I have openbox, LXDE and Mate and LXDE is always the default one.
I've already set autologin in slim.conf but there is nowhere a place to set Mate as a default.
How to do it, please?
m
I've already set autologin in slim.conf but there is nowhere a place to set Mate as a default.How to do it, please?
m
Hm, try maybe in same /etc/slim.conf to put sessions line, in order you want of course:
sessions mate,lxde,openboxAh, that is not there anymore it seems maybe work mayb not... nothing, does this allows you to select default:
sudo update-alternatives --config x-session-managerIf it does that is it, just select default..
You've nailed it, smoki!
That's it.
Thanks a lot,
m
