
in fact the only packages i is in synaptic is these already installed packets and only installed packagers
ls /mnt/disk/pool/DEBIAN/main/t/tree
tree_2.1.0-1_amd64.deb
sudo dpkg -i /mnt/disk/pool/DEBIAN/main/t/tree/tree_2.1.0-1_amd64.deb
the iso is mounted in these way
# sudo mount -o loop /mnt/fiso/devuan_daedalus_5.0.1_amd64_desktop.iso /mnt/disk
i haw previous used my usb iso and that worked for a while mounting it in these way
# sudo mount --bind /media/user/DEVUAN501/ /mnt/disk
the big defriends is the name DEVUAN501 ther is no name in the mnt/disk/ only an some access to the iso file /pool exc...
In synaptic i am getting the following error when updating the packet list
The repository 'file:/mnt/disk/pool/DEVUAN daedalus Release' does not have a Release file.
Updating from such a repository can't be done securely, and is therefore disabled by default.
See apt-secure(8) manpage for repository creation and user configuration details.
The repository 'file:/mnt/disk/pool/DEBIAN daedalus Release' does not have a Release file.
Could not download all repository indexes
The repository may no longer be available or could not be contacted because of network problems.
If available, an older version of the failed index will be used. Otherwise, the repository will be ignored.
Check your network connection and ensure the repository address is correct in 'Repositories' under 'Settings'.
and my sources-lits
# deb cdrom:[Devuan GNU/Linux 5.0.1 daedalus amd64 - desktop 20230914]/ daedalu>
#deb http://deb.devuan.org/merged/ daedalus main
#deb http://deb.devuan.org/merged/ daedalus-security main
#deb http://deb.devuan.org/merged/ daedalus-updates main
I haw add this line too the sources-list. sow i can search the mounted iso file
deb file:/mnt/disk/pool/DEVUAN/ daedalus non-free-firmware non-free main contri
deb file:/mnt/disk/pool/DEBIAN/ daedalus non-free-firmware non-free main contri
I haw add too more lines in sources.list
deb file:/mnt/disk/pool/DEVUAN/ daedalus non-free-firmware non-free main contrib
deb file:/mnt/disk/pool/DEBIAN/ daedalus non-free-firmware non-free main contrib
deb file:/mnt/disk/devuan/ daedalus non-free-firmware non-free main contrib
deb file:/mnt/disk/debian/ daedalus non-free-firmware non-free main contrib
and install aptitude, but search dos not provide any info on files not install
from aptitude updat
$ sudo aptitude update
Get: 1 file:/mnt/disk/pool/DEVUAN daedalus InRelease
Ign file:/mnt/disk/pool/DEVUAN daedalus InRelease
Get: 2 file:/mnt/disk/pool/DEBIAN daedalus InRelease
Ign file:/mnt/disk/pool/DEBIAN daedalus InRelease
Get: 3 file:/mnt/disk/devuan daedalus InRelease
Ign file:/mnt/disk/devuan daedalus InRelease
Ign http://deb.devuan.org/merged daedalus InRelease
Get: 4 file:/mnt/disk/debian daedalus InRelease
Ign file:/mnt/disk/debian daedalus InRelease
Ign http://deb.devuan.org/merged daedalus-security InRelease
Get: 5 file:/mnt/disk/pool/DEVUAN daedalus Release
Ign http://deb.devuan.org/merged daedalus-updates InRelease
Err file:/mnt/disk/pool/DEVUAN daedalus Release
File not found - /mnt/disk/pool/DEVUAN/dists/daedalus/Release (2: No such file or directory)
Get: 6 file:/mnt/disk/pool/DEBIAN daedalus Release
Err file:/mnt/disk/pool/DEBIAN daedalus Release
File not found - /mnt/disk/pool/DEBIAN/dists/daedalus/Release (2: No such file or directory)
Get: 7 file:/mnt/disk/devuan daedalus Release [640 kB]
Get: 8 file:/mnt/disk/devuan daedalus Release [640 kB]
Get: 9 file:/mnt/disk/debian daedalus Release [640 kB]
Get: 10 file:/mnt/disk/debian daedalus Release [640 kB]
Get: 11 file:/mnt/disk/devuan daedalus Release.gpg
Ign file:/mnt/disk/devuan daedalus Release.gpg
Get: 12 file:/mnt/disk/debian daedalus Release.gpg
Ign file:/mnt/disk/debian daedalus Release.gpg
Err http://deb.devuan.org/merged daedalus InRelease
Temporary failure resolving 'deb.devuan.org'
Err http://deb.devuan.org/merged daedalus-security InRelease
Err http://deb.devuan.org/merged daedalus-updates InRelease
E: The repository 'file:/mnt/disk/pool/DEVUAN daedalus Release' does not have a Release file. 213 kB/s 0s
E: The repository 'file:/mnt/disk/pool/DEBIAN daedalus Release' does not have a Release file.
E: The repository 'file:/mnt/disk/devuan daedalus Release' is not signed.
E: The repository 'file:/mnt/disk/debian daedalus Release' is not signed.
E: Failed to download some files
W: Failed to fetch http://deb.devuan.org/merged/dists/daedalus/InRelease: Temporary failure resolving 'deb.devuan.org'
W: Failed to fetch http://deb.devuan.org/merged/dists/daedalus-security/InRelease: Temporary failure resolving 'deb.devuan.org'
W: Failed to fetch http://deb.devuan.org/merged/dists/daedalus-updates/InRelease: Temporary failure resolving 'deb.devuan.org'
W: Failed to fetch file:/mnt/disk/pool/DEVUAN/dists/daedalus/Release: File not found - /mnt/disk/pool/DEVUAN/dists/daedalus/Release (2: No such file or directory)
W: Failed to fetch file:/mnt/disk/pool/DEBIAN/dists/daedalus/Release: File not found - /mnt/disk/pool/DEBIAN/dists/daedalus/Release (2: No such file or directory)
W: Some index files failed to download. They have been ignored, or old ones used instead.
I am wondering about if installing a Linux os and building an desktop environment on it
whit out a internet connection is possible at all, as I install more and more I getting more failiers, like cp. a file send its to the bin
A question her could be, creating a git on the same HDD will give me what I need to solve the problem with the installation
the question is not all about this installation but also the replacement of it.
the problem is temporarily solved by reinstalling my PC, but I still have no idea what causes the problem with synaptic or by not using its installation as a network device
