#1 2024-03-14 20:45:32
chomwitt
virt-manager works only when started as root.
$ dpkg -l virt-manager
ii  virt-manager   1:4.1.0-2    all          desktop application for managing virtual machines
I have added myself to the libvirt group (to pass another error : unable to connect to libvirt)
but now starting virt-manager as a regular user i see 'QEMU/KVM - Not connected' and left clicking on the create a new virtual machine
i see a error window "Error : No active connection to install on."
But $ sudo virt-manager doesnt display that issue.
@devuanwiki
#2 2024-03-14 21:59:32
Re: virt-manager works only when started as root.
Hi, talking about permissions...
I used to run windows on a virtual (box) machine, and I used these changes to smooth the way...
#chown -hR vboxusers:vboxusers /opt/VirtualBox/VBox.sh
#chown -hR vboxusers:vboxusers /usr/bin/VirtualBox
#chmod -R 755 /usr/bin/VirtualBox
#chmod -R 755 /opt/VirtualBox/VBox.sh
#chgrp -h glenn /home/glenn/local/vm1/
#chmod -R 755 /home/glenn/local/vm1/
Just sharing the idea... I hope it helps.
#3 2024-03-14 23:21:49
chomwitt
GlennW thanks for the ideas but i think virtualbox is a different virtualization program .
For time being i followed the https://wiki.archlinux.org/title/Virt-manager  instructions and it worked.
@devuanwiki
#4 2024-03-15 06:14:48
Great! It's the permissions I was reffering to. But glad you got it working.
#5 2024-03-15 06:36:15
chomwitt
Sorry. I guess you are right in guiding towards a pemission issue because eventually i had to change permission
related libvirtd options:
$ sudo nano /etc/libvirt/libvirtd.conf
unix_sock_group = "libvirt"
unix_sock_rw_perms = "0770"
$ sudo nano /etc/libvirt/qemu.con
user = "chomwitt"
group = "chomwitt"
And it was essential  to do also:
Upon opening Virt-Manager, it will default to the system variant (root) of the QEMU connection.
This can be changed to the user connection by going to: File > Add Connection.
Now select QEMU/KVM User session as the Hypervisor and click OK
@devuanwiki
#6 2024-03-15 12:36:32
Just add your user to
libvirt-qemu
group and relogin session.
#7 2024-03-17 05:36:22
chomwitt
I will try that and report back in this same reply.
@devuanwiki
