#1 2024-03-30 14:16:03
freegamea1
[SOLVED] strange process.
sudo ps aux | grep ssh
user      2091  0.0  0.0   7740  2120 ?        Ss   17:10   0:00 /usr/bin/ssh-agent env LD_PRELOAD=libgtk3-nocsd.so.0 x-session-manager
what is this? and how i can disable ssh-agent in devuan?
#2 2024-03-30 17:20:03
Re: [SOLVED] strange process.
See the man page for ssh-agent (although a quick look doesn't say how to disable it). I've not used it myself though.
#3 2024-03-30 18:19:00
I have the same/similar process:
~$ sudo ps aux | grep ssh
user   3129  0.0  0.0   5864   472 ?        Ss   14:00   0:00 /usr/bin/ssh-agent x-session-manager
user  10581  0.0  0.0   3084   896 pts/0    S+   15:10   0:00 grep --color=always ssh
This is because I have openssh-client installed so I can command-line log into a headless VM I have running in my box.
~$ apt list | grep installed | grep ssh-
libssh-gcrypt-4/oldoldstable-security,now 0.8.7-1+deb10u2 amd64 [installed,automatic]
openssh-client/oldoldstable-security,now 1:7.9p1-10+deb10u4 amd64 [installed]
ssh-askpass/oldoldstable,now 1:1.2.4.1-10 amd64 [installed,automatic]
#4 2024-03-30 20:58:20
Try by adding a single "#" at the beginning of the line that says use-ssh-agent in /etc/X11/Xsession.options; then log out and in to restart the X session.
