#1 2024-02-27 23:17:26
haary
[SOLVED] sway and screensharing
Did anyone manage to make screensharing work in Devuan with sway / Wayland?
I'm running Devuan Daedalus with the runit init system and sway compositor.
When I try to start screensharing in Firefox / BigBlueBotton I can select the output from I wish to share the screen but then nothing happens. xdg-desktop-portal-wlr is running, so is pipewire. I'm starting sway with dbus-run-session and have
dbus-update-activation-environment DISPLAY I3SOCK SWAYSOCK WAYLAND_DISPLAY XDG_CURRENT_DESKTOP=sway
set at the top of my sway config file, according to the troubleshooting check list of xdg-desktop-portal-wlr.
It's working out of the box on a Debian Bookworm machine, so I guess there is some systemd - dbus "magic" which is missing in Devuan.
#2 2024-02-28 18:34:26
haary
Re: [SOLVED] sway and screensharing
I got it:
  • Install pipewire pipewire-alsa pipewire-pulse pipewire-jack wireplumber xdg-desktop-portal-wlr
  • At the top of ~/.config/sway/config add
    exec dbus-update-activation-environment DISPLAY I3SOCK SWAYSOCK WAYLAND_DISPLAY XDG_CURRENT_DESKTOP=sway
    exec pipewire &
    exec pipewire-pulse &
    exec wireplumber &
  • Start sway with XDG_CURRENT_DESKTOP=sway dbus-launch sway
After this, screen sharing in BigBlueButton and Jitsi Meet in Firefox is working in sway
