#1 2024-02-29 21:49:10
Deze
[SOLVED] Changing permissions on external drive
An external ext4 formatted media drive has switched to read-only. I suspect a cheap usb hub is the culprit.
In Nautilus as Administrator, i can't change permissions, 'Error setting permissions: Read-only file system'
$ sudo chmod g+w /media/user/UUID
and reboot doesn't fix it.
Reformatting the drive would be a hassle. Are there other commands?
Devuan GNU/Linux 5 (daedalus) x86_64
#2 2024-02-29 22:46:26
Dutch_Master
Re: [SOLVED] Changing permissions on external drive
There might be something else going on you probably don't realize. Do the following:
su #become root, alternatively sudo su
fsck /media/<user>/<UUID> #check the file system for errors and repair if required
chown <user> /media/<user>/<UUID> #make sure the directory is owned by the user
chmod 777 /media/<user>/<UUID> #set permissions for the directory for general access
HTH!
#3 2024-03-01 18:55:02
Deze
Thank you.
# fsck /media/<user>/<UUID>
Returns error message:
fsck.ext2: Is a directory while trying to open /media/<user>/<UUID>
The superblock could not be read or does not describe a valid ext2/ext3/ext4
Commands:
# e2fsck -b 8193 <device>
# e2fsck -b 32768 <device>
Error message:
e2fsck: Is a directory while trying to open /media/<user>/<UUID>
Gparted shows 2 partitions:
1. File system ext4
Flags: msftdata
2. File system 1 mb unallocated
No flags
Are these settings ok for a media drive?
#4 2024-03-01 19:25:38
To clarify: Have you replaced the placeholder <user> with your username? And the placeholder <UUID> with the correct UUID of the device?
Maybe you show us with the drive connected:
# blkid
# lsblk
Then: the unallocated space is fine. But why does the ext4 file system have a msftdata flag, a Windows descriptor?
#5 2024-03-01 22:03:50
Deze
Yes, i replaced <user> and  <UUID> with the correct names, i double-checked with # blkid and # lsblk.
In Gparted i formatted the new WD Elements drive as ext4. I don't remember enabling the msftdata flag. Disabling the flag isn't possible, the key icon in the Partition column probably indicates the drive is locked. I can open files, copying files to the drive and editing isn't possible.
I have no clue how this switch could have happened. Just format the thing?
Thanks.
#6 2024-03-02 18:57:52
It's locked because it's mounted. Right-click on it to unmount.
Any time I've used fsck, I've done it on an unmounted device, like /dev/sdb1 for example. I just tried running it on a mounted filesystem, using the directory, and I got the same error you got about superblock.
#7 2024-03-03 10:37:31
@#1
In case the partition is mounted read-only (ro):
Altering the permissiion of the directory to read-write is not enough. The partition must be re-mounted read-write (rw) as well.
First check the output of mount to see whether this applies at all. (sticking to /dev/sdb1 as example)
$ mount
$ sudo mount -o remount,rw /dev/sdb1
Open question to answer is still: Why was the partiton mounted read-only at all?
Re-mounting the partition rw manually is curing a sympotom - if the real reason allows this at all.
#8 2024-03-03 17:33:02
Look in /etc/fstab to see if it has an entry.
Check dmesg output and syslog for messages about the device or the mountpoint.
Try e2fsck -n <device> (-n means read only so should work for mounted devices). If that shows errors you need to *umount* the device, then run e2fsck <device> (specify the device, not the mountpoint).
#9 2024-03-23 16:58:03
Deze
Fixed.
$ sudo umount /dev/sdb1
/dev/sdb1: recovering journal
/dev/sdb1 contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Invalid inode number for '.' in directory inode 112197682.
Fix<y>? yes
Pass 3: Checking directory connectivity
'..' in /.Trash-1000/files/[file names]), should be /.Trash-1000/files/[file names].
Fix<y>? yes
/lost+found not found.  Create<y>? yes
Pass 4: Checking reference counts
Pressed y to all q's
/dev/sdb1: ***** FILE SYSTEM WAS MODIFIED *****
Read & Write restored 🙏
The new lost+found folder contains files that i had moved to Trash.
There's a new .Trash-1000 folder that contains .trashinfo file in the info folder. When i delete the file it replicates and adds a .trashinfo extension. I'll let it be.
Permissions problem was easier to fix than it looked, thank you for your help!
