Pages: 1
Hi All,
not sure if this packaging problem is on debian side or not -- this is what I get when installing kicad on my devuan testing box:
ii kicad 7.0.11+dfsg-1 amd64 Electronic schematic and PCB design software
ii kicad-demos 7.0.11+dfsg-1 all Demo projects for kicad
ii kicad-footprints 8.0.1-1 all Footprint symbols for KiCad's Pcbnew
ii kicad-libraries 7.0.11+dfsg-1 all Virtual package providing common used libraries by kicad
ii kicad-symbols 8.0.1-1 all Schematic symbols for KiCad's Eeschema
ii kicad-templates 8.0.1-1 all Project templates for KiCad
Notice the mismatch in versions between different kicad package components.
Please advise. Thanks.
Check the maintainer field when you look at "apt info PACKAGENAME".
Does it mention Devuan? (No, it doesn't.)
If the v8 packages are not backwards compatible, then it's a Debian bug, which you should raise via Debian's bug tracking system.
3.1415P265E589T932E846R64338
Got it, thank you!
On the off chance anyone else is waiting for kicad packages, I am using a flatpak version of kicad 8, it works fine.
Pages: 1
